V6 amplifier
Another version is on the way, use KSC1845/KSA992 in the input stage...
Sajti
The latest version is ready, and running since 2 days. 60W/8ohms and 110W/4ohms, dual mono.
Bias was set to 70mAfor each output devices, 77mA on the cold amplifier, falls down to 68mA after some hard running. Output offset is 25mV when the relays turn on, reducing to 5mV in 30 seconds, and finally down to 1-2mV after 5 minutes.
2x200VA toroidal tansformer, 2x40000uF in the PSU. Sanken output devices, Sanken drivers, Toshiba and Fairchild in the front end.
Sajti
