Biamplication?Yeah, just like that.
Too bad mine are monoblocks.
What Vince said.
Also, these words of wisdom from the Mighty ZM:
http://www.diyaudio.com/forums/pass-labs/281520-official-m2-schematic-176.html#post4969758
Get back to work!
I will do my best
What Vince said.
Damn, now i need bigger house
Fantastic Frank. Very Elegant.I haven’t had too much time and progress is slow, but this is what I have done since last time with my MoFo with a twist. I still need to mount the switch mode supplyes.
I got the transformers, boards and mosfets from Frank. Mine is not as elegant, but I have heard it play I unfortunately had to go abroad for some weeks, so thorough listening will be later..
A nice thing about this is that it does the amplification so no need for a special preamplifier..
I have an existing chassis with a Firstwatt type power supply,+/- 23 volts.Would it be possible to run one channel off the + supply and use a complement p ch mosfet run off the - supply for the other channel? I know there are no IRFP250 complements out there (to my knowledge), maybe parallel IRFP240's and their complements? I know,I know---don't be a cheapskate,its just an idea.
Donut - is it 36Vct , or twice 18V?
It is 2 separate 18V secondaries.I'm using a DIY store power supply board so I can pull the common ground jumper.
do exactly that ........then having two independent supplies
Thank you!
- Build This MoFo!
