I am encountering an issue while Biasing.
I could not dial down Bias below 1.2k on LSE and below 809 on RSE. What could be the problem?
When I replace with fresh LDRs, initially i.e, 1st RUN, i could adjust BIAS around 700k ohm and measured Resistances as explained..
Immediately after this when I try to caliberate its throwing 'Error 10' and after this point, when i try to measure the bias its showing 1.2k or above. I couldnt dial down.
Any one experienced this behavior or any solution you can suggest?
Replacing LDRs is an expensive affair for me so dont want to further experiment with available 2 pieces 🙂
When I measured Minimum resistance LSE 70.3 ohm, LSH 88.9 ohm, RSE 52.1 ohm, RSH 115.5 ohm
All are bought from element14 and all components are as per BOM no alternate parts used.
I have replaced another time the LSE LDR and now could bias to 700k ohm on all LDRs
Now its not caliberating and throwing 'Error 10'..
Am using zdr OLED code.
Any thoughts? suggestions?
See this for a hint :
// Error codes:
// 1 : left series could not be calibrated
// 2 : right series could not be calibrated
// 3 : left shunt could not be calibrated
// 4 : right shunt could not be calibrated
// 10 : left series LDR too low max value. Adjust trimmer RT1
// 11 : right series LDR too low max value. Adjust trimmer RT3
// 12 : left shunt LDR too low max value. Adjust trimmer RT2
// 13 : right shunt LDR too low max value. Adjust trimmer RT4
// 20 : cannot set LDRs or calibration relays. Analog and/or relay power supplies are not connected?
// 30 : configuration error: INPUTCOUNT and OUTPUTCOUNT out of range
Yeah, its so silly that I was adjusting bias by keeping DMM under 2k range than 2M 🙁
So in theory am doing 700ohm instead of 700K, when i tried this morning, all is well.. am about to update it over here.
Just a thought at this point as i have not tried..
There is a SMD version of the same component 5LN01C (SOT-23).
Though pin structure is slightly different, probably we can do little bit of innovation around and solder on other side of board as one of the pins (Drain) might require a jumper while 2 can fit current pads..
This will not compromise on the electrical parameters as they are exactly the same as that of 5LN01SP
Looks like 5LN01C is the way to go, PCB modification is trivial. I ordered few other alternatives to test, but they are also SOT23:
http://www.onsemi.com/pub_link/Collateral/NTA7002N-D.PDF
2.42" OLED might pose a problem however. I cannot find the one I ordered earlier anymore, all that I could find is SSD1309 based. While SSD1309 seems to be supported by U8G library, the operation will be slower than with SSD1306 Ascii, unless I figure something out in the code. There is no SSD1309 Ascii as far as I can see, for the time being at least.
My OLED SSD1309 I2C variant seems to work at least, but only when I press certain point on the PCB with my finger, since I got a dud from ebay seller. It will be a while until I get another.
I have the gerber files ready (I'll double check though) fets placed on the bottom layer
Before buying the LDRs I want to ask those who used SR3 ones, is the minimum volume a problematic, i.e. too loud before going to mute ?
Any other problem other than calibration hassle ?
finally my PCB is soldered, but when I try to upload the code I got an error like this :
D:\Oude PC\Documents\Hobby\arduino\arduino preamp\firmware_LDR_v1.0\firmware_LDR_v1.0.ino:14:26: fatal error: PinChangeInt.h: No such file or directory
#include <PinChangeInt.h>
Where can I find that PinChangeInt.h ?
Ronny
Ronny
OK, think I found the right files.
New problem : I Have a 20*4 display, but if I type :
// Specify the LCD size here
// Only 20x4 and 16x2 are supported
#define LCDCOLUMNS 20
#define LCDROWS 4
then I only have 2 bars, if I type 16 and 2 then I got text in the 2 upper rows.
Ronny
#define LCDROWS 4
Ronny
Apart from calibration hassle, no other issues I could find so far. Both SR2 and SR3 have a volume "bump" though.
My 16x02 look like your 20x04 on first startup and I had to turn the trimmer on the IC2 module of the LCD to make it clear.
I am a total newbee in this Arduino thing so please do not slab me too hard ;-)
Sorry for the long post, but I don´t know what is relevant..
I try to compile the source code but get this error message:
Arduino: 1.6.10 (Windows 10), Board: "Arduino Nano, ATmega168"
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino:33:54: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* inputName[INPUTCOUNT] = { "DAC IN", "PHONO IN" }; //** each name maximum 9 characters. There must be exactly INPUTCOUNT names in the list.
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino:36:67: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
char* outputName[OUTPUTCOUNT] = { "LINE 1", "LINE 2", "HEADPHONE" }; //** each name maximum 9 characters. There must be exactly OUTPUTCOUNT names in the list.
