lingDAC - cost effective RBCD multibit DAC design
Update, Feb 2024
Another long-overdue update, I'd completely forgotten that I was maintaining some info at the start of this thread. So what's new :
Kubelik kits are no longer for sale. The credit-card sized kit DAC slot is now occupied by Dorati which has an all-discrete analog section but is otherwise very similar to Kubelik.
The most recently introduced DAC is Abbado II - it has a 5th order built-in LC filter and 16 paralleled TDA1545s. Its design grew out of the experiments I did with stacking multiple DAC chips aka 'Stack-a-DAC'.
Celibidache's design is over two years old now, it uses a 9th order plug-in filter and 20 paralleled TDA1387s. Its the last in the generation of TDA1387 designs, after this I moved over to TDA1545.
At the top of the pile for single board DACs is Marriner, only available ready built with a 9th order plug-in filter and twin PCM56s per channel.
For those building multiple board DACs, there is the Dark LED I/V filter. This is designed to pair up with a wide range of R2R type current-out DAC chips.
In 2024 I'm planning to introduce a DAC with an upsampling filter, so gradually trending away from NOS with the intention of getting the sound quality of higher order LC filters but without their complexity and cost. The digital filter won't be an off-the-shelf device, rather an MCU which gives the opportunity to upgrade the filter with a firmware update.
Update, Sep 2021
This update is long overdue, my apologies for missing out on the opportunity to place some more up to date info here. PhiDAC hex kits aren't available any longer, that design has been replaced by Phi DecaDAC which uses 10 chips rather than 6. The price though only marginally increased for the improved variant and plug-in filters from 'hex' still are compatible with the current design.
Technical discussion on Phi DecaDAC begins here : lingDAC - cost effective RBCD multibit DAC design
There is also a more recent design called 'Kubelik' which has 6 DAC chips and an integral 3rd order filter (no plug-in) in the same form factor (81*50mm) as the original PhiDAC. Kubelik is only available in kit form at present. You can also build Kubelik yourself with parts from Mouser (with the exception of PCB and DAC chips) as there's a BOM. Gerbers are provided so you can order your own PCBs.
Commercial thread for Kubelik is here : Kubelik NOS DAC kits
Update, May 2020
Orders now are open for kits of PhiDAC hex - see details here: PhiDAC hex kits with pre-built filters
Build guide for the kit here : lingDAC - cost effective RBCD multibit DAC design
Update, April 2020
I've been spending a LOT of time at home the past few months, to while away the hours I decided to work on another update to PhiDAC. This new design in its first prototype form was named 'PhiDAC Quad' but is now 'PhiDAC Hex' and will hopefully be available in kit form during May. Its a two PCB design with a DAC-I/V board as the base and a passive filter board as a 'hat'. The key enhancements are that the passive filter is more complex to give better rejection of DAC imaging components and the analog stage has been upgraded by using opamps with external classA output stages. The filter 'hat' board will initially be supplied fully built and tested as the inductors and capacitors need to be close tolerance, checked with an LCR meter. Sound quality is I feel a significant step up over PhiDAC SE, in particular the higher frequencies are sweeter and there's more ambience/bloom.
The schematic can be found here : lingDAC - cost effective RBCD multibit DAC design
Update, October 2019
This thread was originally created to talk about lingDAC which is a stack of four 5*5cm PCBs comprising a multibit DAC based on two TDA1387s which is able to drive some moderate impedance headphones directly with up to 2VRMS output. The fourth (power supply) board isn't shown an an early picture nor in the earliest BOM, it was added during the course of the thread.
Prior to the establishment of the thread, a few 1st generation lingDACs (v1, the first generation having just 3 PCBs in the stack) were sent out to interested parties for listening reports.
LingDAC has at least one feature which make it a bit hard to DIY, especially for those with little experience. That being the filter requires fairly accurate inductors which necessitates an inductance meter being used to select 'good' ones from a batch. Or the filter's capacitors can be tweaked in value to match a slightly off-value inductor, this calls for simulation skills in Spice and a capacitance meter, again not really amenable to beginners. Because of this major drawback I decided to create a design more suitable as a starter DAC, this being called 'PhiDAC'. PhiDAC is introduced in post #126, December 2018 : lingDAC - cost effective RBCD multibit DAC design
PhiDAC has a much simpler single stage filter based on a large number of MLC inductors and only occupies a single PCB, 8*5cm. Instead of discrete transistors it uses AD8017 CFB opamps for its active circuitry. It calls for a single rail PSU of 9V-12V. This is a DAC rather than a DAC-AMP, its not designed to drive cans. PhiDAC was designed with components cheaply available on Taobao and hit a BOM cost just below $3 - some packs of ten kits were sold to interested builders.
The last design, PhiDAC SE rectifies this last weakness - its essentially the same circuitry as PhiDAC but using AD815s in place of AD8017s. The greater thermal capacity of AD815s means a much bigger physical package so the PCB size grew to 6*10cm and needs a single supply of 12-15V. The board doesn't contain the necessary electrolytic decouplers, they are mounted beneath on smaller auxiliary PCBs called 'pants' (opposite of 'hats'). PhiDAC SE hasn't had a complete release of all manufacturing information nor have I costed it but I'd guess it would come in around $5 with Taobao-sourced components. Here's a link to where I formally introduce it : lingDAC - cost effective RBCD multibit DAC design
Towards the end of the thread I'm doing experiments on using multiple paralleled DACs (given they're so cheap it seems an obvious route to explore) and eventually settle on a way to exploit them successfully - but the gory details of that journey will go into another thread. I'll include the link here when that thread's opened : Grossly parallel multibit DAC adventures
Original post, July 2018
I've been working on DAC designs using TDA1387 for several years now, both in helping modify existing designs and coming up with my own solutions.
