lol.
It needs to be tested with DAC's that don't have hardware volume for example Mamboberry LS or other ES9023 based DAC.
If someone wants to try this please post results.
-Tim
I have a Mamboberry but get this errors when I try:
Loading Spotify library...
Traceback (most recent call last):
File "loader.py", line 3, in <module>
File "runpy.py", line 180, in run_module
File "runpy.py", line 72, in _run_code
File "/home/pi/spotify-connect-web/main.py", line 14, in <module>
from connect import Connect
File "/home/pi/spotify-connect-web/connect.py", line 9, in <module>
from console_callbacks import audio_arg_parser, mixer, error_callback, connection_callbacks, debug_callbacks, playback_callbacks, playback_setup
File "/home/pi/spotify-connect-web/console_callbacks.py", line 24, in <module>
audio_arg_parser.add_argument('--mixer', '-m', help='alsa mixer name for volume control', default=alsa.mixers()[0])
IndexError: list index out of range
Failed to execute script loader
Lazerharp, that is telling you that you need to pass a valid mixer value. What command did you use to execute the spotify-web-connect script? Are you running from source or downloaded the compiled version?
Interested in a skype call so we can maybe sort out things together?
Best regards,
Rafa.
Best regards,
Rafa.
Best regards,
Rafa.
Thanks Rafa for the fast reply.
I followed your instructions from here:
https://github.com/RafaPolit/moode-spotify-connect-web/blob/master/README.md
I got --playback_device from running Aplay -L
default:CARD=Mamboberry
Mamboberry,
Default Audio Device
sysdefault:CARD=Mamboberry
Mamboberry,
dmix:CARD=Mamboberry,DEV=0
Mamboberry,
Direct sample mixing device
dsnoop:CARD=Mamboberry,DEV=0
Mamboberry,
Direct sample snooping device
hw:CARD=Mamboberry,DEV=0
Mamboberry,
Direct hardware device without any conversions
plughw:CARD=Mamboberry,DEV=0
Mamboberry,
Hardware device with all software conversions
Then I got --mixer_device_index running Alsamixer then F6 to get Soundcard 0 Mamboberry
Then I tested with:
./spotify-connect-web --playback_device default:CARD=Mamboberry --mixer_device_index 0 --bitrate 320 --name "moOde Connect" --key spotify_appkey.key
The -m or --mixer command is actually DIFFERENT from the --mixer_device_index.
For external DAC, you could try a "-m PCM" argument on that command. For DACs that don't support Hardware Volume, theres a different approach we were discussing of creating a new 'virtual' mixer. All this is to allow volume control.
So, first, attempt this command line:
./spotify-connect-web --playback_device default:CARD=Mamboberry --bitrate 320 --name "moOde Connect" --key spotify_appkey.key
This should work without volume control! (Also, this requires that you launched the avahi zero-conf script prior to running this command, or you will get a missing username and password error).
Rafa.
edit: Im an idiot, I edited the command line.
Rafa.
For volume control, this is exactly the setup we needed to test it up. Can you post the result of the command:
amixer controls
This should give us an overview of what mixers you have available.
Rafa.
Still dosen´t work when I run:
When I run amixer controls I get nothing
What is the error of spotify-connect-web script without -mixer_device_index?
Ok, great, you are the perfect candidate for this actualy! This is what (I believe) Tim was expecting. A setup that provides actually NO hardware option at all.
The steps are going to be a bit longer for you:
Create a file inside /etc/ named asound.conf (you will need to use sudo and the editor of your picking).
The content of the file should be:
After this, the amixer controls command should give you an entry for "Master".
Now run everything with:
./spotify-connect-web --playback_device softvol -m Master --bitrate 320 --name "moOde Connect" --key spotify_appkey.key
There is slight chance that the hw:0 wont work. If that happens, please post the result of:
aplay -l
(lower case L)
Rafa.
Code:
pcm.softvol {
type softvol
slave {
pcm "hw:0"
control {
name "Master"
card 0
aplay -l
(lower case L)
Rafa.
--playback_device hw:0
./spotify-connect-web --playback_device hw:0 --bitrate 320 --name "moOde Connect" --key spotify_appkey.key
and/or try Rafa's 'softvol' approach in previous post
-Tim
-Tim
Unfortunately same error:
Is this error happening also with the custom asound.conf file?
Sorry. No haven´t tried yet. Can you specify the exact path? Must I start it somehow?
The file should go in /etc/.
So:
should create the file. Then you can sudo nano, or sudo vim into it to edit it, however you prefer to edit your files. It doesn't need to be started.
After that amixer controls should hold at least one value, and then the command:
should start the server with software volume enabled.
If not, please post the aplay -l results.
Rafa.
So:
Code:
sudo touch /etc/asound.conf
Code:
Rafa.
So:
should create the file. Then you can sudo nano, or sudo vim into it to edit it, however you prefer to edit your files. It doesn't need to be started.Code:sudo touch /etc/asound.conf
should start the server with software volume enabled.Code:./spotify-connect-web --playback_device softvol -m Master --bitrate 320 --name "moOde Connect" --key spotify_appkey.key
Rafa.
Sorry, still same errors.
aplay -l gives:
**** List of PLAYBACK Hardware Devices ****
card 0: Mamboberry [Mamboberry], device 0: Mamboberry DAC HiFi es9023-hifi-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
amixer controls gives nothing
aplay -l gives:
Subdevices: 1/1
Looking at the Python code there is no default for coded for mixer-device so apparently the param has to be specified.
So try adding --mixer_device_index 0 to the cmd string
-Tim
And, just to confirm, what is the result of:
cat /etc/asound.conf
My skype offer is still available!
pcm.softvol {
type softvol
slave {
pcm "hw:0"
control {
name "Master"
card 0
Thanks for the Skype offer but I am trying to work at the same time
-Tim
Sorry,still same errors .
- PC Based
- Moode Audio Player for Raspberry Pi
