@alex mm
OK. I can give you my personal email. 🙂
@junior35
Bottom of PCB. 🙂
I think junior meant bottom copper layer in B/W in pdf format for etching.
Thank you for clarifying
Technical specifications of SX9
Can you please post the technicla details such as:
Max power/input impedance/THD/IMD/ slew rate etc. ?
Thanks and regards,
Sumesh
Thanks and regards,
Sumesh
A new version of APEX SX9.
Thanks to Dragan100!
Is it really good idea to put the output coil so close to the input connector?
Sajti
Sajti
Opps very bad idea
the output bobbin must be away from the input connector.
Thanks and regards,
Sumesh
New version:
THD 0,05%@1Wrms@8R0@1KHz
THD @100Wrms@8R0@1KHz = cca 0,1%, PSU +/-45VDC
SlewRate cca 50V/usec
Bandwith 2Hz-520KHz (-3dB)
SNR cca 106dB
Final version.
Shouldn't the drivers be on the main heatsink?
Your PCB also has different components than Mr. Apex's schematic. Did you make modifications to it? If so then it would be a good idea to post the updated schematic as well.
NoShouldn't the drivers be on the main heatsink?
There is 2 versions of AX9.Your PCB also has different components than Mr. Apex's schematic. Did you make modifications to it? If so then it would be a good idea to post the updated schematic as well.
First schematic in post #10156,PCB #10167http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-post5374014.htmlhttp://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-post5373747.html
and second (Dragan100 mod) schematic in post #10183,PCB #10191.
Hi to all
today finished my work Ax14
can you tell me if I set the correct bias?
measured on the resistance of 0.22 ohm, 15mV
Hi to all
Mr. Mile,
Can this super simple softstart work for your high power amps? Like BX-22 and SR 200 etc?
Very few components.
Ckt is from TI app note
http://www.ti.com/lit/an/snaa057b/snaa057b.pdf
Layout has 100mil cl for high voltage traces.
regards
Prasi
regards
Prasi
Mr. Mile,
regards
Prasi
Yes, but there is simplier soft start circuit from B500 thread. Use zener diode instead resistor for sharp switch.
Its indeed simpler!😀
Thanks Mr. Mile.
regards
Prasi
- 100W Ultimate Fidelity Amplifier
