There will be hopefully another letter in one month
Interesting Stammheim! 🙂 Would that letter be an X? I would personally love to see a 10A version! 😉
Hi Cornan,
I admit, I had to smile reading that.
But I asked myself what kind of application you have to power with 0-15V / 10A?
Best regards
Stammheim
Best regards
Stammheim
I just wanted to find out, if anybody's reading, what is published 😉
Many thanks, it's corrected!
Hi Cornan,
Best regards
Stammheim
I would still use it for my Brooklyn DAC requiring just around 1.5A. As I see it the more parallel LT3045 the marrier! 😀
Micael
Hi Cornan,
I can power the motherboard of my HTPC that's running Roon core with 12V 5 and 3.3V at 10A.
A hint for people interested in getting the HPULN's:
You can subscribe the newsletter to get a 5% off for your next purchase.
No worries about annoying advertisement, there shall only few interesting products be added into the portfolio in future 😉
Best regards
Stammheim
Best regards
Stammheim
Hi there,
there was a mistake in my webshop MPAudio | Highend for Audio applications regarding pricing, which is now corrected!
All prices are valid for all orders, not depending on the country you order from. In case taxes have to be paid, it is included, covered by MPAudio and will correctly be shown within the invoice!
Many thanks to people pointing that out! It took a few days to adapt the webshop...
Affected people got back the too much paid money back, of course 😉
Best regards
Stammheim
Best regards
Stammheim
I have replaced a MS-HPULN PS (single rail with 6* LT3045, max 3A) with the larger model PS with max 5A.
The replaced PS is used about 3 months and in mint condition.
Pm me if you are interested.
Hi Cornan,
I'm just a recent visitor to these pages and was wondering if you could direct me to information about the "often mentioned" balanced power or could add a circuit of both this and your power supply arrangements - it seems as tho you're are using multiple regulators in series with different current ratings, etc - rather puzzling about how the floating ground points are all connected
Hi Cornan,
Few words but many questions. Difficult to direct you to any info since I have’nt saved nor built the balanced ac-ac ps myself. I have bought it ready made. The thing with balanced transformers is that they cancel all the noise by design. The thing with floating ground is that the transformer will get isolated from the AC mains. That is done by connecting the safety ground IEC input directly to the chassi. Not passing it through to the output.
The dual LT3045 in parallel have a reason. The more parallel LT3045 the better ripple rejection and series seems to boost that performance. IME it does’nt matter if you have a 1A in front of a 5A. It improves in series as well as long as the powered device does’nt require more than 1A.
I would love to try a 10A or even 20A LT3045 in series for a 1A current device just because the total amount of current in parallel AND series matters big time.
Balanced. I do not know how much you already know about it? It requires two toroidal transformers. Two 230-2x 6VAC transformers or one 230-230VAC to 230-2x 6VAC transformer. It will in theory cancel out all of the transformer artifacts.
In my case the AC mains Wall outlets is 2-Pole followed by a DC blocker trap filter into a balanced isolation transformer with a star-earthed grounding point into a star-earthed and starquad wired power distibutor.
Thanks Cornan for your clear reply
Aah, the mains balanced system using a centre tap connection of the secondary winding of a 230:230 isolation transformer to connect to a separate ground, to give a '+/- 115' volt (ac) as the new mains input power - got it, thanks. (I assume I did get it right?!)
I wonder if this new balanced power mains would need a separate dc blocking trap for each of the ac input lines if the isolation transformer is feeding a number of other linear power supply transformers?
I assume this 'new central ground' is the focus of the systems other components ground (star-earth ground system) connections - I wondered about this.
It's quite intriguing to see that computer audio/digital components respond to multiple series regulators to produce an increase in the 'downward dynamics' that Allan Wright wrote about (or just better sound)
I do sometimes wonder what people must have coming through the wall as a mains supply. If there's little/no measured DC offset on your mains supply then a balanced mains transformer is moot. Far better to add a couple of common mode chokes after the secondaries and a DC blocker beforehand if particularly plagued by asymmetry on the incoming mains.
Question. Have you tried both options? Balanced rules my world, but I would not mind if someone that have tried both ways convinced me to choose the common mode choke path. I am rather convinced that no filters and no chokes is what I want so I’ll need to be convinced quite hard I’ll guess! 😀
After an immense trial and error with DC cables back at CA I remain with a question that I hope someone here are able to answer?
ISO Regen performance Improvement Cheap! - Page 31 - General Forum - Computer Audiophile
It would make my life as a experimental cable tester much easier! 😀
I found a large balanced mains transformer 3000VA provided no benefit on on powers, dac, phono or pre, or even on all of them.
Common mode chokes on my phono psu, pre rectifiers were clearly audible as beneficial
I have found that large transformers are not the way to go. Smaller transformers in a balanced configuration is way better than big ones in unbalanced mode. It will relief the transformer from heavier duties and cause less transformer artifacts.
That’s it? No reasons why common mode chokes are better than balanced transformers? 🙁
- Vendor's Bazaar
- FS: „Ultra Low Noise“ Power Supply, LT3045 based PCB’s
