Hi
just to keep the board in correct operation.
the drivers name is:
USB2.0 High-Speed True HD Audio
Hi
and Jplay is reporting :
Asio driver for C-Media USB DAc (64)
so i think its ok?
kr
chris
Where we cay buy 6631A?
my proposal to buy = with case !😉
Aliexpress.com : HIFI CM6631A Digitale schnittstelle 32/24Bit 192 Karat Soundkarte USB zu I2S/SPDIF Coaxial Ausgang Unterstutzung Connect Decoder Upgrade DAC von verlasslichen interface-Lieferanten auf Hi IC Store kaufen
Good Evening..
after burning approx 40 hours) in the board over RCA analog out to my amp i want to give you my impression -(compared to my gustard A20H):
this board is sounding well after the burn in phase, its terible until 15 aren´t left.
the sound is not squeezy and long listening is possible.the DAC ES9023P has a 2V output, so its fine to go in some line in of an amp directly...fine !
the bass is ok but somethimes in low bass its pushing to hard, for me its sound like the tone have to go out without sense to the others. 😛
mid and voices are fine and at the veyr end of the high i miss some coolness. so it is not stressy but at high hats its not really clear and the board is not give enough time to swing out.
The room is 1m meter on left and right side smaller and the deepness is not gooing far back....and sideway behind the speakers🙁
never the less this board cost about 27 euros so it is a fine little sounding DAC. lets hear after 100hours or more.😎
test over tidal (44.1khZ) - jplay - laptop- usb cable- DAC
titel -interpret-album
chilled cream - blank& jones - relax edition 4
armband - steffano Bollani - Gleda
Beat - Tingvall Trio - Beat (at CM66631A its sound strange -like L&R are changed or out of phase...i triple check the connection..... but ....no idea what here happend....😕?
Madrigal - Marialy Pacheco - Introducing
Don´t let me be missunderstood - Lyambiko - Saffronia special edition
Celestial Echo - Malia & Boris blank - Convergence
Movín - Gregory Porter - Liquit Spirit
chris
chris
Is it possible to buy just the CM6631 chip without a board in 10 or less quantities? I don't see it listed on Digikey or Mouser.
I'm in the process of designing a new receiver board for my setup. Right now I use the PCM2706C for USB input, but it looks like the CM6631 would allow for SPDIF input without needing a separate chip. Looking at the SDK it seems that it can be programmed to route the SPDIF in to I2S out when USB in isn't active.
They are on Aliexpress but there the purchase of the same chips can be risky, but who knows?Is it possible to buy just the CM6631 chip without a board in 10 or less quantities? I don't see it listed on Digikey or Mouser.
Hi
No it can not loop SPDIF IN to I2S Out. Because you can not choose SPDIF In as master clock. It will has data lose if you loop SPDIF In to I2S out.
hi Guys
what is your proposal to mod this board:
1 caps, which one and what should i choose
2 Voltage regulator is AMS1117 3.3V regulator with AP2114? which case is the correct one?
3 optical to sharp GP1FAV31RK0F
optical is not existing in at my board and i do not use optical
4 is it possible to mod the es9023P with something?
thx
chris
thx
chris
Hi tdtsai:
Thank you for providing lots of information.
I will try implementing firmware based on these.
Best regarts.
Best regarts.
It's the same dimension as Amanero 🙂
The UAC class is selectable and it can support following sampling rates:
UAC 2.0:
UAC 1.0:
The last one is supported even on Windows XP without any additional drivers.
Here is my version CM6631A 🙂
Design based on small 4 layer pcb.
On the board we have voltage regulator ADM7150 x2,
Crystek Oscillators CCHD-957 45/49MHz and isolator NVE IL715
Firmware compiled from scratch using tdtsai's SDK.
Works like a charm on linux, W7 -W10
It can play PCM up to 768kHz (in downsample/2 mode) and DSD DoP DSD64 and DSD128.
Thank You tdtsai!
I have few pcbs for this project.
Thank You tdtsai!
Thank You tdtsai!
Bought one of this board from China but it can only transport PCM not DoP in DSD, makes it no sense, would rather to use I2S directly for flac and dsd native.
What can be wrong? Firmware? Does anybody has experience on this with dop play?
UAC 2.0:
UAC 1.0:
This is good. The first time I saw such implementation. Hope other interface designers consider such feature. I was struggling with Amanero on FreeBSD because buggy UAC2.0 implementation. I was asked Amanero developer to add support for UAC1.0, just like this board. Don't know what is the current situation anyway.
Thank You tdtsai!
Is this this your PCB+firmware design from scratch? In case you did only firmware, where did you get a completed board?
I use the CM6631A to send DSD-DoP to another IC for DoP to DSD decoding. The CM6631A transfers data bit-perfect, so DoP is preserved. What are you using as DoP decoder?
Pls note the CM-6631A cannot decode DoP as opposed to XMOS which can detect DoP and decode it to DSD interface.
My Amanero isn't fully compatible with UAC 2.0 either. I believe they did fix it in newest versions though.
The DAC chip i used on this one is ES9018K2M which is DSD capable.
USB => CM6631-A => ES9018K2M via I2S
It sounds like I am missing something in between from your post? correct?
Look at the documentation and check if the DoP is supported by ES9018K2M, in my opinion not...
See the comparision ES9018K2M and ES9038pro.
The ES9018K2M is not capable of decoding DoP. It needs "real" DSD to make sound (or PCM of course).
I thought a month ago, but it actually does.
Had a amernero to es9028q2m also own a xmos xu208 to es9038q2m by using the same pin layout, read an article and it says 9018k2m is capable too, give that a try by hooking the cable to Xmos surprislly is does work on DoP.
Have another set of 9038 in, will try that will cm6631 to confirm, or will email to ESS to get a for sure answer
- Digital Line Level
- CM6631 USB audio interface ... any good?
