Dallas II Build
View attachment Dallas2-plans-redraw-251215.pdf
Hi All - I started breaking down some Baltic Birch stock last night and drawing lines for a Dallas II build. I'll post pictures here as I progress - but I had two quick questions:
  • I noticed the plans shared on the forum were made for 1/2" stock, my baltic birch is 3/4" I don't especially want to start redrawing, how big a deal is that 1/4" internal dimension? Should I redo?
  • I have a track saw, table saw and sliding miter saw, so I think I'm good with the tools. The miter should easily handle the 11+ inch width for the angled cuts. EXCEPT that 12 degree cut on the 28 inch board. I'm trying to visualize the best way to do it, but the only way I can see is by standing that board up and hoping those 12 degrees clear my miter housing. Anyone else have any clever ideas? Chisel? Handsaw? Sandpaper?
Thanks!
frugal-phile™
Joined 2001
[*]I noticed the plans shared on the forum were made for 1/2" stock, my baltic birch is 3/4" I don't especially want to start redrawing, how big a deal is that 1/4" internal dimension? Should I redo?
Actually an omission in the plans you linked. I did a recently upgraded plan which indicates the material thickness is 18mm.
Do take a micrometer to your material. 18mm is often called ¾”. ¾” is 19.05mm and the extra 1mm will add up. But it can be anywhere from <18mm to >19mm. Plans need to be adjusted for the actual material thinkness.
The easiest fix might be to make the box 19.05/18 x as wide to maintain the path cross-section areas.
dave
  • plan-281217.pdf
Thanks Dave. The plywood is definitely stamped with cyrillic characters so I wouldn’t be surprised if it’s a metric thickness. I’ll double check tonight. So you’re saying that if the material is 18mm then I’m good with the existing plans? If not - I should modify height width and depth by 1mm?
Edit: Sorry. I’m a bit lost. 19mm thickness actually means I’m losing 2mm interior in each of the three dimensions right?
The 12 degree cut...you could make a sled with a tall fence, such as a 4x6, and clamp the panel to it. A bit of work for two cuts. Or a dado. Then there's the hand plane option, where you lay out the edges of the bevel and plane down to the lines. That would be a sharp hand plane. I like the #3 or 4 for these kinds of things. ChrisB knows how it's done...
I was thinking of the plane. I have a number 7. Not ideal but may work. Thanks!
I have built myself a pair more than a year ago, still enjoyign them as much as in the first day.
18mm all the way, it is a big difference if you use thicker stock. Under NO circumstances I would use thinner stock, as it will certainly be prone to resonances, sound colouring, etc...
The plans you shared, they are made for 18mm stock, you can do the math on the geormetry, and they are what I've used. If somebody is updating the plans (Planet10?) I do have a very efficient cutting arrangement, that allows reducing the material losses by quite a lot.
Thanks!
frugal-phile™
Joined 2001
Thanx.
Please forward it to me and i will add it to the plans. I have added the reference to 18mm, but need to go over the plans and see if there is anything else i can add to the plans before posting the update so the timing is ideal.
dave
Update and question
Hi all. So. Making progress on the build. I followed the plans here from Planet10 for measurements and applied them to the cutting plans also attached. Fairly easy. I broke it all down with a track saw and it all looks fairly accurate. The interior pieces will be cut down from a series of long pieces all the same width. 11 1/32”. In looking at the pieces I think track saws being what they are and my own human error - over the course of the long cuts I’m off by that 1/32” at times. Should I stick these things on the table saw and true them up or just not bother?
Thanks!
