Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
Hi genard, unfortunately no one around to help me with that. 🙁
I have some measuring equipment that I do not even know the name, somewhere in the storage. I hope I can ask people how to use them someday.
I wanted to try IRFP9240 but I do not have them and I found IRFP150N, thus I tried the 2SJ28 that was left from the use of 2SK82. It is just a random pick up and trial. 🙂
Do you mean the resistor bigger than 1 ohm is not recommended? With 2 ohms Vds of IRFP150N is now 10V or so..
Do you have more P SITs?
this one way there might be one better fitting... but best is to measure them.
Or you try all your IRFP150 and look for a brother of the first one.
Yes in fact I have some including 2SK82 and 2Sk180, THF51-S. Even I can see that the variation is high. they make sound but far from consistent.
You mean P SIT have more candidate N FETs? If so I think I can try them..
you need a SIT with around 4.5V at 1.5A and the same for the P channel.
Look that is/was my SITuation...
Black the N-SITs red the P channels.
one thing I'm constantly forgetting to investigate (going through catalogs , then being distracted with something else) ;
IRFP150 is , say , as two IRFP240 in one case
is there some counterpart ( two IRFP9240 in one case ) in P polarity ...... ?
of course - easily available , and cheap ...... :clown:
