High voltage power supply module
I was planning to build standard PSU with chokes and RC filters but changing the voltage is a pain. Does anyone can recommend a quality plate voltage power supply ready made or a kit for SE power amp with at least 300-320V and 60-70mA or more, preferably in Europe? Soft start, good PSRR, stabilized, low output impedance etc... I was looking on eBay but found only with low current for preamps.
i think this design may be you can use!
low noise, low z-out, the sound is good!
thank your advice!
quanghao
I am currently assembling the nuts and bolts to a 60W dissipation power supply for stereo.
So far the amp power supply has 1x 3 poles relays for the mains power (neutral and live) and for shunting the power supply output in case of tube failure or lack of conductivity to prevent dissipation, one for caps charging 'soft' start, one to cut power supply if the bias exceeds 3x value, 1 for shutting the bias monitoring circuit.
So instead of fusing each 4 anodes, I fuse the main transformer output and the regulated supply just before regulation.
The main idea with the bias monitoring and leds signals is to ensure bias within 2mA to use a toroidal transformer for approx. 50watts, UL with cathode feedback.
Thank you Dieter.
I have created simulation of the schematics provided by Quanghao. The ripple rejection is impressive, especially with IRF840, they are great as a source follower, much better than STP5NK50Z I was using before. I have designed PCB and now I'm waiting for the boards :)
My only concerns is that it uses feedback and I am not sure how it can impact the sound.
Alternatively I will use this:
Hi Jerry Long,
I haven't finished PSU designed by quanghao and this is actually question for him, however on the simulation I checked 100mA and it was working great. I needed 300V output and I noticed that best results I got when input was 400V DC.
The second schematics also works fine at 100mA, but you need a heatsink for the mosfet. By changing CCS current (R13) you can regulate output voltage. This doesn't use feedback and the output impedance is higher. Hope that helps.
I thought Jfet css will be good for my need, since you have made it into PCB;)
I think the best person to help is Quanghao. You can try to send PM to him.
IMO there is not a lot of things to change, by changing the value of VR1 you can adjust the output voltage. You need to make sure the heatsink for Q2 is big enough, depending on the voltage drop between mosfet drain and source, and also the output current (Ohm law will help), something like 5-8 K/W should be fine, just keep it below 60-70 Celsius degree. Also R3 needs to have enough power rating depending on the output current, you might need to decrease the value of it if the output current is higher.
My PCB suits transformer with tapped winding in the center, so there are two rectifiers not four like in the Graetz bridge.
