New FIFO buffer for RPI/SBCs
We designed it to work with any PSU including switching ones. We filter the power plane multiple times for each : analog , digital and oscillators.
Our internal testing was done with our 5V psu...Of course a better PSU will have even less noise/ripple
I have Kali+AK4490 working with Moode 3.1, but I have to resample to 24bit or else I get a blast of noise. I get loud clicks sometimes when engaging 'Play' or 'Pause'.
So I'm wondering, Pistollero/Greinedo, whether you had the 4495 working without these issues? I must say the sound is very good. I'm taking the output through UTC-A20 transformers.
John
Hi John,
I am glad you have also tried this combo. The sound is very good for me. I suppose you have connected the Master Clock of the Kali to the AK4495, wich may be one reason of the good result.
On my Kali+4495 I also experienced clicks at Play/Pause Stop/start with Moodeaudio 3.1. After some tests, it seems to me that UPnP protocol is the problem.
I installed LMS (Logitech Media Server) on one of my Linux PC + LMS UPnP plugin and activated Squeezelite renderer on Moodeaudio. Now I can choose between UPnP protocol or Squeezelite. Conclusion : LMS with Squeezelite protocol plays very nice on my Kali+AK4495 setup (no clicks, etc) while LMS whith UPnP suffers from those clicks at stream interruptions.
Moreover, I think Squeezelite renderer sound is better. LMS + Squeezelite renderer in Moodeaudio is my current setup. It integrates also a lot of plugins that are important for me like Deezer and Qobuz that Moodeaudio currently does not offer.
I have been experimenting with PSs. The KALI/Piano sound is hugely influenced by the supply feeding it. I am surprised this is the case since there seems to be plenty of filtering on board.
The most significant improvement was changing from a toroidal transformer to an EI type. I also recommend using the centre tapped FW rectification method using two diodes, rather than the usual parallel transformer windings and a FW rectifier bridge. The seems to make more difference to the sound that the type of regulator used!
Sure is an exotic looking film cap on the LT3042 analog side:
And yeah! Finally separate regulator/filter on the clocks (just in general):
This hasssss to more than the Ti/BB PCM51xx deserves 😉
Need to get the drivers open-sourced & in the official linux!
...and interesting overkill supercap--
Boss pics look very good. I'm very curious to hear reports on it. And even more curious to get one to play with.
Love those SMD film caps... see here:
http://www.diyaudio.com/forums/digi...ry-dac-pro-hw-mods-anybody-3.html#post4626613
here:
http://www.diyaudio.com/forums/digi...ry-dac-pro-hw-mods-anybody-2.html#post4617021
(with more details on the overall mods to the HiFiBerry DAC+ Pro here:
http://www.diyaudio.com/forums/digi...ry-dac-pro-hw-mods-anybody-2.html#post4625603 )
And here:
http://www.diyaudio.com/forums/digi...amboberry-ls-my-new-pi-hat-5.html#post4904623
I've seen them used in other commercial gear, specifically the Ayre Acoustics DACs, the K&K Audio RAKK DAC, and the Sony HAP Z1-ES.
Everywhere I've used them I've been rewarded with a sense of sweetness, transparency, and inner instrumental timbres that are beyond what I thought possible for that unit.
Then the Supercap... I first saw that suggested as a useful add-on to DAC power supplies in Joe Rasmussen's thread here:
http://www.diyaudio.com/forums/digi...entations-alternative-post-dac-filtering.html
I haven't tried it yet, but will in a few weeks on a current project. I'm glad the Allo designers tried it and liked it.
One of my more recent projects has me convinced the PCM5122 has a lot more potential than most realize. I duplicated my 14-linear supply generic digital setup for my 2nd system. 7 of the supplies are used for the LMS-computer and the various networking components, with the rest available for various DAC setups using from 2 to all 9 source/DAC supplies.
The DAC supplies are a bit better than my first iteration, using higher-current toroids and the 2-diode FW rectification scheme mentioned by Dave above.
Currently I running the modified HiFiBerry DAC+ Pro shown in the first link above, replacing the modified Sony HAP Z1-ES in that system... I described the mods to the Sony here:
http://www.diyaudio.com/forums/digi...1es-hi-res-source-new-2014-a.html#post4440620
and here:
http://www.diyaudio.com/forums/digi...1es-hi-res-source-new-2014-a.html#post4443476
With the setup's AC-powered supplies and the HFBD+P in slave mode on a well-powered Allo.com Kali, it edges out the modified Sony. BUT using 3 Uptone Audio LPS-1 floating Ultracap supplies to power the Kali and the digital and analog sides of the PCM5122 pushes the modified-beyond-recognition lowly PCM5122-based $45 retail HFBD+P decisively above the modified Sony and 2nd only to my two Soekris setups.
I never thought this lowly DAC with the down-market PCM5122 could sound so good!
So I have HIGH HOPES AND EXPECTATIONS for the BOSS!
Greg in Mississippi
I might go in, change the d+pro overlay from 22,24 to 45,49 -- hack the registers to use MCLK and compile it -- to avoid volumio ;P -- let's just say the test build is a tower, of a 52 card deck about 40 stories tall
