Moode Audio Player for Raspberry Pi
Many thanks for your help. I just added '/usr/bin/mpc update <path>' to crontab, to run every night. Since I have a NAS, mounted via NFS, this is the easiest way to go 🙂
If I recall correctly, cron isn't running automatically in Moode.
You'll need to enable it and start it.
sudo systemctl enable cron
sudo systemctl start cron
Phil
Im having trouble with moode 3.7 , I am a moode newbie.
Pi3 with a iquadio dac+.
When I try to configure moode and click on the audio icon nothing happens. at the base of the page it says waiting for moode and stays like this for several minutes. Clicking the other icons has the same result.
I've rebooted several times, turned the power on and off etc - nothing seems to make any difference. I have successfully run RuneAudio and Volumio so I don't think its me.
Keen to get this running.
I've installed a ton of Moode systems and when this has happened to me, it invariably been either a dodgy SD card or bad burn.
Did you follow the config instructions?
Ok Tim, I have a slight problem.
I have a NTFS format USB external 1TB drive and it will not find all my files. I have updated MDB a few times and sometimes it will find the folder structure, but then no audio files will be listed. My files are mostly FLAC and MP3. The size of my library is only about 325 GB. The 1TB drive is only one NTFS partition. It is a deskto p3.5" USB drive and has its own power supply.
I do know that this particular Hitachi drive has a "sleep" mode and will stay connected n USB, but turns off the spinning of the drive. Could it be that the USB to SATA (or IDE) chipset is not communicating with MoOde correctly? Or could it be that the drive is not formatted quite right? I do know it has been reformatted a few times.
I never had an issue with my 325 GB WD USB 3.0 Drive, and that is a portable drive powered off the USB. It is also one primary NTFS partition. Mostly the same files too.
Raspberry Pi 3 using MoOde 3.7
Thanks,
Ryan
Nevermind.
I just searched this thread and saw that ther are some issues with large format NTFS drives.
I reformatted my 1TB drive to FAT32 and it works so must better/faster. I used to get audio glitches when a new track started and also missing about 100ms of the start of the track with my smaller NTFS drive. None of those issues with this FAT32 drive. I have no audio files over 4GB and it's really a secondary drive as my main files are on another drive and this is just storage forthis player, so I don't need the benefits of NTFS especially if if FAT32 works better.
For those in the know, is there any benefit to an EXT4 format for an external drive over FAT32 for the Pi?
Monstrum
A little while ago I posted some questions about the control mechanism of the PCM5242 Dac chip as I was designing my first DIY dac / Moode player.
The first revision is now up and running (complete with plenty of mistakes) and named MONSTRUM Dac and as can be seen from the picture this can carry a kali reclocker.
Sound is beyond awesome ;-) ..DIY is the way to go, the high end audio company's are fleecing us for every penny lol.
A Big thank you to Tim for creating such a cool audio player to motivate me to do this...
search not working
Hi I have a problem someone hopefully can help me. I recently put together a PI 3, Hifiberry XLR + pro, 1tb HDD all powered by a USB hub with 2.5A quick charge port for the PI.
I have mostly used Volumio until now and a brief test of Rune today but it doesn't support wifi hotspot out of the box. Both of these work fairly well with my mass of songs and i can search the library with little effort, results are always displayed.
I have bought Moode 3.7 to try out as well but I have a bug in Moode where i can search the 'Browse' tab logical USB drive and get individual songs:
But when i try to search albums or artists in the 'Library' tab i rarely get any results, sometimes i do but not very often. I have tried a new image with only scanning the HDD and changing nothing else but the problem persists:
Has anyone come across this problem as it is the only thing stopping me from moving to Moode permanently.
Thanks for reading.
Really thanks
I did above 2 days ago but when boot pi again I cannot connect to moode .
So I think I make mistake .
just now image write again and edit the config.txt ( I see only config file icon) boot and connected
so play music tonight
really thanks again.
test for week its not work I type in wordpad under the last sentence and save exit reopen config its still have all data include the new that just write
After that put to pi3 try to play music its still have problems loud crack sound wehen skip track or change volume level .
I pull out check again the
dtoverlay=simple-bclk-64fs
was absent . What happen
Hello,
I have a problem with playing DSD files. I can play DSD64, DSD128, but it is decoded to PCM. I cannot play DSD256 – no sound.
My setup is Soekris DAM + Amanero + Rpi3.
I tried standard/advanced kernel, USB (UAC2) fix, DoP (Yes, No), etc.
I post some print screens.
Would you give me any advice?
ajo
