NAP-140 Clone Amp Kit on eBay
Is C11 a bad idea?
[/IMG]
If you are going to have C10 you'd better have C11 too. But based on your circuit board photo I wouldn't add either. Just make sure you are using good quality PSU caps and your wire runs to the PCB are nice and tight.
A couple of easy changes that should make it sound better:
Use a polystyrene 56pF cap (next to Q4) instead of a ceramic.
Use a bipolar cap for C3 (or at least put the existing cap around the right way: + to gnd).
NOTE: Almost all the Naim power amp schematics I've seen on the web continue to have the feedback dc blocking cap the wrong way around. I have no idea who started this mistake but it seems to keep on going. Including in the schematics just pasted here. The +'ve terminal should go to gnd because the LTP base voltages will be slightly negative.
Joined 2010
the nap 90 is the same to nait 2,3 and probably the 5 ....
Yes, that's the Nait2 schematic that I referred to. There are some more drawings for the preamp section and power supply if needed, since it's an integrated amp. The power supply is +/- 30V for NAP90 and +/- 22V for the Nait2 so you need to adjust parts ratings and probably some resistor values that set bias currents in the front end such that they are correct for your actual supply voltages.
what cap ? :confused:
This is the first image I get when I search for "Naim schematic".
Both these caps are shown the wrong way around.
I've been looking at that decoupling mod for the Nap140 too and have gotten me some low ESR Panasonics rated to 50v to test.
Is C11 a bad idea?
(The schematic is from the Acoustica mod list).
Don't run decoupling capacitor leads to a remote PSU Zero Volts.
Join the two decoupling caps together with the shortest possible leads and take the Speaker Return to that junction. Take the Amplifier Output Zobel to this same junction.
Finally run a wire from this junction back to the PSU Zero Volts inside the twisted triplet that brings power to the PCB.
I once met somebody from Naim, I think it was Paul Stevenson, or JV himself. I asked him about the cable trees within the amplifiers, and he told me a very nice story about the lady, who made the "trees" so neatly - she treated them as a piece of art, not electricity, just formal precision and pretty colors. They had some problems after she retired.
I further asked why the wires were not twisted, and he answered something like "not necessary because of low impedances".
But this happened now more than 30 years ago, and my memory might be fooling me.
NAP200 Clone up and running but a question
Hi guys,
nice forum.
I build a NAP200 clone. It is up and running.
But Iam afraid that something is wrong. The Transistors ZTX753 & ZTX653 are becoming "warm" I think they will reach a temperature of about 60°C.
Is this normal?
Is it possible that the AMP is oscillating?
Many thanks for you're help.
Best regards from Germany
