Moode Audio Player for Raspberry Pi
Oh, and all other WLAN clients can work with the defective router and come with the connection clear. The raspberry with libreelec. The raspberry with raspbian, all are on the road with static address. Reset the router to factory defaults to re-enter all over the CLI although obviously the router is not the problem? Not a good idea.
And above all nonsensical
I don't know why you are asking us, you clearly know the most. Fix it yourself.
I offered the benefit of forty years of dealing with people that **** around with their kit. In my tens of thousands of calls fixing similar problems, and your clear lack of knowledge of the basics (such as correctly configuring your dhcp pool) my money is on it being YOUR configuration error.
Where is the alleged error in my configuration? At your place I would make small way
Code:
ubnt@ubirout:~$ show configuration
firewall {
    all-ping enable
    broadcast-ping disable
    group {
        network-group datenlan {
            description t-netz
            network 192.168.2.0/24
            network 192.168.3.0/24
    ipv6-name IPv6_WAN_IN {
        default-action drop
        description "IPv6 Pakete aus dem Internet ins LAN"
        enable-default-log
        rule 1 {
            action accept
            description "Erlaube bestehende Sitzungen"
            state {
                established enable
                related enable
        rule 2 {
            action drop
            state {
                invalid enable
        rule 5 {
            action accept
            description "erlaubt ICMPv6"
            log disable
            protocol icmpv6
    ipv6-name IPv6_WAN_LOCAL {
        default-action drop
        description "IPv6 Pakete aus dem Internet zum Router"
        enable-default-log
        rule 1 {
            action accept
            description "Erlaubt bestehende Sitzungen"
            log disable
            state {
                established enable
                related enable
        rule 2 {
            action drop
            log disable
            state {
                invalid enable
        rule 5 {
            action accept
            description "Erlaubt ICMPv6"
            log disable
            protocol icmpv6
        rule 110 {
            action accept
            description "Erlaubt DHCPv6 Pakete"
            destination {
                port 546
            protocol udp
            source {
                port 547
    ipv6-receive-redirects disable
    ipv6-src-route disable
    ip-src-route disable
    log-martians enable
    name WAN_IN {
        default-action drop
        description "WAN zu LAN"
        enable-default-log
        rule 1 {
            action accept
            description "Erlaube bestehende/in Verbindung stehende Prot."
            destination {
            state {
                established enable
                related enable
        rule 3 {
            action drop
            description "Stoppe undefinierten Status"
            state {
                invalid enable
    name WAN_IPTV {
        default-action drop
        description "IPTV Multicast"
        enable-default-log
        rule 1 {
            action accept
            description "Erlaube IPTV Multicast/UDP"
            destination {
                address 224.0.0.0/4
            log disable
            protocol udp
            source {
        rule 2 {
            action accept
            description "Erlaube IGMP"
            log disable
            protocol igmp
    name WAN_LOCAL {
        default-action drop
        description "WAN zum Router"
        enable-default-log
        rule 1 {
            action accept
            description "Ping erlauben"
            log disable
            protocol icmp
        rule 2 {
            action accept
            description "Erlaube Multicast"
            destination {
                address 224.0.0.0/4
            log disable
            protocol all
        rule 7 {
            action accept
            state {
                established enable
                related enable
        rule 8 {
            action drop
            description "stoppe undefinierten Status"
            log enable
            state {
                invalid enable
    name lan_in {
        default-action accept
        description "zwischen LAN"
        rule 1 {
            action accept
            application {
                custom-category Computer
            description "alles erlauben"
            destination {
                group {
            log disable
            protocol all
            source {
                group {
            state {
                established enable
                invalid disable
                new enable
                related enable
    options {
        mss-clamp {
            interface-type pppoe
            mss 1464
    send-redirects enable
    source-validation disable
    syn-cookies enable
interfaces {
    ethernet eth0 {
        description Internet
        duplex auto
        speed auto
        vif 7 {
            description Daten/VoIP