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'byte doCalibration()':
firmware_LDR_v1.0:401: error: 'setLCDMaxLight' was not declared in this scope
setLCDMaxLight();
firmware_LDR_v1.0:422: error: 'printTick' was not declared in this scope
printTick();
firmware_LDR_v1.0:636: error: 'printBar' was not declared in this scope
printBar(percent);
firmware_LDR_v1.0:885: error: 'printBar' was not declared in this scope
printBar(percent);
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void setMute(byte)':
firmware_LDR_v1.0:1089: error: 'printTwoNumber' was not declared in this scope
printTwoNumber(VOLCOL, volume);
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void setInput()':
firmware_LDR_v1.0:1096: error: 'lcd_print' was not declared in this scope
lcd_print(inputName[chan_in], 9);
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void setOutput()':
firmware_LDR_v1.0:1125: error: 'lcd_print' was not declared in this scope
lcd_print(outputName[chan_out], 9);
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void setVolume(byte)':
firmware_LDR_v1.0:1568: error: 'printTwoNumber' was not declared in this scope
printTwoNumber(VOLCOL, vol);
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void setup()':
firmware_LDR_v1.0:1612: error: 'sinMap' was not declared in this scope
analogWrite(PIN_LCDBRI, sinMap(i, 0, LCDBRI_MAX, 0));
firmware_LDR_v1.0:1618: error: 'defineCustomChar' was not declared in this scope
defineCustomChar();
firmware_LDR_v1.0:1620: error: 'setLCDMaxLight' was not declared in this scope
setLCDMaxLight();
C:\Users\benedikte\AppData\Local\Temp\Temp1_VxD LDR Controller rev1.zip\firmware_LDR_v1.0\firmware_LDR_v1.0.ino: In function 'void loop()':
firmware_LDR_v1.0:1709: error: 'startLCDFadeIn' was not declared in this scope
startLCDFadeIn();
firmware_LDR_v1.0:1769: error: 'startLCDFadeIn' was not declared in this scope
startLCDFadeIn();
firmware_LDR_v1.0:1835: error: 'startLCDFadeIn' was not declared in this scope
startLCDFadeIn();
firmware_LDR_v1.0:1927: error: 'sinMap' was not declared in this scope
LCDcurrentPW = sinMap(mil_delta, 0, TIME_LCDFADEIN * 1000, LCDinitialPW);
firmware_LDR_v1.0:1931: error: 'setLCDMaxLight' was not declared in this scope
setLCDMaxLight();
firmware_LDR_v1.0:1939: error: 'sinMap' was not declared in this scope
LCDcurrentPW = sinMap(mil_delta, TIME_LCDFADEOUT * 1000, 0, LCDBRI_MIN);
firmware_LDR_v1.0:1943: error: 'setLCDMinLight' was not declared in this scope
setLCDMinLight();
firmware_LDR_v1.0:1949: error: 'startLCDFadeOut' was not declared in this scope
startLCDFadeOut();
Multiple libraries were found for "Adafruit_MCP23008.h"
Used: C:\Users\benedikte\Documents\Arduino\libraries\Adafruit_MCP23008
Not used: C:\Program Files (x86)\Arduino\libraries\Adafruit_MCP23008
Multiple libraries were found for "PinChangeInt.h"
Used: C:\Users\benedikte\Documents\Arduino\libraries\PinChangeInt
Not used: C:\Program Files (x86)\Arduino\libraries\PinChangeInt
exit status 1
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.
setLCDMaxLight();
printTick();
printBar(percent);
printBar(percent);
defineCustomChar();
setLCDMaxLight();
startLCDFadeIn();
startLCDFadeIn();
startLCDFadeIn();
setLCDMaxLight();
setLCDMinLight();
startLCDFadeOut();
exit status 1
I took a I2C scanner, and it was address 0x20 and not 0x27 but the result is the same.
I ordered another display, so have too wait a little.
Ronny
Ronny
Koldby,
are you sure your Arduino is ATMega168 ?
Check in Arduino "Preferences" where the location is from your libraries, and remove all the others from that other directorie.
Ronny
Ronny
As far as I can see it doesn't matter which Arduino type there is on my board as it is not when I try to upload the code , but when I try to compile it the errors appear. The board is not even connected to the PC.Koldby,
Ronny
If I remove all libraries from both the lib folder in /documents and /programs and only put the libraries from LDR controller in the /programs I get this:
setLCDMaxLight();
printTick();
printBar(percent);
printBar(percent);
defineCustomChar();
setLCDMaxLight();
startLCDFadeIn();
startLCDFadeIn();
startLCDFadeIn();
setLCDMaxLight();
setLCDMinLight();
startLCDFadeOut();
Multiple libraries were found for "LDRstruct.h"
Used: C:\Program Files (x86)\Arduino\libraries\VxD_OLED_ADA_ASCII
Not used: C:\Program Files (x86)\Arduino\libraries\LDR_1602_LCD
exit status 1
I have the OLED display.
All this makes absolutely no mening to me.
koldby, you need to have all three files (screen.ino, firmware_LDR_v1.0.ino, LDRstruct.h) in the same folder named firmware_LDR_v1.0.
The error messages are related to missing functions declared in the screen.ino file. The i2c-address of your display should only matter after code was successfully compiled (i.e. you should not be able to access the display in case the wrong address is used).
But I have all the files in the same folder.. Just checked it.
The same holds true for the VxD LDR Controller rev1 folder and diyaudio-ldrcontroller-develop folder. All of them cannot be complied no matter what I do.😕
Is it my version of Win 10 that is playing tricks on me? Should I try it on another computer?🙁
- Analog Line Level
- Arduino based LDR volume and source selection controller
