807 Sound Quality?
?I would like lots of info on how is the 807/1625 sound?
Likely will be Russian G807 or the 12V G1625, input stage is 1 tube only 6SN7 or 6SL7, tube rectification, output is one single tube in Tetrode Single Ended A1 about 10W w/low NFB to drive one full range 94dB,8 ohms.
Thanks for help:00
94 dB. sensitive speakers need 8+ WPC, to satisfy Paul Joppa's 102 dB. rule.
The 807 is not a 6L6GC, with a top cap. Absolute max. plate dissipation is 25 W. and you, most definitely, don't want to go there. 21 W. should be safe enough. At 40% efficiency, power O/P will be 8.4 W., which is sufficient. 🙂
Take advantage of the high allowed B+ and regulate g2 B+, at a substantially lower value, say 250 V. Open loop linearity will be as good as it gets.
You will need a fair amount of NFB, in order to obtain a satisfactory damping factor. Given the overall open loop gain requirements, a 6SL7 section voltage amplifier seems right. Fortunately, the full "pentode" mode final exhibits low CMiller, which will not tax the wimpy driver triode.
ICAS (intermittent service) plate dissipation for 807 is 30 W. From my childhood experience as radio hooligan, these tubes can take tremendous abuse.
"Fair amount of NFB" would be a difficult proposition in SE.
ICAS is a very different situation than Class "A" audio, with its more or less constant dissipation. Exploiting an absolute maximum rating will lead to a short service life. I guesstimate that 21 W. is a fair approximation of design maximum.
Extracting sufficient gain from the voltage amplifier to support the requisite NFB level is easy enough. In what way is adequate NFB going to be a problem?
What sound of 6L6-oids, especially in SE, especially with no feedback?
Well, like a porridge of intermodulations.
What Anatoly said is yet another good reason for a substantial amount of NFB. Regulating g2 B+ at a fraction of anode B+ holds the IM distortion down, but doesn't completely eliminate it. NFB is a tool. When used judiciously, NFB is beneficial. Always start with maximizing open loop linearity and then apply the NFB.
Thanks again for explain🙂
How much NFB would be it in a 1625 20W dissipation?
IT would use variable NFB?
Never, ever, put an inter-stage trafo (IT) inside a NFB loop. We only just get away with O/P "iron" inside a GNFB loop.
IMO, variable NFB is not a good idea, but it has been used.
My seat of the pants guess is that approx. 15% of the speaker O/P voltage is a reasonable place to start. In any event, you want O/P "iron" rated for 15 W. or so. Magnetic headroom is needed to keep the deep bass error correction signal from saturating the core.
Another technique for preventing O/P "iron" core saturation is rolling infrasonic noise off at the amp's I/P. A simple RC high pass filter that "corners" in the 16 to 18 Hz. range gets the job done.
Noted, Thanks.🙂
This seems good. It substitute the NFB?
With this filter I dont need a NFB?
