... hm, sorry for eventually generating confusion.
The complete data sheet for the CREE C3D02060 diode is attached.
My consideration took reference to figure 1, forward characteristics. This plots the forward voltage drop caused by the actual current through the diode (even for different temperatures; i.e. pls. respect the heat sink req.).
Anyhow, rule of thumb seems to be that the voltage drop is AROUND 1V for this SiC Schottky diode and I would definitely suggest to verify this upfront experimentally.
All the best,
Ulrich
All the best,
Ulrich
Thank you kindly UL2 , would this mean that for every 10v passing through the diode the’ll be a 1v drop ? Sorry if this sounds silly, Im learning.
Thks
Thks
To use the SiC it's only to change the filament resistor for the SiC? How to calculate how many SiC are needed (attached schematic)?
Dear Felipe,
I'm reading the C3D02060 datasheet such, that at around 1A a voltage drop of 1.2V "typically" happens. You can therefore use either 8 diodes (=9.6V) or 9 diodes to achieve 10.8V. In reality this might slightly vary, being the reason to check this upfront.
All the best,
Ulrich
The C3D02060F drops around 0.8v at 5mA to 0.85v at 15mA. So you just need to add them together for the bias voltage you want. I'm tempted to buy 100!
GB?
Thanks Ulrich I guess do you use chassis as heatsink for them?
Well,
in most cases I prefer to use wooden "chassis" as my manufacturing skills are limited regarding metallic parts.
One example is attached.
This is my current class A tube switching pre-amp.
It provides switching between the 01A and 2P29L tube and between Gyrator/Anode choke as well as between C-R-C and C-L-C filament power supply.
This tool helped me to decide on how to proceed further towards the next pre-amp implementation.
All the best,
Ulrich
Wow nice quality plywood UL2, over my end hard to find plywood of the quality that your using.
Cheers
Cheers
Well,
All the best,
Ulrich
Congrats Ulrich very good wood work.
Cheers
Felipe
Andy do you use Coleman heater regulators in your 01A?
Yes.
I read that you use choke load, how many H for 26 preamp? what do you like better amorphous because have more resolution?
I have a string of 6 x CSD01060A on my 01A and the bias is exactly 5v. That's 0.83v each.
So, according the CSD01060A data sheet, I interpret that you run these diodes below 50mA, right?
All the best,
Ulrich
Should be around 4mA for an 01A.
Regarding plate chokes - yes, I like the NP Acoustics 136H 15mA amorphous plate choke. It's the best plate choke I've used. Nothing fancy cosmetically, just sounds good.
Here is the review of the shootout we had with Andy yesterday.
Also Morgan Jones came today to my place and listened to the final system: 01a-VT-25 into 4P1L PSE. A very busy couple of days!
http://www.bartola.co.uk/valves/2018/08/09/dht-audio-shootout-london/
Cheers
Ale
Cheers
Ale
Huge thanks to Ale for hosting this 10 preamp shootout, and for enabling us to hear the SIC diodes in the cathode. I converted my 01A preamp today and am delighted with the added clarity. I've ordered 100 more. Not cheap but I'm going to use them in the 2P29L preamps and the 10Y. 100 isn't going to last long! The 01A takes 12 and the 2P29L is going to take more like 26..... and then...... and then......
Sounds like fun with diode bias!
The SiC schottky diodes should look somewhat like LED bias, but with the advantage of lower (signal) resistance.
And unlike LEDs, they will not need to be covered (light-proofed), to prevent noise from ambient light sources - LEDs can work in reverse.
At 1-10A, the diodes present about 1Ω to the signal. At lower currents (below 100mA) the SiC diode is in the threshold region. At 4mA, it is very close to threshold, and I would expect it to be somewhat non-linear: you can see the forward transfer curve curling, and the low-end.
If the SiC rectifiers sound good in this position, a couple of further tests come to mind immediately:
- the forward voltage will be more stable, and the signal resistance will be lower, if the current is increased to at least 250-500mA. The easy way to achieve this would be to filament-bias the diode string. 250mA would bring the signal resistance of the C3D02060A down to around 1Ω.
Filament bias would also increase the forward voltage, so you would need fewer diodes to get the same bias-voltage.
- The great advantage of SiC rectifiers, i.e.: much lower reverse-recovery current pulses (lower overall noise) - is of no use in this application; they are only forward-biased. Before spending a large amount of cash on Wolfspeed diodes, it would be worth checking out ordinary diodes rated for high current - and compare the sound. The MUR860 (8A continuous) should do nicely. The general nature of the forward transfer characteristic is very similar - while the cost is around 20dB lower.
RS stocks the MUR860 at pretty much the same price as the Wolfspeed (60p+for 25), and it's discontinued at Farnell. Any other suggestions?
Ale was saying the same as you - try it out in filament bias because it needs more current. It does sound nice with the 01A despite everything. Next will be the 2P29L at 15mA but in filament bias we're really turning on the current. That should be interesting.
Absolutely love your final terminology. Puts alot of this into perspective.
Cheers
Hey Ale, love your site, some really nice things on there that I want to try out 🙂 Rod's here too, have a bunch of his filament/bias boards here ready to go into amps.
Still on the fence about CCS/Gyrators in the anode circuit, have always preffered inductive loads and no solid state in the signal path. Maybe you'll convince me one day 😉
sorry for the threadjack
- Tubes / Valves
- 01A question
