Pure Tube i/V for ES9038PRO-9028, 9018, AKM...
Hello QH, can you tell me if this is correct and if it is correct that means those resistors have to be mount on top of the surface components.
Hello QH, thanks for replay but in post #72 I asked about those resistors and you said not to used them because they are in parallel with R i/v , but in a recent post said need to use 100k resistor and in pure I/V right channel I have to change them from 47k to 100k, just a little confuse here, please advise. thanks
Hi!
All the sample image 1 . You see good !
R I/V at all input . (27 ohm)
Hello QH, thanks for asking, almost just waiting for two more transformer ( need 4 transformer to converted from 220 to 115). Is a challenge because chassis mod but I will finished it. I'm getting a wonderful help from Algar (Sylvain), he did the same to this Dac but he has a ton more experience in electronics than me, again thanks a lot to him. But I have more questions about some components, if you do not mind to ask you. Thanks
