New PassDIY Headphone Amp (now available)
Glad to have you on board! There should be some progress very soon, I'm supposed to get a batch of opamps to try today.
As for overpriced and lousy and the antidote thereof, the Schiit Magni 3 is, by all accounts, absolutely mindblowingly fantastic. And $99.
Update - The final configuration should be posted soon. The current PCB is fine, there will be a few tweaks to the schematic.
Documentation will contain the BOM.
The ball is rolling on getting the PCB into the diyAudio store, but this is never a fast process.
The best bit of news is the one I made with jellybean parts is fantastic sounding! Using a $0.50 ON Semi LM833 opamp and IRF 610/9610 outputs.
Yes, I agree.
This was always going to be a project suitable for a wide range of builders, and having a solid PCB and configuration to ensure success has been important. I think we've finally gotten there. 🙂
Thanks!
Yes, I agree.
To Wayne, 6L6, and diyaudio! I look forward to building this when the final boards, BOM are available.
Looks like a donation to DIYaudio is also in order.
This is the new board with a build using no exotic parts. It sounds absolutely wonderful! (In this example my favorite has been a $0.50 OnSemi LM833 and IRF610/9610 output mosfet.)
The official guide is in-progress. PCB will be in the diyAudio store in the not-distant future.
attachment.php
attachment.php
attachment.php
A build of mine. No CNC finish on the case yet, maybe later ...
The most dificult were the the output transistors 2SK2013/2SJ313 - matched quad (2N,2P) was bought form liubincalvin forum user.
Plays nicely, however, the default gain setting is a bit low my taste (Senheisers HD600 needs more)
