TDA1541 with SAA7220 and resistor I/V I have found very subtle, and with Pass I/V it gives great depth. (I have a depth-enhancing 300B SET).
Note that with a passive preamp it is much better; while any active preamplifier might sound tense.
But that is in my home with my ears (certainly not going above 13k anymore, right even less, and I'm very sensitive to fast transients that quickly are heard as harsh highs).
This is also what I noticed.
TDA1541 or TDA1543 perform much better (sonically) with passive I/V solutions.
Any type of active circuitry (transistors, OPs) directly connected to the chip seem to
improve distortion (THD) but seriously degrade the sound.
Many people are skeptic about SAA7220, but the B version is really very good and
it has many features suitable for operation with TDA1541A or TDA1543.
I know John would not agree with me ;-) but to my ears, the SAA7220B + TDA1541A and
passive I/V with a good tube analogue stage (with all the extra perioherial circuitry
included) is still - after so many years of playing around - one of my two DAC references.
I have not listened to Johns latest DAC, but TDA1541A has something that no
other solution have seem to be able to produce.
I remember also a very good result on a high end stock CD player from TEAC Z serie something with a filtering chip (a Sony if I remember ?!) and 2 x TDA1541A...
Despite the simple usual oaps I/V + buffer it used to sound good.
To your ears, what are the qualities added by the tubes over solid-state with the TDA1541A please ? What topology did you like here for the tubes ?
If active sounds tense I pretty sure that capacitor values
used are pretty high be it SS or tubes.
I do not believe tubes "add" and OP amps or transistors "subtract" something from the music.
I have heard tube circuits that sound really bad. I believe the simplicity might be the trick here (simple circuits).
I just used the tube-circuit posted by John here many years ago (look back in this thread).
Thnaks, I should have this one on a folder, I readed twice John's thread and sometimes some parts of it even more (best electronic book ever 🙂 )
Did you test the tube feeded by the drift of current TDA outputt (Toersten technic iirc) ?
--------------------------------------------Thnaks, I should have this one on a folder, I readed twice John's thread and sometimes some parts of it even more (best electronic book ever 🙂 )
I am not familiar with such a problem. Could you elaborate please?
You must know it, this is more my inacurate words and understanding to write it!
http://www.diyaudio.com/forums/tubes-valves/197920-thorstens-tube-stage-tda1541a.html
http://www.raylectronics.nl/pdfs/Thermionic_Valvestages.pdf
Sorry but I cannot understand R10 and C4. Taking the signal down the drain. 😱 I would put them in series to the output . . .
----------------------------Hi,
Ok, now I see what you mean.
You can solve that problem much easier. But your schematics is slightly better.
I agree with the previous comments. I think the output network is wrong.
Do you know if someone already tried the SAA7030 which was for two TDA1540 but in simultaneous mode for the TDA1541A instead ?
I did. I transplanted a TDA1541A DAC board taken from a Cambridge Audio CD-3 into a Marantz CD-74. It worked without any issues. As I remember (it was a while ago) I removed the SAA7030 and connected the DAC to the SAA7000 directly.
hi ECdesigns, can we have a lead time when your amps and DAC will be available to purchase worldwide?
Just want to share this: A new TDA1541 Kit that support 384K Simultaneous data mode.
The SAA7030 only has 14 bits word length (for the TDA1540) but oversampled it behaves quite well like 16 bits NOS.
The TDA1541 should accept the fewer bits. But you must do it at 176 kHz.
I saw a SAA7030 kit from 2013 that outputs the simultaneous mode with a new upsampling chip. CDREAMS is the site.
Pics are not showing. 😱Just want to share this: A new TDA1541 Kit that support 384K Simultaneous data mode.
Thanks Albert,
I should try on a verroboard, I have a TDA1540 board from a Marantz cd player. IIRC the SAA7030 filter has less jitter than the filters made for the TDA1541A ?!
Well I assume 14 bits gives less listening details and a harscher top end...
... I found the TDA1540 to sound good with few tweakings though !
Hi.
I bought for my CD-371 one low jitter clock module from ebay (this) but it seems it doesn't work. I took out all clock related components around saa7220 and just connected main clock output to pin 11. The cd is spinning chaotically in both directions and never stop. If I try to connect also the ground of the module to cd player ground (pin 12 for eg) the spinning stops but then the rectifier diodes from the module go crazy hot (actually first time it burnt the CD player fuse). The module produce a nice 5.00 V for powering the TXCO but ... that's were my measuring capabilities are ending: I don't have a scope to see the output 🙁
If I put back the old clock the CD is working fine (except for the ERR message while trying to read TOC of some CDs but that's a different issue I guess)
Any ideea please? TX
Pin 11 of saa7220 - for xin and 12 (also on saa chip) for grounding. Do you think I should use digital ground on the tda (pin14)? I'll give it a try but I'm not confident about any difference. Tx
- Digital Line Level
- Building the ultimate NOS DAC using TDA1541A