            mtu 1500
            pppoe 0 {
                default-route auto
                dhcpv6-pd {
                    pd 0 {
                        interface eth0 {
                        interface eth1 {
                            host-address ::aced:deca
                            no-dns
                            prefix-id 42
                            service slaac
                        prefix-length 56
                    prefix-only
                    rapid-commit enable
                firewall {
                    in {
                        name WAN_IN
                    local {
                        name WAN_LOCAL
                ipv6 {
                    address {
                        autoconf
                    dup-addr-detect-transmits 1
                    enable {
                mtu 1492
                name-server auto
                password ****************
                user-id [email]0xxxxxxxxxxxxxxxxxxxx1@txxxxxxxne.de[/email]
        vif 8 {
            address dhcp
            description IPTV
            firewall {
                local {
                    name WAN_IPTV
            mtu 1500
    ethernet eth1 {
        address 192.168.2.1/24
        description switch
        duplex auto
        firewall {
            in {
                name lan_in
            local {
        ipv6 {
        speed auto
    ethernet eth2 {
        address 192.168.3.1/24
        description Gigaset
        duplex auto
        firewall {
            in {
                name lan_in
            local {
            out {
        speed auto
    loopback lo {
port-forward {
    auto-firewall enable
    hairpin-nat enable
    lan-interface eth2
    rule 1 {
        description VoIP-SIP
        forward-to {
            address 192.168.3.115
            port 5060-5076
        original-port sip
        protocol udp
    rule 2 {
        description VoIP-UDP
        forward-to {
            port 5004-5020
        original-port 3478
        protocol udp
    wan-interface eth0
protocols {
    igmp-proxy {
        interface eth0.8 {
            alt-subnet 0.0.0.0/0
            role upstream
            threshold 1
        interface eth1 {
            role downstream
            threshold 1
            whitelist 232.0.0.0/8
            whitelist 239.35.0.0/16
    rip {
        interface eth1
        interface eth2
    static {
service {
    dhcp-server {
        disabled false
        hostfile-update disable
        shared-network-name lan1 {
            authoritative disable
            subnet 192.168.2.0/24 {
                default-router 192.168.2.1
                dns-server 94.75.228.28
                dns-server 62.141.58.13
                lease 259200
                start 192.168.2.2 {
                    stop 192.168.2.97
                static-mapping xxxxxxxxxxxxxxxxxx {
                    ip-address 192.168.2.110
                    mac-address 08:60:6e:69:7b:75
                static-mapping xxxxxxxxxxxxxx {
                    ip-address 192.168.2.100
                    mac-address 00:11:32:20:95:ab
                static-mapping xxxxxxxxxxxx {
                    ip-address 192.168.2.170
                    mac-address 64:51:06:e3:12:aa
                    ip-address 192.168.2.112
                    mac-address 00:23:14:72:a7:90
                static-mapping xxxxxxxxxxx {
                    ip-address 192.168.2.103
                    mac-address b8:27:eb:c8:ee:06
                static-mapping xxxxxxxxxx {
                    ip-address 192.168.2.150
                    mac-address 14:49:e0:68:f2:c0
                    ip-address 192.168.2.135
                    mac-address b4:52:7e:84:45:86
                    ip-address 192.168.2.210
                    mac-address 14:91:82:61:b1:e2
                static-mapping xxxxxxxxxxxxx {
                    ip-address 192.168.2.105
                    mac-address 00:90:a9:f7:aa:da
                static-mapping xxxxxxxxx {
                    ip-address 192.168.2.12
                    mac-address 00:0F:60:09:56:47
                    ip-address 192.168.2.116
                    mac-address 00:1f:1f:bc:07:b9
                    ip-address 192.168.2.127
                    mac-address 7c:dd:90:1e:59:a0
                    ip-address 192.168.2.200
                    mac-address dc:ef:09:e1:5a:0e
                    ip-address 192.168.2.102
                    mac-address f0:34:04:1e:c7:1d
        shared-network-name lan2 {
            subnet 192.168.3.0/24 {
                default-router 192.168.3.1
                dns-server 192.168.3.1
                dns-server 192.168.2.1
                lease 86400
                start 192.168.3.10 {
                    stop 192.168.3.89
                static-mapping Gigaset {
                    ip-address 192.168.3.115
                    mac-address 7c:2f:80:46:28:54
        use-dnsmasq disable
    dns {
        forwarding {
            cache-size 150
            listen-on eth1
            listen-on eth2
    gui {
        http-port 80
        https-port 443
        older-ciphers enable
    nat {
