Pi 3 with HiFi Berry DAC+ board and metal case
Very frustrated - I cannot get the internal wifi of the Pi to work properly. In AP mode the SSID appears randomly but I have never been able to connect to it. I have resorted to using an external wifi dongle (Pi official model) but I can't get this to work either.
I'm not sure if you've read previously on the history, but this is an issue with the HiFiBerry DAC+ board. You can confirm this by removing the HiFiBerry board and you'll find your RPI wifi then works properly.
It might be easier to just select a different I2S DAC board vice all of the fiddling with an external wireless dongle.
Dave.
Hi TimCurtis, thanks for your Moode.
I added NAS about 2TB flac, update has been completed. It has appeared full folders in NAS.
When i show Library, "library loading" has been completed, but it still no track in library.
I can only play music directly from the NAS folders, add to playback.
Please show me to do that?
My questions are as follows -
1. Should be dongle be attached to a powered usb hub in view of the DAC+ board?
2. I have disabled the PI's internal wifi/BT function, so how do I configure the wifi dongle - will this be wlan(1)? I would prefer to use the auto-config file method to set up the Pi to connect to my router's wifi and bypass the need for AP mode if possible. Could you suggest suitable auto-config file settings to do this please? 😕
Metal case is going to block signal from integrated Pi-3 Wifi/BT adapter. Also if you are running Hifiberry DAC+ Pro and not the DAC+, the occilators (clocks) on the Pro interfere with Wifi signal.
- start with fresh moode image
- connect ethernet cable --or-- take Pi out of metal case
- boot
- if no ethernet cable then connect via AP mode
- plug in external Wifi dongle
- turn off Pi-3 Wifi/BT adapter using System config
- shutdown
- unplug ethernet cable (if one was connected)
- power up
-Tim
It could be because:
1) The tracks aren't tagged. Library uses Genre, Artist and Album tags. If any of these tags are missing they are assigned a pseudo tag of "Unknown" which will appear in the Library.
2) The number of tracks is too large and the Library loader has bombed as a result of exceeding some internal resource (buffer, memory, php execution time, etc).
How many tracks in your collection?
-Tim
-Tim
My collection is about 40,000 tracks. Is there any solution?
Assuming that you have everything tagged correct you could try the following.
I don't know if this will help you or not, but I had a similar situation. I have the following directory structure on my NAS:
Code:
FLAC/
/Artists
/Classical
/Collections
/Hi-Res
If I configure the NAS Source using only the FLAC directory on the NAS the database updates but the library will never open. Insead, I created four NAS Sources:
Code:
FLAC/Artists
FLAC/Classical
FLAC/Collections
FLAC/Hi-Res
The library now opens without issue and every song is included in the library. My collection is a bit larger than yours.
Cheers, Bryce.
Code:FLAC/ /Artists /Classical /Collections /Hi-Res
Code:FLAC/Artists FLAC/Classical FLAC/Collections FLAC/Hi-Res
Cheers, Bryce.
I will try this solution. thank you very much.
Hi, just saying. If you need a beta tester for 3.5 I'm ready ;.)
all the best
+1
- boot
- shutdown
- power up
-Tim
Just FYI, Tim:
I looked at the pi3 wifi (when checking out the piZEROW)
The similarity of #'s stuck out to me, thought it was interesting:
Announce: piCorePlayer 3.10 - Page 57
Just FYI, Tim:
Hi Scott,
Hopefully, audio device makers are doing EMC testing to make sure their boards are designed so they don't kill WiFi on the Pi's.
-Tim
Internal Pi3 wifi works fine. Issues with channels related to Hifiberry DAC Pro with its built in clock, and shouldn't affect wifi or AP mode on a DAC+
I suspect your problem is this: Pi 3 with HiFi Berry DAC+ board and metal case
You've put a relatively low-powered wifi adapter inside a metal shield, thus cutting the signal by a ton of dB
Dave.
The problem is with the DAC Pro, not the DAC+
Hi Scott,
-Tim
Well we know of at least one HAT maker that didn't.
Anyone received their replacement Hifiberry DAC Pro, yet?
I'm surprised that Pi didn't fit a micro SMA connector for attaching an external antenna.
I can confirm that this is not a problem with the HiFiBerry DAC+. Mine works fine with WiFi. I don't have the pro, so I can't say anything about that.The problem is with the DAC Pro, not the DAC+
Sent from my Nexus 5X using Tapatalk
Like this...?🙂
https://hackaday.io/project/10091-raspberry-pi-3-external-antenna
https://www.adafruit.com/products/851
https://www.dorkbotpdx.org/blog/wramsdell/external_antenna_modifications_for_the_raspberry_pi_3
Wi-fi problem with RPI Zero W
first I want to congratulate Tom for a great Moode player.
I tried all the audio distributions and I think Moode is the best 😉
I have a RPI Zero W.
I want to use it in something like multifunctional DIY boombox.
The problem is that can't access web interface via WiFi
No problem to access the Moode interface via LAN to USB connector.
I made the WiFi configurations via cable connection.
After the reboot I tried to connect without cable but without success.
I've tried few times but the situation was the same.
There is no problem when I use LAN cable. Every time WiFi network settings looks correct but the Zero can't connect via WiFi.
Did I miss something in configuration or something other?
I have a RPI A (maybe the first model) and there I use USB Wifi dongle. I made the same configurations ant there is no problem to connect via WiFi.
Maybe the RPI Zero W is a new product and there is no drivers for the Wifi adapter in the Moode, it is possible ?
Noobie with Moodeaudio having audio problems on RPI3
Hi everyone at Moode, 1st timer be gentle.
7 weeks ago I installed and tried various streaming programs but got no audio from PC UI. Tried Volumio, piCorePlayer; Runeaudio and finally MoodeAudio. All with the same results. I reset all my equipment and upgraded every lead. (I Don't use WiFi, just Ethernet) Can you show me how I can hear the audio output from the RPI3 Moodeaudio on my PC?
Raspberry Pi 3 bundle
HiFiBerry DAC+Pro & Digi+Pro
4 TB USB HDD
16 gig Samsung Micro SD
SD Format
Win32Diskimager
PC i5 with HDMI TV monitor
16 gig ram
256 gig M2 HDD
4 TB Sata HDD
Asus Mobo
Virgin Media Cable Router 70 m/bits Connected with Ethernet cat 6 cables.
Marantz SR7011 AVR
PC connected to 'PC HDMI input' with HDMIv2 Cable (optional Digi optical and 5.1 Analogue) leads
RPI3/HiFiBerry Digi+Pro connected to 'Media Player HDMI input' with HDMIv2 also with Digi Coaxial Lead.
4 TB USB HDD
SD Format
Win32Diskimager
16 gig ram
256 gig M2 HDD
4 TB Sata HDD
Asus Mobo
Marantz SR7011 AVR
The 0W not supported in Moode 3.1 but will be in upcoming Moode 3.5 release.
-Tim
4 TB USB HDD
SD Format
Win32Diskimager
16 gig ram
256 gig M2 HDD
4 TB Sata HDD
Asus Mobo
Marantz SR7011 AVR
Unplug HDMI cable from PI and then follow Moode Setup Guide.
-Tim
- PC Based
- Moode Audio Player for Raspberry Pi
