State of the art of measurement microphones phase response calibration
Lucky me,
From linked thread above said:
I contacted iSEMcon GmbH, which also offers ECM8000 calibration services:
content.ibf-acoustic.com/catalog/product_info. php?cPath=21_23&products_id=76 (sorry for the space in the middle, the forum forced me to do that)
(see the sample data: these include phase response!)
I asked them what was their methodology for measuring phase response. Here is their (short) answer:
iSEMcon said:
The phase response above 500Hz is calculated from frequency response (inverse fourier transform calculated from my measurement software). In the range 10Hz to 500Hz it is relative to my B&K reference mic (measured in a small pressure chamber).
If their measurements are correct, this means the sample ECM8000 has a quite linear phase response throughout the whole spectrum, which contradicts Herb's affirmations. Now I'm confused...
I'm using a ECM8000 calibrated by iSEMcon with their phantom power supply/pré-amp. :)
Yes, but read the following comment.
The B&K 4133 is likely to have a flat phase response down to 3 Hz or lower, so the low frequency comparison test is kosher. For the upper freq phase test, calculating the phase from the freq response is only valid if you know that the source has a flat phase response, or the source has a known phase response (which means measured with a mic with a known absolute phase response)
It seems like a good point to me. Also, how do you 'match' the 500 Hz area between the two measurement techniques?
Also, the phase response from amplitude is only valid, mathematically, under certain properties of the signal. It is what they talk about when they mention the Hilbert transform.
That whole thread is an interesting read, and it looks like it might be the top of another Pandora's box.. go figure :confused:
I'm not worried, the phase angle shown isn't a cause for worries for me.
I can agree to the statements included in that tread from Dennis Sbragion.
But it's good to know my mic has been calibrated to mimic a high performer down low.
I knew that, that's why I got it. :)
On the top end there are many things that can influence the exact roll off, none of them really worrying me.
That's cool, wesayso.
Maybe somebody else is worried about it, though.
It seems like they should, if they want to make sure their speakers are phase accurate.
They might go through all the trouble of designing a phase correction filter, only to match their speaker to the phase response of a microphone that they don't know the phase of..
A 1/4" microphone capsule will pretty much have a minimum-phase response in the whole frequency range of interest, so you can actually get it from the magnitude response alone.
This is not easy to do down low using automated methods, as you would need a magnitude response that goes much lower than 10Hz to actually be able to calculate phase response down to that frequency.
That is why iSEMcon do not use calculation for the lower range and rely on actual comparison instead. It is still minimum-phase though, and even if information is missing to accurately calculate it, you can still manually predict it by interpolating the behavior of the mic down low.
There was a functionality introduced in rephase 1.1.0 that will let you do that:
- measurement compensate mode to manually replicate a given measurement
(eg replicating a mic calibration file and getting its missing
minimum-phase response, replicating a target curve, etc.)
It was rename to "inverse" in later versions.
I used it to retrieve phase information on my cross-spectrum (Herb) calibrated Dayton mic which was missing phase information.
You simply load the magnitude correction file, hide phase info (if any), inverse it, and then work your way through (minimum-phase) EQs to get it flat, as well as (minimum-phase) filters to model the high pass behavior (which is the critical part).
jmbee also did it and published a detailed description of the process (cannot find the link at the moment, not sure it was on this forum).
It work, and it also let you "rub out" some strange deviations in the correction response that look more like measurement/calibration process artifacts that real capsule behavior.
Well if there's one I know on here who was doing just that, from top to bottom in his room at the listening spot... I would be pointing at myself. Which is why I got the best alternative to the real expensive mics and moved on.
How on earth would you get an answer if there isn't anything you can do about it? Worry about the things you can control, like your listening environment. A flat measuring mic isn't going to cause a sudden phase change, however a reflection can do that.
Here is the correction I used for my mic (select all, copy, and load from clipboard in rephase).
Bypass the measurement to see the actual correction.
Code:
rePhase settings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Found an interesting comparison while I was digging those file.
In black you can see the original narrow-band correction file I got from cross-spectrum, with zero phase.
In green is the response with th phase behavior automatically calculated. This was done by DN92 (not an active member here, unfortunately). I don't exactly which methods he used but he tried several and tuned them to get the best result he could.
