I've taken my zero w to my friend's house to demonstrate the great product but I need to get it on his wireless network
What's the quickest/easiest way to do this?
I don't see the moode AP on my mobile like I did when I originally set it up...
You will probably have to use Ethernet, if you already have your home AP set up in moode. Once connected via Ethernet, you can change your wifi settings via the web interface
Before taking it home, wipe the wifi settings and it will revert to moode AP
You can try:Hi gents
This is a zero w with 3.7 so no ethernet
Afraid I can't easily 'take it home', I'm in a different country now
Any other ideas?
1. Temporarily change your friend's wifi to your home router's ssid & password and then edit things to match the original once you get access.
2. If you can read / write the micro sd card's file system then there's probably a config file you can edit but someone else will have to supply those details.
3. Flash another micro sd card with a fresh copy of moode.
Hi Tim,
As you are preparing the new Moode 3.8 version, I was wondering if it could be possible to allow the installation of Moode on a USB HDD instead of a SD card: I tried to do so many times (following some tutorials that I found on the web) without success (the first boot was always successful but then it could not start the day after) and reading this thread I think that it is not allowed by your software...
looking forward to reading your comments,
Thank you in advance
Hi @pkdick,
The last 3.8 build I made was based on Jessie Lite 2017-03-02 release. There is later release 2017-04-10 that indicates in the release notes:
http://downloads.raspberrypi.org/raspbian/release_notes.txt
* Use PARTUUID to support USB boot
And this procedure for booting from USB drive.
https://www.raspberrypi.org/documentation/hardware/raspberrypi/bootmodes/msd.md
Is this what you are looking for?
-Tim
-Tim
I noticed that track 2 of a particular album didn't show in the library. I rescanned the DB and it still didn't show though it is definitely in the scanned album folder. So, I deleted the folder containing the album and rescanned. As expected the whole album was then missing. I copied the album back, from another location and scanned again. The album is back, but again it's without track 2. Any idea as to what's going on?
Can the FLIRC USB Universal Remote Control Receiver be used with Moode? Thanks
No one tried using a Remote with moode then?
Hi @pkdick,
-Tim
Hi Tim,
Thank you for this information. You may have noticed that I am not a linux specialist, but usually I was able to follow the tutorials and do what they were teaching... I tried many times to move the Moode installation files on my SSD connected to my Raspberry through USB: what I did not understand is that after the operation and having written the config.txt and the fstab file (using the PARTUUID info in order to keep the SSD identification whatever it happens), I could not start again the raspberry, making a cold boot (i.e. the day after).
I also found the booting modification procedure that you propose, which I did not apply as it is an irreversible modification for the raspberry. Anyway, I would be grateful if someone could give a dedicated procedure for Moode USB boot, if possible... As a matter of fact such softwares as Moode are writing a lot on the SD card, which may eventually create issues...
Thank you in advance,
I don't know what it means, but this is what the log shows me for the album in question; track 2 is missing:Hi @ICLIP,
Examine MPD log to see whats going on.
cat /var/log/mpd/mpd.log
-Tim
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/01 Lerner & Loewe - Overture.m4a
May 19 14:40 : ffmpeg/mov,mp4,m4a,3gp,3g2,mj2: max_analyze_duration 5000000 reached
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/03 Lerner & Loewe - Wouldn't It Be Loverly.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/04 Lerner & Loewe - With a Little Bit of Luck.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/05 Lerner & Loewe - I'm an Ordinary Man.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/06 Lerner & Loewe - Just You Wait.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/07 Lerner & Loewe - The Rain in Spain.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/08 Lerner & Loewe - I Could Have Danced All Night.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/09 Lerner & Loewe - Ascot Gavotte.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/10 Lerner & Loewe - On the Street Where You Live.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/11 Lerner & Loewe - You Did It.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/12 Lerner & Loewe - Show Me.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/13 Lerner & Loewe - Get Me to the Church on Time.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/14 Lerner & Loewe - A Hymn to Him.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/15 Lerner & Loewe - Without You.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/16 Lerner & Loewe - I've Grown Accustomed to Her Face.m4a
May 19 14:40 : update: added NAS/AE/Musicals and Soundtracks/My Fair Lady/17 Lerner & Loewe - The Embassy Waltz.m4a
in place update question
Ignore... a reboot cleared that up.
I apologize if this has been covered... I have been running 3.6 just fine. All is good. I finally sat down to do an in-place upgrade. I went thru the appropriate steps, 'checking for update' etc. Clicked the update... that all went fine... yada yada.
Only problem is all system information says that it's running 3.6. I presumed (maybe incorrectly) that it would bump to 3.7.
Thanks,
Ryan
Thanks,
Ryan
Hi @pkdick,
-Tim
Yes please! My hybrid version is rubbish
Thanks,
Ryan
Hi Ryan,
What does the About screen show?
Moode log will also have the version stamp and the update stamp.
cat /var/log/moode.log
EDIT: nvm, I see that "reboot cleared that up"
-Tim
Hi Mike,
What are advantages of USB boot?
-Tim
Thanks,
Ryan
A reboot fixes that as well, I had the same issue.
- PC Based
- Moode Audio Player for Raspberry Pi