        rule 5010 {
            description "Maskiert ausgehende Adressen"
            log disable
            outbound-interface pppoe0
            protocol all
            type masquerade
    ssh {
        port 22
        protocol-version v2
    upnp {
system {
    host-name ubirout
    login {
        user norb {
            authentication {
                encrypted-password ****************
                plaintext-password ****************
            full-name Norbert
            level admin
        user ubnt {
            authentication {
            full-name Norb
            level admin
    name-server 185.93.180.131
    name-server 88.198.53.55
    ntp {
        server 0.ubnt.pool.ntp.org {
        server 1.ubnt.pool.ntp.org {
        server 2.ubnt.pool.ntp.org {
        server 3.ubnt.pool.ntp.org {
    syslog {
        global {
            facility all {
                level notice
            facility protocols {
                level debug
    time-zone Europe/Berlin
    traffic-analysis {
        custom-category Bypass-Proxies-and-Tunnels {
            name igmp
            name sip
        custom-category Computer {
            name Bxxxxxxx
            name "Web File Transfer"
            name Mxxx.com
        custom-category File-Transfer {
            name "xxxxxxxx"
        custom-category Streaming-Media {
            name rtp
            name VLC
            name xxxxxx
            name "xxxxxxxx"
            name "xxxxxxx"
        custom-category ntp {
            name ntp
        dpi disable
        export enable
traffic-control {
    advanced-queue {
        queue-type {
            hfq VoIP {
                description Telefon
                host-identifier sip
                max-rate 2mbit
vpn {
    ipsec {
        auto-firewall-nat-exclude disable
ubnt@ubirout:~$
Code:
firewall {
    all-ping enable
    group {
            description t-netz
        default-action drop
        enable-default-log
        rule 1 {
            action accept
            state {
                established enable
                related enable
        rule 2 {
            action drop
            state {
                invalid enable
        rule 5 {
            action accept
            log disable
            protocol icmpv6
        default-action drop
        enable-default-log
        rule 1 {
            action accept
            log disable
            state {
                established enable
                related enable
        rule 2 {
            action drop
            log disable
            state {
                invalid enable
        rule 5 {
            action accept
            log disable
            protocol icmpv6
        rule 110 {
            action accept
            destination {
                port 546
            protocol udp
            source {
                port 547
    log-martians enable
    name WAN_IN {
        default-action drop
        enable-default-log
        rule 1 {
            action accept
            destination {
            state {
                established enable
                related enable
        rule 3 {
            action drop
            state {
                invalid enable
    name WAN_IPTV {
        default-action drop
        enable-default-log
        rule 1 {
            action accept
            destination {
                address 224.0.0.0/4
            log disable
            protocol udp
            source {
        rule 2 {
            action accept
            log disable
            protocol igmp
    name WAN_LOCAL {
        default-action drop
        enable-default-log
        rule 1 {
            action accept
            log disable
            protocol icmp
        rule 2 {
            action accept
            destination {
                address 224.0.0.0/4
            log disable
            protocol all
        rule 7 {
            action accept
            state {
                established enable
                related enable
        rule 8 {
            action drop
            log enable
            state {
                invalid enable
    name lan_in {
        rule 1 {
            action accept
            application {
            destination {
                group {
            log disable
            protocol all
            source {
                group {
            state {
                established enable
                invalid disable
                new enable
                related enable
    options {
        mss-clamp {
            mss 1464
    syn-cookies enable
interfaces {
    ethernet eth0 {
        duplex auto
        speed auto
        vif 7 {
            mtu 1500
            pppoe 0 {
                default-route auto
                dhcpv6-pd {
                    pd 0 {
                        interface eth0 {
                        interface eth1 {
                            no-dns
                            prefix-id 42
                            service slaac
                        prefix-length 56
                    prefix-only
                    rapid-commit enable
                firewall {
