Are there any advantages of converting the rpi i2s to i2s(lvds/hdmi) and using the sk1021 i2s(hdmi) - in?Using J11 to connect the raspberry pi, you need to remove three 33 ohm resistors. This way, the i2s is the raspberry pie, but the hdmi i2s isn't available.
Or is it just as good as connecting rpi i2s direct to the sk1021 via J11 or direct coupled to the dac as I have?
I will test both options as I have several small pcbs i2s to i2s(lvds) - hdmi tranceivers produced.
Under is my prelimenary setup. rpi direct coupled via hifiberry digi+ pro to the dac for the time being. Tapping 5vdc to the rpi from the sk1021.
Prototype i2s-hdmi tranceiver upper left.
Success. Testing rpi i2s to i2s(lvds/hdmi) and using the sk1021 i2s(hdmi) - in.
Works like a charm after some "fiddling".
Unable to tell if there are any changes in sound between i2s direct or converted to lvds.
They both sound excellent 🙂 With this setup using the rpi as a standalone streamer to the sk1021/dam1021 will be a great setup 🙂
Thanks for testing! So it doesn't matter how I connect it, they both work fine?
With hdmi is neater, but more parts
You can use 2*10p interface for the combo384.
I think I2S is definitely better than I2S LVDS over hdmi in short distance transmission.
Looks like the TX should be ok, and the RX is not ok.
Show your wiring pix, please. Also, make sure your dam1021 firmware is 1.06.
Please check.
![url])](/community/proxy.php?image=http%3A%2F%2F%5BSok.jpg%5D%28%5Burl%5Dhttps%3A%2F%2Fpostimg.org%2Fimage%2Fzacrahqez%2F%5B%2Furl%5D%29&hash=025a8344008754a47195544f446a3a64)
Please check.
You've got a wrong connection, so the wiring could burn the chip. Use DAM1201's J3 instead of j10. Please read our manual carefully.
I have a Soekris DAM1121-01 due to be delivered today and have an AudioZen SK Lite on its way to me so I'm work on how I'll implement my DAC build.
A question: Unlike the DAM1021, the DAM1121 only has one means of connecting the SK Lite, pins 10 & 12 of J2. With the SK Lite connected how can I use a serial interface to upload new filters? Can I just connect a serial interface to J2-10 & J2-12 along with the SK Lite or does it require some sort of switching arrangement? Thanks.
DAM1121 can not directly connect to the computer serial port.
Please refer to the manual and connect the 1K resistor to dam1121 com pins. You should connect RS232 and SK Lite at the same time. I think there is no need for the switch.
Thank you and sorry for my lack of clarity in not referring to the resistors - I assumed them as a given.
Your kits in Canada now,I shipped it.You can track the Canada post,the detail imformation I will PM to you.Audiozen do you know when you can ship my kit?
SB
2017-07-03 17:44 200237,China, International item mailed in originating country
SK Lite + with Dual-balanced DAM1021
@audiozen
SK-Lite to dual-balanced mono DAM1021 will require 1K to ISO RX for each isolated serial RX in/board?
How is IR input selection achieved between AUTO-->SPDIF-->AES-->USB-->I2S-->Toslink-->AUTO ?
It toggles SPDIF1 +/- also?
@audiozen
yes
LITE:AUTO-->CH1-->CH2-->I2S-->AUTO
It toggles SPDIF1 +/- also?[/QUOTE]
same as dam1021.No additional features added.
yes
I received my SK Lite today. Very well packed and efficient delivery - thanks.
I'll implement with my DAM1121 over the next few weeks all being well.
- Vendor's Bazaar
- AZ OLED setup kits for Soekris dam1021/1121 control
