Simplistic NJFET RIAA
Still plugging away at it
Thanks Salas, you were very helpful when I started. I’ll dig everything out and blow off the dust from my brain. I suppose I was hopeful somebody local to me might have time and the skills required to finish it off. It’s been a while.
Hi Salas, so I’m short on a few parts, but have made some progress. Q3y hfe both around 608. Is this orientation correct?
All a little dusty like my brain. 😜
Q3y
Slow progress, but getting there. Is this the correct orientation for Q3Y?
Thankful
Please excuse the dust, I started this years ago 😜
D1x
Ok, I tested an installed all led’s ( along time ago), all but dx1. Can’t find the paper with the values listed from when tested. Can you please advise d1x value? Also how do I test again? Something to do with 9 v battery and R ��.
Thanks So much!
P.S. Notice that if your own LED strings don't exactly reach the total forward drop voltages quoted in the instructions its not a problem, you just want them strings total voltages fairly well matched between the channels. Since the rest are already done and installed in in your case except D1x just match two reds for D1x to complete the PSU circuits.
Hi Nick
I put the Phono in a carton box with adequate ventilation just to simulate the aluminum box will be in the near future so to adjust the TP1-TP1 bias
I see that even in the box the bias is raised slowly but in a continuous way up to maybe over 4Volts, and some time i do have to re-adjust VR2x to the limit and still can't go lower enough to 3.6V, I also use VR1 to lower the voltage but still raise slowly but continuous.
From cold start I see that it may takes an hour or more to reach 3.5-3.6V (without re- adjustement from previous session it starts cold from 1V or less and gradually raise to 2-3V in a hour or so).
I wonder if I put a plastic cover over the two K369s to isolate them (in a way) from the enviroment which is getting warm from the Power Supply Heat
Any ideas?
You could try a cover or to swamp them with a hot melt gun. Anyways you only look to keep an equidistant point they would hover about because MC version input stage may drift but still keeps enough DC voltage window to contain the few decades of mV level signal swing.
Circuit Description
Hi Salas, Is there a circuit description for the FSP like the DCG3 thread post #47?
I’ve been trying to better understand how this circuit works. I’m loving this project and very happy I’m finally getting back into the hobby.
Many thanks as always, for all your knowledge and support :cheers:
Ps: I’m slowly getting through the 1600 + pages of this thread.
