Cubie - small F5 variant with GR grade JFETs and LatFETs
well... done!
Will build it for a friend (2SJ74GR, 2SJ162, 2SK1058 Reichelt, 2SK170GR Dönberg).
Ok, let make the power supplies...
JP
Power supply. I´ll go mono and 2 versions: with CMC (WE) or resistor (SMQ). Schottkys are FSV1045V.
JP
hello Juma,
if i want to build this cubie for 50watt output power
how many pairs do i have to pararel the output TR?
is it still the same voltage rails and bias settings?
50W @ 8R means higher voltage power rails and cascoding JFETs at least, so it would be practically a new design.
Just adding more output pairs would take you to 50W only if you use very low Z speakers (1-2 R)
