Moode Audio Player for Raspberry Pi
@goldhorse
Glad to hear the result is useful to you.
Soon after the manual recipe was released, I tried building moOde on Armbian on a Cubox-i4Pro. Why? Because it and several other SBCs were sitting on my bench gathering dust after a long-ago project. I hit the same bumps as you. Didn't pursue it further. RPis work great, cost half to a quarter as much, and have a great selection of reasonably priced DAC Hats available.
And I second your sentiment for the holiday season!
Kent
@Kent
Why do people climb mountains? Because they there to climb 🙂
While as you said the RPi is very easy to work with, it is also very hard to ignore the power the Tinker Board provides so I'm still hoping more support will come over time.
I'm trying out another approach I came across in a Japanese discussion board, where you have moOde on one RPi, which will take care of the GUI, UPnP, etc and MPD part, and pass along the PCM stream to another board with the DAC, in my case the Tinker Board.
goldhorse
Ahh, makes sence why I cant find it then. I'll be upgrading after christmas then.🙂🙂
A few questions on that account:
  • Does the new Moode version support RPi 2B?
  • Can I use the Imagebuilder on the existing Moode installation? and will it just wipe the old installation?
  • Does the new version support cromecast audio (and/or is planned for the future))?
  • Does the new version support streaming audio via bluetooth (mainly on android)(and/or is planned for the future))?
@ms2204
Haven't seen anyone answer yet so here's my take:
  • RPi2B? yes, I'm running r40b12 on both RPi2B and RPi3B just now, with HiFiBerry DAC+ and DAC+ Pro (sorry @Zootalaws, I was young and foolish last year, metaphorically speaking🙄).
  • Imagebuilder on an existing Moode Installation? Yes...but. I've done it from the command line. Just this morning I tried it by downloading the builder via the moOde GUI (System config/Download image builder) and running it via the moOde SSH term server. The script started fine but came to a full stop after successfully downloading raspbian-stretch-lite.zip. No time to diagnose this until tonight.
    The old installation won't be overwritten unless you try something like @HeeBoo's direct installation procedure.
  • Chromecast audio? Not now, AFAIK. Only Tim can predict the future.
  • Bluetooth source (which means streaming from moOde to some Bluetooth sink, like a Bluetooth speaker)? Not now. Again, only Tim can predict the future.
Kent
Bluetooth out requires Blueman (Bluetooth manager)
sudo apt-get install pi-bluetooth blueman
Hi Mike,
Do you have a config that works where moOde is the sender?
-Tim
A bit old ... but got it to work without modifications except editing mpd.conf (i can't choose this in Moode configuration), so let me explain :
On RPI3 (Wifi disabled), paired my bluetooth speaker with bluetoothctl (not a big deal , trust, pair, connect ) after discovering it.
In bluetoothctl :
[UE BOOM NOIR]# info 88:C6:26:XX:XX:XX
Device 88:C6:26:XX:XX:XX
Name: UE BOOM NOIR
Alias: UE BOOM NOIR
Class: 0x240418
Icon: audio-card
Paired: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Serial Port (00001101-0000-1000-8000-00805f9b34fb)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
Modalias: bluetooth:v000ApFFFFdFFFF
[UE BOOM NOIR]#
Then edit mpd.conf to add :
audio_output {
type "alsa"
name "Bluetooth Speaker"
device "bluealsa:HCI=hci0,DEV=88:C6:26:XX:XX:XX,PROFILE=a2dp"
But currently if i switch on my amp, i got also music on my speakers !!!
Maybe just because added on mpd.conf and not making a possible choice.
Maybe someone can rework this kind of settings 😉
regards
:santa2: brought me a 7" touchscreen, and SmartiPi Touch case, so yesterday after all the gifts were unwrapped and the kids were busy with games and/or LEGO, I sat down to try out Moode. I already had a Pi3 and IQAudio DAC Pro assembled and tested with the IQAudio test image, but had so far failed to get other music player packages all sorted :headbash: (mostly Max2Play and OpenElec, a few hours of fiddling on each).
HUGE kudos to Tim and this forum!
