Hi
just mounted the Salas supply to the preamp
it give me hum...tried my other supply no hum
voltage is ok around 17.3vdc
music is fine
i can measure more ac volt on the output of the pre,,than i have on my other supply (mv ac)
grounding same as with my other supply
music is fine
Different supplies may have different PCB zero paths needing another grounding scheme. Post a picture of the build to see about wiring and grounding.
problem to take picture,,no working camera
have tried different grounding,,
ground from pre to rca output
no ground from Salas supply
in same boks are supply to dac and to waveio board
tried with an without ground from supplyes no different
hum is same on both channel
is nearly the same with low and high volume
Maybe try with a mobile phone? A picture would really help. Same buzz with low and high volume hints to a ground loop has been created within the various systems in the combo box. Also measure AC mV on the PSU rails to make sure its not an oscillation either.
I also have an idea about separating the ground lane on the preamp board between channels. But it will need a cut with a hobby knife. So we better see the build and catch something incompatible with the wiring first if it exists.
Hi Salas
you have right with taking a picture ---but your idea to thing in other grounding solve the problem..totally noise free
it was my Sowter trafo from output of my dac,,they were grounded to the start point..i tried to remove the wire and that help..i think the problem with them was .they are not isolated from the kabinet
thanks Salas to help me on the right track
now i am waiting for my to trafoes from Poland. so i can mount the hole thing in a fine way
Great! Problem solved just by an answer triggering a correct thinking path
Let it run with music or not for some hours just for the new capacitors to come up. Then let me know if a change happened in some meaningful way to your system between the σ22 and this?
yes Salas always great with good idea
i can already now hear a difference to my AMB supply,,little to early to tell what i hear..must first give the supply some hours to play..
Keremito:::you can have right what you say about the bass from the pre with the Salas supply
it is early in the start of the supply and pre for you but i can hear that the bass (compared to my AMB supply) is so strong and not so round ,,it can sound like the bass is not there
but,,,this is some of the best bass heard in my system,,fast dry dynamik
i think you will discover that the sound settle a little down in the top when you have play some more hours on this pre
If there is no practical error involved in Keremito's and its only down to quality of bass maybe repositioning his speakers could be also considered as a test. A standard DCG3+DCSTB build presents bass through speakers more like planar headphones do. No bloat is there in the phrasing and suddenly it can slam like a garage door startling you. I would still recommend to him good quality short coaxial wiring though because its 1MHz capable preamp and RFI could go into it when simply using CAT-5 thinning its tone out.
can DCb3 be powered with salas bib? if so will the sound signature like bass slam will be same as DCSTB? I believe it might be better with even lower psu impedance? or will it be same?
Thank you Salas. Here are the measurements:
Resistor values while on the board: Left/Right
R12: 1mohms/1mohms
R13: 0.585 mohms/0.585 mohms
R14: 10 kohms/10 kohms
R15: 50 ohnms/50 ohnms
Q1 collector: 12.66/12.74 Volts
Q2 collector: 16.58/16.61 Volts
J3 drain: 400 mV/275 mV
J3 Vgs: 1.014/1.003 Volts
I think all is good, I removed the CAT6 wires used 18 ga shielded for the inputs, changed the volume pot to regular fit now while the Goldpoint arrives. With new cheapo pot get loud with less rotation. Old was 20k, the one in use is 50k. I ordered 25k, hopefully it will be ok.
I also put the preamp on the scope, all good consistent gain of 3 20-100 Hz.
The system is very resolving, I have 2 sources, one being a Sony HAP-Z1ES, with it some recordings are on the bright side. Plenty of detail, good sound stage. Not so good recordings just sound like that.
R12: 1mohms/1mohms
I am happy to report that bass is back. I think that the volume attenuator was the culprit, it measures well through all the rotation tracking was very good, perhaps I had it miswired, who knows it's out now. I am waiting for a new high-grade pot. I will report what becomes of the DCG3 with a high grade attenuator. Thanks to all for the help! I am smiling again!😀
Congratulations!!!