                    in {
                        name WAN_IN
                    local {
                        name WAN_LOCAL
                ipv6 {
                    address {
                        autoconf
                    enable {
                mtu 1492
                name-server auto
        vif 8 {
            address dhcp
            description IPTV
            firewall {
                local {
                    name WAN_IPTV
            mtu 1500
    ethernet eth1 {
        description switch
        duplex auto
        firewall {
            in {
                name lan_in
            local {
        ipv6 {
        speed auto
    ethernet eth2 {
        description Gigaset
        duplex auto
        firewall {
            in {
                name lan_in
            local {
            out {
        speed auto
    loopback lo {
port-forward {
    hairpin-nat enable
    lan-interface eth2
    rule 1 {
        forward-to {
            port 5060-5076
        original-port sip
        protocol udp
    rule 2 {
        forward-to {
            port 5004-5020
        original-port 3478
        protocol udp
    wan-interface eth0
protocols {
    igmp-proxy {
        interface eth0.8 {
            role upstream
            threshold 1
        interface eth1 {
            role downstream
            threshold 1
    rip {
        interface eth1
        interface eth2
    static {
service {
    dhcp-server {
        disabled false
                lease 259200
                start 192.168.2.2 {
                    stop 192.168.2.97
                lease 86400
                    stop 192.168.3.89
        use-dnsmasq disable
    dns {
        forwarding {
            cache-size 150
            listen-on eth1
            listen-on eth2
    gui {
        http-port 80
        https-port 443
    nat {
        rule 5010 {
            log disable
            protocol all
            type masquerade
    ssh {
        port 22
        protocol-version v2
    upnp {
system {
    host-name ubirout
    login {
        user norb {
            authentication {
            full-name Norbert
            level admin
        user ubnt {
            authentication {
            full-name Norb
            level admin
    ntp {
    syslog {
        global {
            facility all {
                level notice
                level debug
    traffic-analysis {
            name igmp
            name sip
            name Bxxxxxxx
            name Mxxx.com
            name "xxxxxxxx"
            name rtp
            name VLC
            name xxxxxx
            name "xxxxxxxx"
            name "xxxxxxx"
            name ntp
        dpi disable
        export enable
traffic-control {
    advanced-queue {
        queue-type {
            hfq VoIP {
                description Telefon
                host-identifier sip
                max-rate 2mbit
vpn {
    ipsec {
ubnt@ubirout:~$
I lost interest in your problem when you called my post nonsense. I can see three glaring errors in your configuration. Sucks.
Good luck. With your obvious network superiority, you won't really need it, will you?
In my earlier post I stated that WLan worked with my HiFiBerry Digi+ Pro. I was mistaken, it doesn't. I was using a Digi+ until 2 weeks ago when I swopped to the Digi+Pro. Previously Wlan worked (I checked by swopping back). I should point out that I normally use wired lan for preference. Only changes I made were to system and MPD settings for the I2S devices. Although with the Digi+Pro WiFi shows as 100% signal strength with it's usual ip address it is not accessible.
I therefore have to concur with Tim and Melmac that there is a problem, but it is related to the Digi+ Pro, not Moode. My Digi +Pro is latest generation, so oscillator interference is a plausible explanation.
Nevertheless with the wired lan the system works well and sounds great. Thanks again to Tim for all his work.
Samba is a tried-and-true function, tested literally millions of times on this platform. It's much more likely to be your network - whether that's the router, Pi network adapter or whatever, is down to you to sort out.
Just because you can manage a low-bitrate ssh connection doesn't indicate a great-performing network.
Thanks for your answer.
Even if I must admit it left me a bit frustrated, I decided to investigate further and found (at least one of) the problem:
-It has nothing to do with my network or CIFS but has to do with the usb target I was trying to access to on the moode CIFS shares:
-If I copy to the SD card CIFS share (\\moode\SDCARD\*), speed is OK, but if I try to do anything on a USB target (\\moode\USB\My_Disk\*), then the speed is so worse than even a 1Mo file copy at 10-20Ko maxi, then gives a copy error before the end.
Same problem occurs whatever the USB target (usb key; 2,5 inch drive..)
I knew that the way the raspberry handle usb and network can cause bottleneck, but I didn't think it could be that worse in CIFS.
Did any of you experienced such situation, so I would consider it as "by design limitation", or should I investigate further ?
Thanks in advance.
