I was, as most everyone is, rather skeptical at first. Here's a little something to suck on.That's interesting, is lemon special?
Home / Remedies
Lemon for Acid Reflux
December 15, 2016 By Admin 8 Comments
Is Lemon Juice Effective in Treating Acid Reflux?
Though lemon juice contains citric acid, when it is mixed with water, it becomes alkaline which helps in neutralizing the stomach acids. Apart from that, it contains potassium and generates calcium carbonate which helps in the same.
It contains vitamin C and A, pectin and fiber that body needs to function properly and provides relief from pain and inflammation in the chest and esophagus.
It balances the pH levels so the digestive system can function properly.
It is naturally antibacterial, so it kills the germs that cause digestive problems.
It cleanses toxins and impurities from the gastrointestinal tract.
It regularizes the production of hydrochloric acid in the stomach and bile production in the liver, both of which are essential to the proper assimilation of nutrients from food.
Limes are just as good but around here the price for juice is about 4x.
There is some evidence that omeprazole can interfere with vitamin and uptake although it's not considered a general risk. I take 2/day with a Vitamin D and B-complex.
I've been doing the lemon thing for over a year now and so far so good. No more of either problem.
'Cept the enamel's all gone from my teeth. Maybe I should stop swirling it around so much and just drink the stuff. 😉
Citric acid acts as a buffer between a pH of 2 and ~8, which is higher than your stomach's pH. So even in lemon juice it's a bit of a dilution (nothing like water). It definitely does NOT become alkaline, just between two valencies.
The rest, unfortunately reads like hocus pocus. That said, if it gets you drinking more and seems to mediate indigestion, then great. Lemon juice is good for some nutrients too.
So carry on. But if you're dealing with acid reflux, there's some pretty decent pharmaceuticals that can help, acknowledging most folks like to avoid that as much as possible.
Good advice in general! My wife drinks a shot of cider vinegar everyday and belts it down. I'm a chemist and firm proponent of pharmaceuticals. It was kind of interesting being in grad school in the 70's..........
You can read up more on many different sites, some of which will take you through the process in greater detail. Really quite interesting. No, it's not mixing with water that alkalizes it. Let me go find something.Citric acid acts as a buffer
Well, I'm just talking physical chemistry here!
https://en.wikipedia.org/wiki/Citric_acid
I think they're talking about citric acid taking up an extra hydronium ion if it's put into a solution, e.g. an acidic buffer.
(I'm being pedantic, and want to reiterate if it's working for you, that is good 😀)
Back to your regularly scheduled food thread: I'm making carnitas this weekend (insert smiley smacking its lips).
I remember it is about the metabolizing of the lemon juice that creates the alkalinity and it sounds like you're light years ahead of me on this so...
Anyway, yes it works well for me, and at pennies per day (about 40 of them) I'll continue for now.
Love carnitas. Big batch of spaghetti sauce, meatballs and Italian sausage on the stove right now.
I was, as most everyone is, rather sceptical at first. Here's a little something to suck on.
An Italian Doctor Shocked the World: Cancer Is a Fungus That Can Be Treated With Baking Soda!(Video) - Collective Healthy
I'd expected you to talk Cal into 24/7 sipping of Limoncello.
(afair, lemon juice has a pH value of 2-3, the range that opens up the bottom pylorus valve)
The legalization of Everclear has spurred on a revival of the homemade stuff in our Italian community.
A man who doesn't know that's always on the table cannot be helped. ;-)
Everclear
Each time I see silly expensive packs of Vita Coco in a supermarket, I'm reminded of the affordable coconut water brands on offer at Asian stores for decades.
Startups backed by Hollywood, success guaranteed, a global economy with a new set of rules.
Monkey see monkey do. The abuse to traditional farming to convert to coco plantations is horrifying.
Monkeys Pick Coconuts In Thailand. Are They Abused Or Just Working Animals? : The Salt : NPR
Already on it boss.I'd expected you to talk Cal into 24/7 sipping of Limoncello.
Is that why I fart so much? I blamed in on Candida.(afair, lemon juice has a pH value of 2-3, the range that opens up the bottom pylorus valve)
I just use vodka or even white rum. Heck you can even make one with Stevia or Sucrella for the sweetener. Whatever is used, I cut back on it as I'm not big on sweet. Limes, oranges and grapefruit are all good too.The legalization of Everclear has spurred on a revival of the homemade stuff in our Italian community.
Careful, some of them contain no coconut at all.Each time I see silly expensive packs of Vita Coco in a supermarket, I'm reminded of the affordable coconut water brands on offer at Asian stores for decades.
My version of the Limoncello is underway as is another version using Kaffir lime leaves. Pics when the battery recharges. Mind you, they're not that exciting to look at. 🙂
I'll be making some lemon sauce later to go with my first attempt at Dolmades.
Entirely unremarkable really except perhaps that I'm using fresh vine leaves from my garden. Last year I composted the leaves I had to trim to let the (future) grapes get more sun but this year I'm making dinner!
Query: is Pudlowski's last France guide 2009? I traded some DIYAUDIO member lateral mosfets for a copy, but there seems to be no update.
Limoncello ends up looking like, well, urine.
- Member Areas
- The Lounge
- The food thread