Tarnished switch pot contacts most probably. The 25k Goldpoint you expect has no harsh or thin traits. It also opens up volume in slower fashion than most 21-24 step switchers. Even if you will need more output impedance from it so to round off your sound further we can always up R1. No worries.
I had listened to the first beta tester's two realizations with a mono BiB for both channels and they were generally fine. For subjective details between using those PSUs its precarious to say much because I had listened with them in different builds. It takes to have two double mono DCG3 preamps with BiB/DCSTB using exactly the same parts everywhere from trafos, diodes, reservoir capacitors types, down to same volume pots, resistors, and wiring/grounding scheme, to truly can sit down and compare in strict A/B fashion.
Just because its a revealing hard driving preamp with gain and much line output current capability, I designed and tested the fixed parts and fixed voltage DCSTB along with it to secure an author tested easy solution that plays well together. For you guys to can start confidently by avoiding speculation, too much heat build up, more external sinking, or potential for setup and stability errors with general duty variable PSU tryouts depending on type. If already in hand from previous projects its painless to try them. But sometimes they can be costly enough new experiments to risk subjective disappointment especially when investing in double mono.
From there on you may experiment according to your curiosity. The preamp's electrical needs are not weird demanding only one certain PSU. Beardman for instance applied three different PSUs already during his saga to fit the sound hand in glove for a particular system. Two highly respected third party ones from the kits/modules market and the DCSTB.
Most valuable subjective finding in this thread is have patience. If your build does not mix and match perfectly well within an existing setup on first shot don't despair. Leave it powered on for some hours, play again to make sure of your goals, and start trying things. Its worth the effort as it proved again and again. New bold gear can be upsetting an existing system's balance sometimes or there is an influential internal part to better manipulate or fix.
Keep it at +/-17V. There is a three Leds drop to the relay calculated for giving it 12V on nominal rails (that can be changed to less Leds if the preamp MUST be used with lower voltages if the HP output max power does not matter to you). But the capacitive parasitics of the Mosfets are better on the higher voltage rails so the THD and the speed aspects fare better.
R12: 1mohms/1mohms
Those are healthy results and you also stated that after changing a dubious volume pot the bass feels normal again. This build behaves and reacts well then.
There is no basic assembly error indication. But I forgot to ask you the DC mV across R3 also. Let me know those R3 voltage drops when its handy to measure.
Most all items are delivered now (except the final heatsink).
I was so impatient that I bought heatsink (not really the right one) in a local store because I wanted to test my build.
Everything works, offset is fine and the DCG3 sounds good. I just have to test a little bit more and decide wether I should increase the gain about 6db. Could be a little bit more of power for my DT1990 Pro.
Things working good. The gain decision also goes hand in hand with your audio source's output level of course.
My source is a soekris dam1021 using the raw output, controlled by audiozen OLED Kit. Due to the kit output ist limited to 0db. When using the soekris normal pot +10 db are possible.
I‘ll try 1.5k for R6 to get 4x gain or is 2.2k possible to get 5x gain without clipping in frontend of DCG3?
Regarding the Soekris' analog output, you'd better plan your gain structure assuming that it outputs 1V RMS, since a bunch of the better custom filters include some volume reduction to protect against inter-sample peaks that might result in clipping.
Also, that +10db output option is practically useless since we're talking about digital gain. The resistor ladder is limited to outputting 1.4V RMS max (~1V RMS with the better filters).
Your DT1990Pro will be at 120dB SPL with 3.97Vrms by the way. I just checked using 102dB/mW sensitivity and 250 Ohm impedance as claimed by Beyer. Translates to 63mW power draw by the headphone.
So use gain X4 for Soekris as a source. Thus R6=1.5K.
Changed R6 to 1.5k. Now it's perfect, there's enough headroom upwards now.
How is it going in the meantime? Did you let it rest waiting to be boxed or you clocked some further music replay time with it?
Hello Salas, thank you forr all the advice, the pre is sounding excellent. Goldpoint pot arrives today. We'll see how that works out.
The voltages across R3 are 1.014/1.003 Volts.
Thank you again.
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
