All in one chassis.
Such a professional work!
Very nice, soulmerchant. Can you give us any tips on how you cut the holes for the panels? It's a great result.
First marked them on the plate (print-out on thin paper carfefully taped to the plate before tapping the drill points.
Then with a very small bit as exactly as possible I drilled pilot holes.
Then I used a stepped drill bit, making sure it was well lubricated.
You might notice that the only visible screws are in the corners. All tubes are counter-sunk to the underlying plate, which need not be so pretty
I looked at this thread a lot for visual ideas and inspiration for this project
It's a 6sn7 cathode follower line stage.
Sorry, can't get pics to upload from my phone..... to be continued )
Motor Start Capacitors are rated for intermittent duty ONLY. Always use Motor Run Caps.Are you using motor start or motor run caps?
Ian
No. OPT:s are inside.
Toroidy TTG-6AS7PP from poland.
Omg, such a nice parts shop.. glad I read this forum.. how do the toroid OPTs perform from this company ?
Mr Ed, do I spot OD3 regulators there? got any more info on that?
It is a CLCLC supply split after the first choke , there is a CCS, OD3 and OB3 then out to the 6SN7.
- Tubes / Valves
- Photo Gallery