'lingDAC' has satisfied me in listening to such an extent that I feel its worth sharing the whole design here as I feel I'm close to reaching the end of the road with what's possible when beginning with the TDA1387 (famous last words!).
A few bullet points to introduce this DAC :
  1. designed for Red Book CD source material hence 16bits and 44k1
  2. no-oversampling design means no digital filter is used
  3. a steep analog filter is used instead of the digital filter to kill images
  4. the design is aimed at reaching the best SQ, not best measurements
  5. lowest possible BOM cost commensurate with still sounding good
  6. designed as a board stack for maximum DIY flexibility, boards are 5*5cm
I need to tidy up the schematics before posting them, I'll add them to this post as they're rendered presentable.
Returning later I see I'm told I'm unable to add attachments to this post so guess new info will go into subsequent posts.
@kokoriantz has collected together pdfs of schematics - for lingDAC here (3 boards) : lingDAC - cost effective RBCD multibit DAC design and for PhiDAC (single board), here : lingDAC - cost effective RBCD multibit DAC design
Here are the three boards required to build a lingDAC - from the left the DAC, filter-I/V and buffer stages. A fourth board for power supply is in the works, the aim being to be able to run from a very cheap USB 5V wallwart. For now the first two boards need a 9V supply and the third, 7V.
I was very fortunate as Abraxalito sent me one of his first lingDACs a couple of months ago.
I have been slow to try it out (Sorry Abrax), but am getting close now. Real life and laziness have slowed progress :/
I received the three main boards, and have put together a power supply using three lifepo4 batteries. Power supply is about 90% finished, just need to actually hook up the batteries to it now, but it does have three working 3.3V regs.
So PS will output 10V, and then Abrax included diodes on my power input to drop it down to around 8V to power the three boards.
Lately have been making some changes to my digital playback system which has a soekris r2r dac, the original 1021 with a bunch of mods mostly related to power.
Been spending some time listening to it as my baseline.
Hoping to hook up the lingDAC this weekend, then will let it break in some and then compare to my soekris.
Randy
Very fortunate to have received one the first version three tier boards with SE output a while back, and also only recently had time to give the boards a quick try. Yes feeling very guilty about getting around to this after a few months - humble apologies Abrax.
Have been putting together a battery supply using Lipo with regulators when time permits between daily grind of course.
For the first 'armature' effort, read ''could no longer wait', I used two Lipo in series which gave me between 7.98 and settling at 7.54 volts for a quick whirl.
The sound quality did not seem to degrade between the two voltages.
What is the typical 'negative' effect to expect when the DAC is supplied at the lower threshold of the 8v (+/- 0,5v) 120ma?
Perhaps I should read a bit more - sorry if this a naive question!
Going below 7.5V what will happen is the transistor doing the supply regulation won't regulate any more. Whether anything is audible I don't know, haven't done tests.
Incidentally just a quick mention that the lingDAC picture I put up in post #3 is an updated version (v2) of the design, based on some feedback from you guys and doing my own listening. The five of you who've already got lingDACs have the v1. The biggest change is to the DAC board itself where I've reduced the number of DAC chips down to two and implemented a low-noise, low impedance shunt regulator. The shunt reg makes a substantial improvement to the bass, its by no means subtle.
v2 DAC board schematic added
  • DAC board.pdf
Richard, what is the intended function of LED5 through LED8, which are attached parallel to the analog outputs of inverted data DAC U8?
-Ken
Hi Ken - good question.
The aim there is to give the 'passive' DAC as close as possible the same voltage on its outputs as the active one. In the basic configuration only one DAC's outputs are taken to the I/V stage, the other DAC is there solely as a 'dummy' to balance out the current drawn by the active DAC (the current draw being signal dependent). I figured to get the best cancellation it might be best to give both DACs the same output voltage, but I've not actually gone and verified this.
With the original v1 lingDAC the outputs were held at +4.5V by the I/V stage, this necessitated two green LEDs in series (2.2V each) to get to the desired voltage. On v2 lingDAC the I/V stage holds the output around +1.1V - this needs a single IR LED, the other LED footprint will be fitted with a 0R link.
Can the v1 be modded to a v2?
I'll compare schematics myself, and see how much difference there is.
Randy
v1 can be modded to v2 in the sense that the shunt reg can be used to power the DAC chips on v1. Bear in mind that you'll have 4 or 8 chips (can't recall exactly who got which variants of v1, some have 4, some 8 chips) to power so the quiescent current of the shunt needs increasing by a substantial amount. v2 runs with around 40mA through Q6 for 2 DACs, so I'd suggest of the order of 55mA for 4 DACs and 80mA for 8.
Looking at the schematic, probably more than I want to hack in, so I'll likely build a v2 at some point, at least of the DAC board.
