except for the thermal thing, that is were you solid state guys failI like that he spars with both sides, Charles Hansen as well as several reviewers. I also notice none of your stuff gets much (any?) mention. He makes very clear that audio is science but does not seem to have much interest in the scientific method. He also espouses the idea that maximum power efficiency is obviously the ideal situation (intuitively) even though there is no scientific basis for this.
More wasted time... 6moons audio reviews: APL HiFi NWO 3.0-GO
It's always exciting to read how a component manages to break in its owner over the course of a few 100 hours 🙂
Jan
I have no idea what you mean here.
Thermals for solid state ic and board levels design? There's always more to learn, but it's not exactly a immature field.
Hee! So instead of spending $10,000 or whatever on a DAC, maybe he could save some money and just get a cat.
We always can learn from tube aficionados.
I’ll start working again on my omnis, so I had a tour on Stewart Hegeman’s designs.
I found this interview, IMO it’s relevant to the interests of the members
retro vintage modern hi-fi: Stewart Hegeman interviewed by Norman Eisenburg 1961
George
You are in for some fun with new sounds when you 'get it'.
Be prepared to launch some belief systems straight out of the nearest window.
Dan.
Bybee frisbee? 😀
Maybe you didn't read his reasoning, efficient things are "better" intuitively for no other reason than that they are efficient. Then go on to infer this is a scientific fact. Take this quote and then compute the wall plug efficiency of some of those flea power SET amps. Or just take the quote as a statement of "scientific" principle.
High-Efficiency (HF) is the most important and critical advantage in audio. Why? HF speakers require less energy from outside sources to achieve the same level of performance. The energy from those "outside sources" is always imperfect and compromised. Accordingly, the less energy from "outside sources" included in the total energy created by the system, the less compromised the sound will be. And, to be clear, "outside sources" specifically mean electronic phono stages, DACs, active line stages and power amplifiers
Your other comments were not necessary we (me too) moved into optics a decade ago. I would love to see this forum go no monikers.
> maybe SR is too low... sounded hard/edgy.
" hard/edgy " is more apt to be from SR too high ( in my experience )
Really? Are you sure?
-Richard
I'll do some math, time permitting, but as long as the dithering data is not correlated with the signal, I don't see any reason why they should be different (actually, converge).
I did my homework and I have to admit I was wrong. While I’m still convinced that pre and post truncation dithering would be indistinguishable in a DBT test, the correct way to dither is before truncation. That is, dither the low 8 bit of the 24 bit original with noise having a TPDF probability distribution. Other distribution (including flat) can be considered, but TPDF is theoretically optimum (in the distortion reduction sense).
Now, while dithering the 16bit truncated result LSB with either the XOR of the 8bits of the pre dithering signal, which is indeed as stochastic as you can get, or even simpler with a binomial distribution (aka “toss a coin” signal) will indeed provide distortion reduction, this is not optimal. It is equivalent with the pre dithering with a flat distribution noise, which can easily proven as suboptimal.
Unfortunately post dithering the 16 bit LSB doesn’t offer any other options; we could of course consider dithering the last 2.5 LSB and then considering TPDF is possible; but then this will add to the 16bit noise floor, which is once again suboptimal compared to the pre truncation dithering.
So the optimal way is dithering before truncation. Once again, I’ll place my bets on a NULL result in a sorting DBT, though, so this is an academic issue only.
Waly: Appreciate follow up on the dither question. May I ask, do you mean it is theoretically an academic issue, or proven to be an academic issue only?
I have no interest in betting on anything, just not much of a gambler. However, if you would like to put up some 16-bit files made from a high quality hi-res source you think would be a fair test for people to try to distinguish, I would be interested to give it a try. I'm sure other people would too.
Just to be clear, I'm not claiming to know in advance which way the outcome might go, just think it would be interesting to run the experiment and see.
Edit: To be sure we are on the same page with respect to a test, the idea would be to see if anyone can hear some remnants from, say bits 17 and 18 buried in dither noise in a 16-bit file, or if nobody can hear anything down at such a low level. Would that be a fair statement of what we would be trying to find out?
I came to the same conclusion as waly, but not feeling like I got an intuitive sense of what's going on, I want to make up some scripts to visualize the effects. Hopefully I'll get a chance to write up a post to share.
It might be difficult or impossible, certainly. Never tried that one is all. Not too hard to hear a little difference between a hi-res 24-bit digital recording and a 16-bit file made therefrom, but that isn't the same as what we are taking about in this case. 24-bit verses 16-bit might be easier to hear as compared this dither before/after 16-bit only test. In this latter test, the higher resolution information in the dither-before file is buried in noise, so no surprise if were harder to discern.
Update on the DAC3 review, Charles Hansen has really flamed on in the comments. He clearly didn't like the review!
Yes. Positive.
My main experience comparing LF356 to LF357 as line stage in phono preamp.
I used LF356 for phono stage (per compensation needed) and LF357 for line
stage (per square wave response)......My main customer (whose ears I have
come to trust) complained " hard edgy " ( or something oh so close )
On listening myself I understood his observation .
Changing to 356 for line also made him happy .
The comment after Mr. Austin's nails it. I wore out my welcome with Mr. Hansen a long time ago.
What i meant is most if not all EE's never worry about the temperature of an IC as long as it doesn't reach the maximum. Resistivity and conductivity being temperature dependent will hence be different between low and high amplitude / energy signals. I know I can make an IC super efficient by simply talking a can of air, turning it upside down and spraying with the freezing air that comes out. So I propose, as I have in the past, why not attach a TEC (thermal electric cooler) and set to some dew safe temp like 15 C and see if you do not get more linear operation. This IS high end, no?
- Member Areas
- The Lounge
