Belden DIY audio cables
For what I think is the question? I would imgaine RF will always be in common mode into the speaker terminals. It is possble a well designed choke would do some good. Here is an example in the link. I think Farnell show a differential mode type by mistake. A common mode choke should have an equally and opposite reaction to the amplifiers output as it is in differential mode, as if it wasn't there ideally. Only error sigals in common mode are cancelled in the ferrite doughnut. Any RF differential mode should be reduced by the amplifer Zobel circuit if fitted ( 10nf + 8R or similar ).
http://uk.farnell.com/lcr-components/cf4/choke-common-mode-2x2-4mh-4a/dp/9520961
From a interference point of view, twisting is slightly better than braiding. However from a mechanical point of view, a braided flexible cord will hold it's shape better.
A ferrite choke can be placed near the amplifier terminals, to reduce high frequency RFI.