I'm use MooneAudio with Rasperry Pi3 and Pi7 Touchscreen. All works very nice, but after 10 minutes the Touchscreen go blank. I tried many different methods to resolve this problem, but without any results. Can you help me?
Did you add touchscreen support by yourself or use an image? It may just be the screensaver coming on in which you can either extend the time (see post 6325), disable it, or just touch the screen to have it turn back on.
Last year there was a bug in the rpi software which caused the screen to not wake from sleep but that has been fixed for a while.
Sent from my iPad using Tapatalk
Think there looking into the problem of the Digi+Pro with it effecting the Pi's WiFi
https://github.com/raspberrypi/linux/issues/1588
Thanks in advance.
Try changing sync to async for your particular USB disks file system in the config file below, then reboot.
/etc/udisks-glue.conf
-Tim
Thanks in advance.
If you are using a USB wifi adapter, it may significantly impact throughput. I don't tend to copy across the network to USB devices attached to the Pi, and I now exclusively use the Pi3, with its built-in wifi adapter.
One easy test would be to connect using Ethernet and test your throughput.
Do you have the make and model of the wifi adapter you're using? Not all drivers are created equal...
static IP
It's worked out
Fresh image in the raspberry.
External Wlan at the Rasberry (hifiberry disturbs)
Turn on the Rasberry
In the router are displayed 4 leases, each 2 for each interface (eth0, internal wlan0). This happens only with Moode os, I've tested with several other clients, including Raspberry with other os.
The moode os with "moode.local call.
configure SSID, PSK
Disable the internal WLAN in the Webfrontend Configure system.
Moode os reboot.
With putty etc/network/interfaces and ifconfig.
Determine the valid Ip for Wlan0 (external)
In the router, the IP for the Wlan0 map.
Check if this IP, Moode os is accessible (not always the case)
Clear all leases in the router
Reboot moode os
Moode os with the valid IP call.
Otherwise the path to the NAS can not be saved
Configure - Network - here Wifi (wlan0) is on DHCP field, the gateway field, DNS field, IP field is not visible and thus not adjustable.
All functions in the LAN are given, the playing of Internet radio fails.
Wifi (wlan0) field switch to static, enter IP, gateway, DNS.
Then Internet radio is also available.
Moode os has its static IP
All attempts to set the IP directly at the first call of the Moode os fail even though in the config files correct values ​​after securing the configuration are registered.
My usual way with all other clients, Ethernet cable to a client, go to the configuration menu, activate Wlan interface, static IP, subnet mask, if necessary enter DNS, save configuration.
Done.
With the moode os is walked obviously a special way, or it is seriously not planned to set a static IP.
But the fact is, the Moode os is more stable in contrast to rune audio or volumio
Feature possibility - USB CD player
Hello
I very much like my NAS(flac)>Pi3(Moode)>i2s DAC>amp setup.
It would be handy however to be able to quickly play the odd CD, i.e. without having to rip, copy it across to NAS then update the moode library.
Which leads me to wonder... could it be possible plug a USB optical drive into the Pi3 and have moode use it as a source?
Here's to wishful thinking
Oli
Berichttekst: Hi, I am very new to this. I like to make an audioplayer which is DLNA 1.5 compatible and works with an I2S DAC. Can Moode do all this? Can it play all bitrates in the 44 and 48 kHz range upto 192 kHz 24bit? What setup of RPi and DAC do you recommend?
In its base configuration Moode is primarily Audio and has the ability to enable a UPNP interface for controlling the playback of music. The DNLA spec is based on UPNP so you will get some of what you want.
If you want to play music controlled by a phone application such as Bubble, Lumin or Linn Kazoo then yes you can do that with Moode.
As for the right Hardware Combo , there is a lot of personal choice, I use a Pi3 and HiFi Berry Digi+ to an external Dac and a PI2 with an IQAudio Dac couldn't confirm they are the best choices. Search this thread as somewhere Tim mentions what he uses and you can be sure they are tested thoroughly.
At the moment consider avoiding the HiFiberry Pro stuff if you are a newcomer as there are issues with these boards and RPI3 boards wireless.
If possible use a wired connection, for high bit rate music especially.
