What do you mean by "plays very loud"?
-Tim
I mean that it plays significantly louder than other inputs on the amp. without a SPL meter to give an accurate difference, the best I can do is say that on a scale of 1 to 10 when I play something on Moode on 2, it is the same loudness as any other input to the amp on 4. (
Hopefully that makes sense).
Before I could tame that by lowering the "Limit Maximum Output Percent" setting.
I have the same DAC (Hifiberry DAC+ Pro) and haven't observed any doubling (?) in perceived loudness. I wonder if there is something specific to your setup. Are you running balanced outputs? Do you hear any distortion or clipping?
For what it's worth Archimago has measured peak to peak output on the DAC+ Pro at about 2.1 Vrms which is par for the course for unbalanced line level audio gear.
You've suggested a driver issue -- Can you give some more details on that?
Richard
Hi Marek,
You prolly have a broken build. moOde 4 works perfectly on my Pi-0W.
-Tim
Hi Tim
That's what I hope is the case, as before it was always running perfectly on PiZero.
Will try again and see what happens (for now I'm back to 3.84 as I wanted the working player for tonight)
Introduction
Features
Sw versions
Licence issues reason no iso
Download url
Installation
Base system
Extras
Local Gui
WIFI
Testing
Known problem Faq
Hardware tips
Dac connections
Power supplies
Pi 3 specialities, (eg usb boot)
Local disks
Diet Pi system
Yes, a Wiki is ideal but it will need to be actively maintained or it will date very quickly -- always the Achilles heel in these kind of things. Perhaps it can be hosted on Github.
A couple of suggestions:
The reason for no image can probably be a short explanation folded into the download section as it would be most relevant there.
Do some of the things such as "base system" and "extras" = "setting up and using moOde"? Just trying to be more descriptive for less technically minded users.
Richard
Richard
A quick thought on this, might GooGooMuck's other devices all be lower than 2.1V out? Thereby having his new RPi DAC that is, end up louder at a particular percent of volume? Many consumer sources are 0.9V...
Bryce may add his LCD scripts....Bryce ?
I would have no problem with that.
Richard
Not running balanced inputs.
Not certain about the driver, but in the past there was a reason to set the output maximum to a lower value (81 if I remember correctly).
Hi Martin,
Optimal settings for Hifiberry DAC+ and DAC+Pro to compensate for clipping are:
(1) Menu, Configure, MPD: Volume control = "Hardware", APPLY
(2) Menu, Customize, Hardware volume control
(a) Logarithmic curve = "Yes"
(b) Maximum volume % = 81
These settings will yield a nice logarithmic curve and 0dB overall for the device at 100% volume level (Moode knob = 100).
Tim
This is where I was getting the settings from in the older version I was using.
Possible. I always thought CD players and tape decks has a 2V output at the RCA jacks.
Hifiberry fixed the +24dB volume clipping issue long time ago. Now 100% volume level in players = 0dB hardware volume as it should be.
Please post the output from System info and I'll have a look
-Tim
Oops, I believe I made a mistake in quoting Archimago's measurement: it isn't peak-to-peak but simply the peak measurement, so double it for peak-to-peak.
It appears to be standard for CD players to have a 2 Vrms output even it that is not the "standard" for line level.
CDP and DAC output levels
From the Chip Options screen in moOde for BB PCM chips:
Analog gain can be set to 0 dB (2-Vrms) or –6 dB (1-Vrms).
Analog gain boost can be set to 0 dB (normal amplitude) or .8 dB (10% boosted amplitude).
You can verify what your settings are by the cmd below
alsamixer
-Tim
alsamixer
-Tim
Hello Tim,
The last picture - which makes u concern- with q1, q2 ...etc was my different tried to mount the NAS with different f.ex,. user or different remote direct. Now I deleted all of them and u have clean one tried- example:
Don't make me bad, I really appreciate your work, a like moode v.m. but as I got all my music stored on NAS, I 'm unfortunately unable to use it the way I 'd like to.
Moodeaudio - Google Photos
br. Zefiryn
PS The print screen from Volumio I will send in few min.
I have just mounted my Qnap nas without a problem
1qnapnaslibraryMoOde4.0 by Man in a van, on Flickr
No need for user and password with mine, and the default format for the Qnap is NFS.
