I like that too ... 🙂
Little more ...
Little more ...
Joined 2009
An externally hosted image should be here but it was not working when we last tested it.An externally hosted image should be here but it was not working when we last tested it.
Inexpensive gear for you then?
Joined 2009
Joined 2009
Either my Thorens TD160 with a Denon DL-110, through the modified phono
stage in my HH Scott LK-72
Or, My RP6 with a Benz Micro Gold, through a Creek Audio OBH-15 MkII, into the aux on the LK-72
My last customization, currently listening music from him:
Beautiful Cold Beer.
My one metre of Oak worktop.
The bottom layer is fabricated from the offcuts of the top two layers.
I skimmed the edges with my router end-mill stylee by clamping a couple of strips of wood either side to use as a refence edge, worked a treat but I had to enlarge the base of my router to span the gap.
Tung oil finish.
Tung oil finish.
Cold Beer, What TT did you start with? I really like the idea of multiple layers of BB ply - very dimensionally stable.
Thank you.
This is the original one:
stereonomono: Rotel RP-300
I love working with multiple layers, and to transform old stuff into something new. Here is one old Dual:
My turntable.
Fully maglev bearing lifting a 15 kilo platter.
Panzerholz plinth.
Maglev feet.
Panzerholz plinth.
Maglev feet.
Updated ... modified the plinth size, the motor pod housing and the pulley changed to solid copper ( instead of aluminium )
Arm modified to micrometer VTA adjustment.
You cant see them in the picture but changed the feet from maglev to points resting on sorbothane pads.
- Analogue Source
- Post your Analogue Source pics here
