Vacuum Tube SPICE Models
In case if someone needs:
Code:
.subckt ABC1  P G K
   Bp  P K  I=(0.03461462647m)*uramp(V(P,K)*ln(1.0+(-0.09451114315)+exp((4.492501276)+(4.492501276)*((27.91471754)+(-293.1782318m)*V(G,K))*V(G,K)/sqrt((31.13718048)**2+(V(P,K)-(6.760356504))**2)))/(4.492501276))**(1.200237187)
   CGK G K 4.3p
   CGP G P 1.7p
   CPK P K 3.1p
.ends ABC1
Disabled Account
Joined 2013
Disabled Account
Joined 2013
I have created 6s28BV model. Hope I got the capacitance right -see attached
* 6s28bv LTSpice model
.subckt 6s28bv P G K
Bp P K I=(0.002601162511m)*uramp(V(P,K)*ln(1.0+(1.527218592)+exp((9.597585957)+(9.597585957)*((44.10205487)+(1219.438634m)*V(G,K))*V(G,K)/sqrt((45.94661787)**2+(V(P,K)-(-7.057968898))**2)))/(9.597585957))**(2.135670747)
CGK G K 6p
CGP G P 3.1p
CPK P K 7p
.ends 6s28bv
  • 6s28bv.inc.txt
Thanks Koonw.
Hey artosalo, would 6P18P be close enough to EL82 for you to use? Maybe you'll want to give it a try.
Code:
.SUBCKT 6P18P_P  1 2 3 4 ; P G1 C G2 (Pentode) 24-Dec-2006
+ PARAMS: MU= 14.95  EX= 1.350  KG1= 568.0  KP=37.41   KC= 150
+ KVB=  34.4  VCT=  0.00  RGI=1000
+ CCG=11.5P  CPG1=0.2P CCP=6P
RE1  7 0  1MEG
E1   7 0  VALUE=  ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LN(1+EXP((1/MU+V(2,3)/V(4,3))*KP))}
G1   1 3  VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*1.57*TANH(2*V(1,3)/(KVB*3.14159))}
G2   4 3  VALUE={STP(((EXP(EX*(LN((V(4,3)/MU)+V(2,3)))))/KC)-((PWR(V(7),EX)+PWRS(V(7),EX))/KG1*1.57*TANH(2*V(1,3)/(KVB*3.14159))))
+*(((EXP(EX*(LN((V(4,3)/MU)+V(2,3)))))/KC)-((PWR(V(7),EX)+PWRS(V(7),EX))/KG1*1.57*TANH(2*V(1,3)/(KVB*3.14159))))}
RCP  1 3  1G      ; FOR CONVERGENCE
C1   2 3  {CCG}   ; CATHODE-GRID 1
C2   1 2  {CPG1}  ; GRID 1-PLATE
C3   1 3  {CCP}   ; CATHODE-PLATE
R1   2 5  {RGI}   ; FOR GRID CURRENT
D3   5 3  DX      ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
I've attached a 6P18P datasheet. Interelectrode capacitances are in there.
  • 6P18P.pdf
Disabled Account
Joined 2013
Also try this EL82 pentode model use pentode and triode curve as input:
* Created on 02/13/2018 11:26 using paint_kip.jar
* Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively
* Plate Curves image file: el82.png
* Data source link: <plate curves URL>
.SUBCKT EL82 1 2 3 4 ; P G K G2
+ PARAMS: CCG=11P CGP=1P CCP=5.9P RGI=2000
+ MU=9.2 KG1=11601.3 KP=52.3 KVB=23.6 KVC=2.43 VCT=5.02 EX=2.1 KG2=34328.4
* Vp_MAX=400 Ip_MAX=250 Vg_step=2 Vg_start=0 Vg_count=21
* Rp=1600 Vg_ac=23.5 P_max=11 Vg_qui=-23.4 Vp_qui=240 UL=0.43 EG2=170
* X_MIN=69 Y_MIN=251 X_SIZE=869 Y_SIZE=548 FSZ_X=1942 FSZ_Y=1102 XYGrid=false
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=y harmonics=y
RE1 7 0 1G ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
+{V(4,3)/KP*LOG(1+EXP((1/MU+(VCT+V(2,3))/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
* Alexander Gurskii screen current, see audioXpress 2/2011
RE2 8 3 1G ; Dummy
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG2*(KVC-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0} ; Dummy
C2 1 2 {CGP} ; GRID 1-PLATE
.ENDS
  • EL82.inc.txt
Disabled Account
Joined 2013
hi, I need the ltspice model of the subminiature jan 6418 valve connected to a triode.
Triode curve is included in the datasheet. Noted the capacitance values are not listed.
Code:
* 6418T LTSpice model
.subckt 6148  P G K
    Bp  P K  I=(2.232751379m)*uramp(V(P,K)*ln(1.0+(-0.1251078596)+exp((9.293821508)+(9.293821508)*((7.752252766)+(-9.512594942m)*V(G,K))*V(G,K)/sqrt((2.911290527e-008)**2+(V(P,K)-(0.3137181941))**2)))/(9.293821508))**(1.896157386)
.ends 6418T
  • 6148T.inc.txt
Disabled Account
Joined 2013
Hi I am looking for LTspice model for 6S46G-V.
Tube data on: 6С46Г-В, Tube 6С46Г-В; Rohre 6С46Г-В ID43226, Double Triode
Triode curves in attach file
Code:
* 6S46G-V LTSpice model
.subckt 6S46G-V  P G K
    Bp  P K  I=(0.2734720428m)*uramp(V(P,K)*ln(1.0+(-0.03670114995)+exp((1.195695849)+(1.195695849)*((13.41579021)+(-192.3170616m)*V(G,K))*V(G,K)/sqrt((22.0885471)**2+(V(P,K)-(4.392866787))**2)))/(1.195695849))**(1.454315615)
    CGK G K 6.5p
    CGP G P 2.2p
    CPK P K 7.5p
.ends 6S46G-V
  • 6S46G-V.inc.txt
