speaker protection
Prasi,you know the next step!😉
I hope this is the expected next step😉.
edit: slightly edited the silk (credits)
  • protect pdf with film cap-Cu bottom.pdf
  • protect pdf with film cap-silk top.pdf
Here is an idea of passive circuit, based on a normally-closed relay avoiding further damages to the amplifier in the event of a fault:
Under normal conditions (no DC), the relay remains unenergized:
attachment.php
When DC is present, the relay is activated, opening its contacts:
attachment.php
attachment.php
attachment.php
Good,very clever design! but in this case you need another mute circuit elsewhere ,maybe in the amplifier input.
Is it a pcb available?
Why? This might be required for the previous examples, the ones shorting the output (although it risks being ineffective, if the amp's problem is such that it is completely unresponsive), but this ones opens the speaker's circuit all the time the voltage is present. In fact, the fault voltage serves to power the circuit.
No, I just cooked it now, it's still hot from the oven and hasn't been tested.
Another possibility would be to drive a bistable relay, but the rearming problem would need to be solved.
An elegant method would be to use a purely electromechanical residual current circuit breaker: there is a manual resetting lever that could be accessible on the rear of the speaker
As a normally-closed relay used how the start-up noise will be avoided?
Let the amp builder handle that. A passive speaker protect has value by itself.
Indeed: this thread is about speaker protection, not anti-thump circuits, and anyway, how would the circuit know what is a power-on thump and what is part of the program, like violent percussions, explosion noise, etc?
Continuous DC for more than ~100ms is clearly pathological, but other than that....?
Perhaps with multple FETs in parallel the on resistance could be tamed?
Digikey carries the CPC3902 depletion FET. There's a price break at 25 and they're not expensive so we put 25 of them in parallel.
This would provide an effective on resistance of ~<0.1R, carry a pulse current capability of ~10A.
They'd be 'normally closed' and a dc-fault would be used to energize them.