:up: :cheers:
The SmartiCase comes with a power splitter, so you don't even need to solder in the 5 pin header to pull power to the screen from the Hat. Physical assembly was trivial. Then I:
  1. Burned a blank Raspbian stretch image with ApplePi Baker
  2. ssh'd into the Pi3 and followed the Build Script 2.2 instructions, copy and paste style
  3. So many reboots. Bonus: wow a Pi3 with a minimal image boots FAST.
  4. After the basic "Initial Configuration" procedures in step 12 of the build script, I followed the 2 IQAudio DAC config steps for Moode from page 38 of this guide:
    http://www.iqaudio.com/downloads/IQaudIO.pdf
  5. After "Step 13" cleanup and reboot, I skipped the optional components until getting to "Component 8 - Local UI Display"
  6. This is literally the only build step I had to interpret: Where Tim writes, "NOTE: These steps are performed AFTER actually starting local display via System config, rebooting and then accessing moOde on the local display" you need to hop to page 1103 of this very thread and read @Morias hints. Execute anything there that isn't in the build script. Side Note: as someone who has been around since X11R3, it is hysterical to me that we still fiddle with 3-5 line .xinitrc configs to make everything go.
...and BOOM. Fully functional touchscreen music player with high quality DAC output, first time through, no hassles. That's impressive as hell.
Now I'm copying the big music library to a fresh drive, and will move everything down to the big stereo this afternoon 🙂
[Then, because I am a cranky old masochist with firm opinions about computing topics, I will see if I can extract systemd from the mix without breaking everything. Quiet you. Yes I am That Guy. Leave me to my quirks]
Which build script are you referring to?
:up: :cheers:
MoOde r4b12 with power button
Hard through GoogleTranslate!
I have a Rasrberry B2 + Audiophonics 9023 V3 TCXO + LED 20X4
I set the moode build_recipe_v2.2 up to step
## STEP 12 - Launch and configure moOde! ##
without
## STEP 10 - Optionally squash /var/www ##
, then
Forum Audiophonics.fr • Consulter le sujet - Moode Audio support
sudo apt-get update
sudo apt-get install gcc
cd /home/pi
git clone git://git.drogon.net/wiringPi
cd wiringPi
./build
cd /home/pi
wget https://raw.githubusercontent.com/audiophonics/Raspberry-pwr-management/master/sds.sh
sudo nano /etc/rc.local
sudo bash /home/pi/sds.sh &
sudo wget https://raw.githubusercontent.com/audiophonics/Raspberry-pwr-management/master/softshutdown.sh
sudo wget https://raw.githubusercontent.com/audiophonics/Raspberry-pwr-management/master/softreboot.sh
cd /var/www/command
sudo cp worker.php worker.sav
sudo nano worker.php
I changed these lines so-
// command/moode jobs
case 'reboot':
sysCmd('mpc stop');
sysCmd('systemctl stop nginx');
sysCmd('sudo bash /home/pi/softreboot.sh');
break;
case 'poweroff':
sysCmd('mpc stop');
sysCmd('sudo bash /home/pi/softshutdown.sh');
break;
The button indicator and on the board work! Maybe I'm not doing the right thing, but it works.
Then the command:
Code:
I find myself with:
Code:
cp: can not create regular file 'worker.sav': Read-only file system
Then when ordering:
Code:
once the file edit I can not save it:
Code:
[Error writing worker.php: Read-only file system]
Have you had this problem?
Building moOde -- the story so far . . .
Hello everyone,
I hope you had a wonderful holiday spending time with the most important people in your life.
For those just joining the thread -- perhaps Santa brought you a brand new RPi -- I thought I'd quickly summarise the build options for Tim Curtis's moOde audio player:
  1. IMG file: There is no img option at the moment due to GPL licensing issues. Short answer here http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-1218.html#post5282792
  2. Source files + build recipe: this is a step-by-step process that involves building moOde on a Raspberry Pi running the Raspbian OS via SSH terminal commands. You will need two microSD cards, one for running Raspbian and one for building moOde, and a microSD-USB card adapter (multi-card adapters are not recommended as they can appear as multiple mount points and confuse things). This essentially involves copying commands from the build recipe into the terminal and allows a lot of customisation opportunities for experienced Linux users. Source files and recipe can be downloaded at moodeaudio.org
  3. moOde OS Image Builder: this is an automated script by koda59 and Tim that uses the above build recipe that is run on an RPi with Raspbian. As per the build recipe, it requires two SD cards and an adapter. It is (mostly) set and forget but there are some options that need user input at the start and you will be prompted to remove the microSD card from the USB adapter and use it to reboot the RPi to continue the build. Details are in the support section of moodeaudio.org
  4. Moosimbu script: this is a patched version of the automated image builder provided by HeeBoo. It requires only one microSD card and updates the existing Raspbian installation to moOde OS. It is a work in progress and supported by HeeBoo. See this post for downloading the script http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-1216.html#post5281736
  5. DietPi installation: moOde is now installable via the DietPi distribution. Some functionality is not integrated yet but this should be solved in the future: DietPi / Fuzon • View topic - v159
Some tips:
  • I suggest using ethernet to connect the RPi to the network/internet while building as the process seems to run more smoothly than via WiFi. However YMMV.
