Power Amplifier LJM L20SE
I bought one on aliexpress and also tried to solve the puzzle. What I found is identical except for one detail: I can't find the 33k resistor between VEE and the base of the 2N5401pre-driver: your schematic counts 29 resistors, the actual board only 28. (at least, the version I received).
There is a resistor much to small, pulls the input stage out of balance.
Mona
I think its a perfect amplifier ,can outperform commercial ones of many 1000 .Of course needs coupling input capacitor ,adjustable bias current at 25ma per transistor and nothing else.At 35-0-35 AC don't need to change the value of 150 Ω resistor ,maybe at higher power supply.
I had a quick look at the circuit.
* What is the phase and gain margin?
* Where is the short circuit protection?
* HDS662 has to temperature compensate 6 VBE's
* current source with 270 Ohm resistor and 2N5401 will not be stable with severe ambient temperature changes!
* where is the offset-null trimming?
* where is the quiescent current trimming?
* 1n4004 are not very fast diodes for freewheeling transients!
* 1mF capacitor in the feedback path ?
I'm sorry
🙁 You are correct, this resistor does not exist, there are only 28 resistors.
Images
