Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Thanks for the info Juntuin 🙂
I was not prepared to have such a productive informative learning session from everyone today! The weather is beautiful outside today and I’m inside on a device reading and messaging......EXACTLY what I yell at my kids for😀
Indeed, some intensive reading, learning and building today 😀
Go and grab some fresh air!
Can someone confirm that will I destroy something lifting whole amp's ground? As stated, lifting signal ground didn't provide any help for me, don't know why.
Hi Danny, just edited my post 🙂 at first I tried to lift signal ground only with 10r, it did not had any effect! That's why I was so surprised when lifting speaker return also helped.
That's probably because the shunt feedback(c111,c115) is still not lifted and connected to PS ground.
For a proper signal lift the input signal and the shunt feedback need to be lifted, local PS decoupling and speaker return should not be lifted.
See the schematic of the BB.
Here it's lousy weather 🙁
Danny
By the way, ALL should look the power inlet at AV Receivers.
An example:
[URL="https://www.pioneerelectronics.com/StaticFiles/Custom%20Install/Detailed%20Product%20Information/AV%20Receivers/SC-65_Back.jpg"]https://www.pioneerelectronics.com/StaticFiles/Custom%20Install/Detailed%20Product%20Information/AV%20Receivers/SC-65_Back.jpg[/URL]
Off course, the ALPHA should have a [B]star ground[/B] [I](circuits -> case)[/I].[/QUOTE]
Please have a look at CLASS I & CLASS II electrical equipments.
Your example is a CLASS II, look at the symbol.
Danny
I'm master editor 😀 so just edited previous post also.
What possible negative effects I might suffer for lifting whole amp? It's quiet now atleast, and sounds very nice and powerful. It seems that proper grounding would need some serious work to be done.
Now it’s time to crank the volume and enjoy.
The ALPHA20 totally ROCKS!!!!!
:cheers::cheers:
You are so right my friend 😀
Take beside the speaker return also the decoupling cap C103 gnd outside the signal gnd lift,
then you really have a signal lift 🙂
I did a simulation with speaker return inside signal ground lift and it looks very bad: distortion up with 50db and clipping starts already at 10v peak
To finnish
Marantz PM8006
inside
[URL]https://audio.com.pl/i/images/9/1/6/dz0xMjAwJmg9MTA1OQ==_src_49916-wzmacniacz-marantz-pm8006-audiocompl-fot7.jpg[/URL]
[B]Rotel A14[/B] inside
[IMG] [url]https://audio.com.pl/i/images/9/9/7/dz0xMjAwJmg9OTA4_src_49997-wzmacniacz_rotel-a14_audiocompl_fot9.jpg[/url][URL="https://audio.com.pl/testy/stereo/wzmacniacze-stereo/2914-rotel-a14"][/URL]
Does anyone know how [B]double insulation[/B] has been implemented?
Thanks for a simulation. I think I'll leave C103 as it is for now and move only speaker return to other side of the 10r lift asap. Have to rework with frame later anyway, then I'll change that cap also 🙂
