V6 amplifier
PCB with resistors only. I use mainly DALE RN series, and some Takmans in the feedback network.
Finally finished:
Dual mono PSU, with 250VA toroidal transformers, and 40000uF on each side.
+/-42V PSU, 70W/8ohm, 120W/4ohm output power.
Separated small psu for the protection. 2sec turn on delay, DC protection over +/-1,5V, and overheat shut down at 90degree.
Sajti
New version was born in the last weekend. New semiconductors in the front end, reduced loop gain, different value in the compensation, new solution for DC offset settings. New location for the trimmers for easy access, and settings.
Sajti
