The bass is better, more dry, less rumble. KEF Q100, -3 dB: 49 Hz - 40 kHz.
I suspect that it also increases the fall slope of the coil.
I tried with tweeter cables too but the sound was in U, too much highs.
And with two rounds with woofer cables but the sound was worse.
With the music (classical, baroque, jazz... music without electronic instruments) I listen to -when my diy devices can with the VERY BIG noise/interferences of the mains- I have so many bass that I do not miss a sub, unlike what happened before.
With other filter, more complex, the results do not have to be the same.
Wow. I should go to Adolf Würth, who lives just some kilometers apart from me, and tell him that he could even make a lot more money by marketing his RFI ferrites to audiophools. Or, even better, I should buy large qantities of them, quit my daily job and do the marketing by myself.
Best regards!
Best regards!
Is it so hard to think a little before to write here?
The idea:
Bypass capacitor with other in parallel => The same with coil, with other in series.
It was trial and error. And it worked.
The idea:
Obviously.
The AC current flows through your 'coil' in opposite directions, so the tiny inductivities that each of your conductors see are cancelled.
Best regards!
I know, that is why I used the italics: series. But the inductances are not cancelled.
+ -- coil -- ferrite -- woofer -- ferrite -- -
The question is that the sound is better. And bypass the yellow capacitor with 10 nF 600 V styroflex too. And those little two pieces of rock wool, placed in the back, up. And ...
There is something about frequency and Skin effect when designing SMPS multi-stranded transformers. Could it be it ?
On my living room I use parallel grey supra cable 6 mm I think. For PA I use ordinary round rubber black mains cable 2.5mm.
I was using that flimsy 1mm black/red cable that came with the speakers, and one day I changed them for supra. That's when I changed also the RCAs and Scart Video cables for Monster. You know ... They say Gold is what matters ....
But I experienced something:
I have a stained glass fixed window on my stairs and in one of the corners there is a crack. When I changed the cables, I could hear the glass rattling when going up or down on the stairs. I've never noticed it before. Perhaps the cables increased the bottom end...
Of course the very tiny additional inductivities are cancelled. You're running both the woofer's black and red wires through a common ferrite core in parallel, don't you? At least your pics show that. This basically is the same as a bifilarly wound inductor with the current through each wire flowing in opposite directions. Remember the original purpose of these beads as a common mode RFI filter...
Your experience of better bass response clearly has to be deduced from expectation bias.
Best regards!
The test is very simple to do.
Really? DBT's usually aren't.
Best regards!
Again, the inductances are not cancelled.
http://www.farnell.com/datasheets/1919956.pdf
No. 'Bypass' caps often make things worse. Adding a ferrite to make a common-mode choke does not add to inductance.maty tinman said:Bypass capacitor with other in parallel => The same with coil, with other in series.
Yes.Kay Pirinha said:The AC current flows through your 'coil' in opposite directions, so the tiny inductivities that each of your conductors see are cancelled.
You clearly believe so.maty tinman said:The question is that the sound is better.
No.MAAC0 said:There is something about frequency and Skin effect when designing SMPS multi-stranded transformers. Could it be it ?
Extremely unlikely.I have a stained glass fixed window on my stairs and in one of the corners there is a crack. When I changed the cables, I could hear the glass rattling when going up or down on the stairs. I've never noticed it before. Perhaps the cables increased the bottom end...
I measured the distortion of an 8ohm dummy load at the end of 2m of 16ga stranded zip cord vs at the amp’s output terminals and also at the end of 2m of 12ga solid copper Romex. There was a huge difference in not only amplifier damping factor, but also distortion profile, but THD, and in one case, the zipcord caused a mild oscillation in the amp. Amp was VHEX+, my reference Class AB amp. I now use 12ga solid copper Romex. It’s all measurable and not little effects - more people should measure and stop wondering.
An amp with oscillation, or the verge of oscillation, can produce strange results. The fault lies with the amp, not the cable. As I often say, cable sensitivity is a sign of poor electronic design.
Perhaps so - the VHEX+ by vzaichenko has been a pretty solid amp and it was surprising that the mild oscillation showed up on the FFT. But it doesn’t change fact that cables do affect the amp impedance / damping factor greatly oscillations notwithstanding.
No, cables do not greatly affect the amp impedance - unless they are very thin. However, a poor amp design might oscillate with certain cables and the oscillation could affect the amp impedance (and distortion, and frequency response etc.). Don't blame the cable.
- Design & Build
- Parts
- Belden DIY audio cables
