But what is the thickness of reddingsdeken?
Is not it too thick?
If the thickness is right, it is the best solution.
GGLE does not know what reddingsdeken is. However metal coated polyethylene terephthalate AKA Maylar is used in "inverted" ESL a la Final. Windows shades are 12 microns or one half of a mil. Same goes for emergency blanket: see attach.
It's too heavy for 20k. 6 microns or 1/4th of a mil will do.
Anti-static Metal Shielding roll/ESD Shielding VMPET sheet/Shielding Film
Lowest thickness value 5 micron and with the right resistance.
Up to 1 meter width.
Minimum order only 500 square meters.
Anti-static Metal Shielding Roll/esd Shielding Vmpet Sheet/shielding Film - Buy Antistatic Shielding Film,Esd Shielding Film,Esd Films Product on Alibaba.com
Tried to find information about the thickness. I can only find 75um. wout31
Where did you find 5um?
And where do you find resistivity values? 10^9 would be great.
Send an inquiry if you're willing to buy the quantity.Ok 10^8 to 10^10 is great... byt still WAY too thick... 75um = 0.075mm...
Plus some $ 200 - $ 300 for transport + taxes. So more like $ 400 - $ 600 for the batch. To be paid upfront with an LC.Is $140 (500*0.28) the last straw that breaks the camel's back?
Got my first Quad ESL-63 element (just 1 of the 4) playing with PEDOT😛SS. Mind you, NO ready formula as was stated here before. Ready bought formula is way too low in resistance.
So far, so good. Silent, no rattle, no click or hiss, good sound as far as I can say for now. Let's see how it lasts in testing.
Pricey stuff that PEDOT that's why only one panel for now to test. As it's water based I want to see if it sticks for a longer period and how it reacts to humidity changes.
Thickness added by the coating is 2 micron according to my meter. (the cheap one)
No measurement done on weight yet, that's for later.
My reading off Quad ESL 63 panel:
Shouldn’t it be higher?
I've stopped repairing 63 panels cause they are so poorly made with wrong glues and flimsy construction.
And, your picture shows a typical untouched Huntington panel in all its glory, with amateurishly sprayed membrane...
So now you put them together with the correct glue and you spray the panels professionally with the correct conductive coating.I've stopped repairing 63 panels cause they are so poorly made with wrong glues and flimsy construction.
They should be fine again for many years.
A little off-topic: Does anyone know where I can get a single dead or blown ESL57 tweeter panel? I want to measure the stator parts to try to make a 3D-printed version.
Bwaslo, I don't understand you want to print this, as the stator of the ESL 57 is a flat plastic sheet with round holes all of the same size.A little off-topic: Does anyone know where I can get a single dead or blown ESL57 tweeter panel? I want to measure the stator parts to try to make a 3D-printed version.
I can give you the outside size, the hole size, the thickness and the hole pattern. The spacers for the diaphragm are glued on plastic strips, I can give you width and thickness of those too.
Most important: what a bout the resistive coating on the stator, how are you going to solve that? Or are you going to use in a different way?
I've got a busted panel for you, but shipping if from The Netherlands to the USA is probably total overkill in costs. Hope you can find one in your own country. Ebay is your friend.
- Planars & Exotics
- ESL Diaphragm coating
