Valve Itch phono
I think I don't need the PTFE sleeving, attached pic: are the black cables connected to RCA.
Do I see two sets of cables connected to the RCA jacks? This is definitely a recipe for additional unwanted capacitance, any way to tidy up and get rid of one of those cables?
The black ones appeared to be shielded as well, not what you want when capacitance is already a problem. Provided everything is enclosed and there is no AC (other than the signal) inside the box shielded wire is not needed and just adds capacitance. If the capacitance is 20pF - 30pF per 30cm or less it's probably not a concern otherwise you might want to consider changing it.
Attached pics, 1st pic probe x 1 direct to signal generator scope 50mV/cm, 3rd pic probe x 1 cathode V3 scope 1V/cm.
