TPA3255 - all about DIY, Discussion, Design etc
I agree its confusing - nobody to my knowledge uses analog input classD without feedback, so that final sentence is crucial. Digital input classD is often found without feedback though - TI has some chipsets with feedback (they term this 'closed loop') and some without ('open loop').
You're not wrong about your confusion!
Think about the PWM-based proportional-to-bus-voltage-gain as part the internal loop gain of the amplifier, but then there's a pre-filter feedback network which sets the overall gain of the block. Since the error amp will dominate the internal loop gain, the small change in the class-D amp's gain with bus voltage will not materially affect the gain set by the feedback network.
From the outside as users of the chipamp, we are "stuck" with the already-established internal feedback network, so the gain is pinned to 21.5 dB
tpa3255
Hi all
I build my amp TPA3255.
Input opamps full defferential THS4131, PSU MW LRS-350-48.
Thanks guys! I've been studying passive circuits, but with the purchase of this EVM I've started studying active circuits. Feedback is slowly sinking in!
Just to satisfy my own curiosity, I created a 400Hz signal at .64 volts and measured the speaker out voltage. It was 15.27 volts, which equates to a 27.5 dB gain. Since I'm running this amp BTL, the output voltage would double vs se, which would account for the extra 6 dB.
Mike
I would expect this to work even with >1k source impedance. The drawback is increased noise - but this will be quite low as well. All in all these noise figures of 1nV/sqrt(Hz) are more or less academic as in most real cases your audio source will contribute far more noise.