In red is the response obtained with the method above (not fine tuned, mainly focusing on the high pass behavior here).
I posted my comment hoping that somebody would know what to do about it.
I do agree with you on the listening environment considerations, but I hope there's a better way of doing things than just moving on.
@ pos
Thank you for the links and info. I don't have rephase as I'm just now starting to setup for my single driver speaker project.
I plan on correcting it with DSP, and that's why I asked myself the question I submitted here.
I can tell you and other people have put a lot of effort into solving this issue, and I wonder if this is really as good as it gets.
Is there really no way of knowing the phase response of a microphone without the assumptions that it is a minimum phase device for most of the spectrum, and the magnitude interpolation at lower frequencies to calculate the phase (or direct comparison with other microphones, that no matter how expensive and I'm sure great, still have the same problem of not knowing their phase response accurately)?
Get a mic that has phase correction data, like from iSEMcon or do as POS just told you, then move on ;).
Be sure to measure your complete audio chain too! Through loop back etc. at the sample rates you wish to use.
@ pos
What are you planning to correct, an anechoic listening environment? The minute phase deviation between 20-20.000 Hz in the mic isn't the biggest hurdle by far. It would be better to invest your time "where and when" you want to adjust phase out in a real room with real speakers.
What kind of speakers do you wish to correct? Will they still have the same IR response if you move up or down or left or right?
Once you did manage to make them perform top notch in that listening spot you'll notice your ears get a completely different picture to deal with. As we are listening with 2 ears on each side of that perfect measurement spot.
Just move that mic 10 cm left or right and run a measurement with both speakers to see what that does :eek:.
We will never run out of things to worry about.
Things like, where do I point my microphone... on axis to the speaker? Up a little? Straight forward to point between both speakers?
I don't disregard it (at least not completely).
But we have to be realistic. Choose your best option and move on. There will be larger things to worry about, as long as your mic is flat FR with an acceptable phase correction in your frequency range of interest.
I have done the linear phase down to DC thing. That didn't work for me. I now have minimum phase trough the pass band of my speakers. But I can't control the monitor speakers that were used to adjust the music by the mixing and/or mastering engineer. They might not be as correct in phase as my own speakers, yet they were used to adjust what I am listening to.
That might be a worse place to be at compared to the microphone. As well as our listening environment. Control what you can, look deep into what you can measure and put trust into the "reverence" you have. That whole thread you linked to had no valid options to offer.
It did have some info though. You seem focussed on possible wrong beings that might still exist. For me, seeing a surgical FR correction clean up my impulse is proof enough that I am close. The thing I have to worry about is when to stop correcting, as phase will only be correct at that exact spot in time and space. And it's not even where my ear is going to be.
Bypass the measurement to see the actual correction.....
Thanks share guidance this subject.
With focus on high pass behavior have a few quistions :).
1. When loading your setting from clipboard it set taps to 8192, wouldn't it be better set at say 131072 to get phase curve precision work down to DC component.
2. How is further procedure to create microphone txt correction file correctly that most programs request as correction file for microphone.
I don't remember what taps settings I used when generating the impulse, but it was more than 8192 as you can guess. Don't remember why this particular file is set to 8192.
Next step is to load the impulse in HOLM or REW and export the response curve to use as a correction file.
I should really include a "correction response" export functionality in the file menu...
sax512,
Could be wrong but think makes sense for high pass behavior try investigate numbers your chain perform and ensure all chain devices response is taken into count, then make a sealed woofer box and tune it to a known roll off with tools as real world impedance plus T/S parameter measurements and finally measure that known roll off very nearfield, any deviation that show up could be corrected with pos method.
Measurement microphones are used when correcting speakers through DSP filters.
However, it seems like the phase response of measurement microphones might not be as reliable as their amplitude response.
The state of the art of phase response measurement for these microphones is, for what I understand, as follows:
From a certain frequency up, the phase is calculated from its amplitude response. This can be done under the assumption that the microphone is a minimum phase device in that range.
For lower frequencies, where the calculation above cannot be performed due to amplitude response roll off, there are two methods:
a. Interpolation of the amplitude response, so that the calculation can be applied
b. Comparison to an industry standard measurement microphone, assuming its phase response is the right one.
Is there a more reliable way that doesn't rely on assumptions and calculations, but rather direct measurements?