  • Be patient and allow some time for the build process. Some users have reported more than an hour.
  • You can monitor the build process via SSH during the final stage (the RPi booting from the moOde OS card) with the following command (thanks HeeBoo). The password to login at this stage is moodeaudio:
Code:
 ssh pi@moode "cat ~/mosbuild.log | grep 'COMPONENT\|STEP\| Compile \| END\| Error'"
Emendations or updates are very welcome.
Richard
I have just built moode on a raspi3b using 4 beta 12 and the Moosimbu script (got it working on 3rd attempt - 1st time around I was probably too impatient and started config'ing too soon, 2nd time around the local.rc failed to run correctly).
I think i'm all up and running now but have not yet connected the IQaudio Digi+ to my DAC and heard any music out of it yet.
I believe that you can add radio stations - I have found all the stream feed details but I don't see where I should enter them - how do I get to the radio station maintenance screen?
There may be an alternative method but this works for me. Go to browse, click on RADIO and on the far right you will see . . . click on the three ... to get pop with options. Click on create and you enter in the address for your new station.
Hope this helps.
Tim,
Will it be difficult to integrate pairing Bluetooth from Moode instead using bluetoothctl command ?
In the same spirit, is there a way to choose an audio output from Moode from mpd.conf ? ( i changed mine to have Moode as source sink).
All is working well, but i need to tweak mpd.conf if i only want output on my speakers or on Bluetooth speaker.
Could be cool to have it direct in MoOde interface 🙂 even if BT speaker is not very audiophile.
Maybe it is too much changes.
Idiots guide:
Install raspbian stretch lite
Edit boot portion to have ssd file and set up networking (if wifi) and to add the install script
Put the sd card in your Pi, boot.
Ssh to Pi, start script, wait.
Done
It really is as easy as that..
Err, not easy for this idiot, but I'll get there. Like Malefoda said,
it's more on computer side than audio side.
Zootalaws's comment,
If that’s too hard for you, maybe diy audio isn’t for you.
... really is arrogant. We all stand on the shoulders of giants. We shouldn't forget that we were all newbie's once, even the giant (grinch) Zootalaws!
Trying out the mosbuild.sh script. running over Ethernet
I can get through Step One and the new "OS" written onto the second (newly formatted) SD card. Remove first SD and replaced with second, and reboot.
Bootup sequence runs for a bit and then gives me
[FAILED] Failed to start /etc/rc.local Compatibility
and then dumps me out to the moode login.
What have I missed?
Just installed Moode 4 Beta 12 on Pi 2B successfully without any problem whatsoever.
Followed Heeboo's instructions for a single SD Card installation and came back a couple of hours later to a fully working setup.
Initial setup done via hardwired ethernet, set Wi-Fi up afterwards and am now listening to 24/192 FLAC over the air.
Many thanks to Tim for all the hardwork you put into this project. Thanks too to koda59 and Heeboo for their input into the installation scripts.
That's the way to go, IMHO.
I suspect that most users have a single instance of Moode and don't need the added complication of trying to build an installable Moode image.
Phil
Tim,
Do you mean allowing moOde to send audio over BT for example to a BT Speaker?
If you have a working config, email me and lets see what can be done to integrate into moOde 🙂
MPD outputs are changed via command below where N is a number from 1 - 4 that identifies the output. If you have added an output block to end of mpd.conf then it would be 5.
mpc enable only N
-Tim
Maybe it's due to /etc/rc.local start too earlier for the RP1.
The builder wait for 10 sec to avoid this kind of error (i got it during testing phase on RPI3 without waiting time) ... but maybe 10 sec is not enough for this model.
Maybe NorthCountry can try to edit mosbuild_worker.sh and change wait4rc 10 to wait4rc 20 or more to see if it can be the way to success 😀
Hi koda59,
I changed mosubuild wait4rc 10 to 30 in mosbuild_worker.sh and build process goes well. I can build beta12 on my RasPi1B and that works fine.
Thank you for your advice.
