hi quanghao
do you have the transformer information"voltage and rating" for HV supply board and for filament?
i cant find from the part list.
and how can i switch balanced and unbalanced output? i need to update the firmware?
or just connect to control board?
Hi chi0001!
This information for Transformer for balance Pure I/V tube
Yes only connect to Control board, i will sent up date later!
thanks
thanks
Thanks Quanghao , I got the boards.
All Ok for you now? Please let me know,
Thanks and try to make it , it is best sound off Dac.
Hi chi0001!
thanks
do you have this transformer for sell?
this : Hq9038 Transformer
and shipping 50$ to your country!
thanks
total 200 right?
Thanks QH, is ok but I have some questions because started looking for parts and in the part list you describe the audio note resistor like been 560R and 470R , is confuse which one to choose, can you explain this.
2) I do not see the value of these resistors R31 , R32, R10 and R9 on the part list neither the schematics.
3) Also you have to sets of cap Nichicon and Murdorf 100uf/ 450v , I think your trying to say we can choose either one of these sets, because they have the same cap#, then I ordered the 2 sets by mistake . I think if you put a note saying we can choose either one but not the two is going to save some bucks to newbies like me.
So Can you please update the part list so we are more confident to by the parts. Thanks
Hi JPDuarte;5368592
Ok please use 560R. thanks
it parallel with R i/V, so you not need use them ( only use R= 27R )
yes, all Cap with voltage you can use from 350V min.
EX: NICHICON-76195 100uF / 450VDC, KX Series
link: Nichicon KX Series Electrolytic Caps
thanks
thanks
Hi QH, sorry but I have some more questions, in the PI3 supply schematic I see some resistor and caps that I don't know where they go on PCB and you also have one resistor for the relay R47 that is listed on schematic 47K and on the part list is 33k, which one is the correct one. Sorry I just need to be sure that all the components are right in case I have to troubleshooting. Thanks
paid by paypal, please check.
Ok . I got it!
I will ship some day!
Thanks QH, I did read it, that's why I'm asking because you wrote down the part list too, right? Then by your response I have to believe schematic have the correct numbers.Started to populate the boards and I want to be sure they are fine. Thanks
- Group Buys
- Pure Tube i/V for ES9038PRO-9028, 9018, AKM...