Ronnie
-Tim
System Info:
20180205 011255 worker: - Start
20180205 011255 worker: Successfully daemonized
20180205 011255 worker: - Init
20180205 011255 worker: Session loaded
20180205 011255 worker: Debug logging (off)
20180205 011258 worker: Host (moode)
20180205 011258 worker: Hdwr (Pi-2B 1GB v1.1)
20180205 011258 worker: Arch (armv7l)
20180205 011258 worker: Kver (4.9.79-v7+)
20180205 011258 worker: Ktyp (Standard)
20180205 011258 worker: Gov (performance)
20180205 011258 worker: Rel (Moode 4.0 2018-01-26)
20180205 011258 worker: Upd (None)
20180205 011258 worker: MPD (0.20.12)
20180205 011258 worker: USB boot not enabled yet
20180205 011258 worker: File system expanded
20180205 011258 worker: HDMI port off
20180205 011259 worker: File check ok
20180205 011259 worker: - Network
20180205 011259 worker: eth0 exists
20180205 011259 worker: eth0 (192.168.1.121)
20180205 011259 worker: wlan0 does not exist
20180205 011259 worker: - Audio
20180205 011300 worker: ALSA outputs unmuted
20180205 011300 worker: Audio out (I2S audio device)
20180205 011300 worker: Audio dev (HiFiBerry DAC+ Pro)
20180205 011300 worker: ALSA mixer name (Digital)
20180205 011300 worker: MPD volume control (hardware)
20180205 011300 worker: Hdwr volume controller exists
20180205 011300 worker: Chip options (Burr Brown PCM5122)
20180205 011300 worker: - Services
20180205 011302 worker: MPD started
20180205 011302 worker: MPD scheduler policy (time-share)
20180205 011302 worker: MPD output 1 ALSA default (on)
20180205 011302 worker: MPD output 2 ALSA crossfeed (off)
20180205 011302 worker: MPD output 3 ALSA parametric eq (off)
20180205 011302 worker: MPD output 4 ALSA graphic eq (off)
20180205 011302 worker: MPD crossfade (off)
20180205 011302 worker: - Last
20180205 011303 worker: USB sources (A063-310D)
20180205 011303 worker: NAS sources (mountall initiated)
20180205 011303 worker: Volume level (100) restored
20180205 011303 worker: Maintenance interval (21600)
20180205 011303 worker: Watchdog started
20180205 011303 worker: Ready
alsamixer:
Analogue [dB gain: 0.00, 0.00]
Analogue Playback Boost [dB gain: 0.00, 0.00]
alsamixer
-Tim
Nice, I hadn't noticed that option. So setting the gain to -6 dB should reduce the SPL by half.
Log and alsamixer look ok.
-Tim
That's what I thought also. Oh well, add another mystery to the universe. Ill just have to set Moode's volume to the low 80s and hope it doesn't get nudged upward .
Thanks for the help everyone, 3.1 was working well but was thinking of getting an Allo Boss, which didn't have an option in 3.1. So maybe things will work out with the Allo and Moode 4.x
The symptom of "louder to the ear volume" suggests something external to moOde software.
What downstream audio device and input port is your Pi+DAC connected to?
-Tim
Why not try setting the -6 dB analogue gain option for the DAC chip as mentioned above? That will reduce the output of the Hifiberry without using the digital volume.
I just got my raspberry pi and a boss dac and have tried various audio players. Moode is sweet! While I have a fairly large local music library, I also subscribe to Google Play Music. So, I configured La MS to support Google Music and enabled the squeezelite player in Moode.
I had a quick question regarding squeezelite and the DSP operations supported under the MPD settings...
When Squeezelite renderer is disabled, the "Audio Information" dialog box properly displays all of the tasty details regarding the current song (including the active "DSP Operations").
However, when Squeezelite is enabled, the "DSP Operations" all show "N/A". This is true when playing the audio from the LMS or when using MPD to do a local playback.
Does this mean that the DSP Operations (resampling, crossfeed, etc) are disabled any time the squeezelite renderer is enabled, or are they disabled only for the squeezelite audio source?
It would be great if these operations could be used for any audio source being played...
The DSP operations are only for MPD. They could be applied to any renderer including Squeezelite but lot of work to do this and not enough requests or project support...
-Tim
-Tim
An Onkyo-A10 amp (recently serviced and brought to factory spec). Tried switching inputs with other sources (cassette deck and CD player) but Moode/pi/HifiBerry is still much louder. It's not a subtle difference, similar to when an obnoxiously loud commercial comes on the television while watching a show at a decent volume. The kind of commercial that makes you open your eyes wide and exclaim, "geeeze" while fumbling for the remote's volume button before the whole house wakes up.
I've had "vintage" 70's and 80's high-end audio electronics that never really worked right in todays time. There were always issues. Vintage speakers however are a different story, some are to die for.
Good luck.
-Tim
- PC Based
- Moode Audio Player for Raspberry Pi
