Beautiful construction as usual with all of your designs! Can't wait to read about your observations of the sound and measurements. I've always preferred the sound of BP4 & BP6 enclosures over Sealed and BR.
I am trying to get those answers too. From what I know until now, one can either use the DPC sensor or can use the flexible parameters, but I am not sure they can be both used at the same time. Probably when used in a horn, one can use only the adaptive parameters.I'm not entirely sure about that really. The literature imply that the sensor placement and polarity are crucial or instability will result. I would think that as long as the drivers are operating in phase into a common throat that the dpc sensor could be placed normally. However the drivers are mounted face to face and 180deg out mechanically. I've attempted to ask PS about sensor placement and operation with throat chambers and multiple driver arrangements but they ignored every question I've ever sent them. Unless you are an engineer with a huge customer for them, good luck getting any detailed information. Either that or they simply don't have the answers.
The adaptive parameters don't really interest me much. I won't be using them. Sure you can use advanced dsp to emulate a driver with certain performance characteristics but only up to a point where the driver or amplifier become a limiting factor. It cannot make the driver handle more power, have more linear excursion or change its efficiency. Likewise for the amplifier. As with any other type of normal dsp manipulation it only holds up until some limit is met after which it will start to revert to the ceiling of the native behavior and capabilities. If you design for the capabilities of the amplifier and driver to be what they are to begin with, the adaptive dsp shouldn't be needed much. It's a really cool technology which can do some very advanced things but I'd rather achieve the performance goals without heavy dsp if possible.
Little bit of an update. I have the cabs and have the 21-ipal's loaded into one. I've started on some preliminary testing. Some pics and impedance measurements below. I'm using wooden covers to block the vents and lower tuning but they are a bit leaky in the impedance measurements below. I'm going to figure out a way to get a better more solid seal and rerun them. I expect it will clean up and increase the magnitude of the low frequency peak below tuning a bit.
Cheers
Cheers
Actually a guy who contacted me about building some Othorn's and Gjallarhorn's built these for me. Yes he does good work.
Unfortunately my usual soundcard / mic preamp popped something inside of itself upon power up last night so it'll be a few days until I get back to any measurements while I figure out a replacement.
Hey Josh,
I've been using a Behringer UMC202HD for measurements recently and I've found it very good for what's needed, and they can be had remarkably cheaply.
I'm not affiliated with Behringer, but I do like some of their products. You'll probably want something nicer 😉
Very jealous of the IPAL drivers. Serious bits of kit.
Chris
Chris
where did you decided to put the dpc?
are you going to experiment with the positsion?
Hey Epa. I haven't decided yet. I'm probably going to try a normal baffle placement first. Start testing with small signals and work up towards higher levels slowly while monitoring. Make sure that is stable. If not I'll have to adjust until it is. That's a ways off though. I'm going to do regular amp testing first with an SP-12000 and a K20. I can do that first. Then I can take my time with the IPAL module doing tweaking and investigation.
Impressive creation! Josh, did you consider Push-pull loading during your design process?
I did not. It would cause an imbalance in the loading on the drivers and cones and complicate the throat area resulting in a larger more complicated cabinet. Any minor reduction in even order harmonic distortion would be offset by increased complexity and potential system instability. Modeling says that pressures in the throat may reach upwards of 14000Pa during testing. The B&C drivers already have very low distortion and the loading of this design I expect will result in harmonic distortion levels being quite low even at concert level output. we will see though.
I just posted all of the measurements from this cabinet with the 21Ipal drivers at DB for those interested in the objective data. No testing notes yet but those will be added later.
Testing was done as an active system with a Speakerpower Torpedo 6000 module with all available cabinet tunings and also with the usual Powersoft K20-DSP used with passive cabs. Testing with 21DS115-4 drivers will follow later this summer.
Looks good Josh,
I look forward to reading the notes.
Thanks Dan. it'll probably be a while before I get those up but I may have a chance to work on it this weekend. Testing season is proceeding full steam ahead this year.
Josh, I simmed a couple of (20-ish) other (cheaper) drivers and want to build a prototype for testing a few candidates. but looking at the simple plan I could not find the height of the cabinet only width and depth in the simple plan, can you enlighten me?
Internal height is 22.58. Its 24" outside dim using 18mm ply. If you just cut everything the same say 22.5 you'll be fine. As far as more reasonably priced drivers the newer 18rbx100 or 18lw2500 should be ok. 18sw115 works too. The fun starts at the 21ds115.
- Subwoofers
- Ricci's Skhorn Subwoofer
