500W PA amplifier with Limiter
One thing for sure: You can't safely use devices with a Vce rating of 100V as drivers in an amplifier that is fed from about +/-77V, the DC voltages after rectifying your 55-0-55VAC. Addidtionally, these TIP's aren't the most fastest ones. Perhaps you may ask for MJE15034/35's?
Best regards!
Best regards!
i used tips with 36-0-36 AC it works with good quality but not as powerful as the mje's on B500 it happened that suppliers here had stopped selling them, only the mje340/50 are on stock
any way i may deal with ebay and ali later...
thanks for the support
Apex B250
I just finished two B250, and tried to power up both of them and no one works. I connected the signal ground to power supply grround, dummy load 4 R, signal generator, and power supply +-80 volt. Nothing....everything it's cold, but no signal at output. What it's wrong or this pcb have some errors?
Is there wire jumper on your pcb?
higher rail problem
my b500 is working very good at 55 0 55 v dc ..Nice audio output ..but when I increase dc voltage to 75 0 75 v...it's clipping very fast i e at very lower audio level the clipping indicator glowing red and speaker sound flipping ....when I change bias resistor from 1.2k to 330ohms clipping occurs at higher level of Audio .but at clipping point the sound becomes distorted ...so what's the problem ??and what is the actual bias resistor for b500 tef at 75 0 75v dc ??
now working perfectly actually one mje15032 damaged due to inrush current flow .. actually I connect 1.5 kva 50 0 50 v ac transformer without soft start and inrush current damaged small components..
