DAC ES9038 PRO Group Buys
Hello, a pair of questions:
1) Can i use another USB transport with I2S output instead of Amanero, like Jlsounds' I2SoverUSB?
2) Can i use a Raspberry PI with I2S output as player source (possible issues due to oscillator frequency communication)? ES9018 Buffalo III boards allow that.
Hi quanghao.
Is´t possible to use your dac in doble mono configuration?
I don´t have problem to modify arduino code to support two chips if you provide me the code.
ES9038pro no need to use two chips because:
1. 9038 is very expensive.
2. ES9038 current = 3 times 9018 current
please see image 9038 vs 9018.
thanks
you can use other USB with pin connect: see image
yes, you can other clock with pin connect, see image
thanks
I need a minimum of 15 people to help me implement this project. Thank you very much!
DAC ES9038 Pro have these features: : Design by Andrea-Quanghao
Ouput: Stereo - 2 Channels 8 to 1 parallel
- PIC Microcontroller to remap DAC and share I2S connection with DSD signals
- Amanero module integrated to have USB input
- Support 44,88,96,192,352,384KHz PCM tracks
- Support 64,128,256,512 DSD tracks
- Able to play also SACD ISO from PC
- Full ground isolation from USB module
- On board reference 100MHz TKD oscillator
- Ultra fast oscillator buffer
- 4 inputs: USB, Spdif coax on BNC, AES/EBU Professional on XLR, Optical Toslink.
- Many output stages choice
- 4 row x 20 characters LCD
- Controller compatible with any 5V LCD and VFD
- Simple and cheap firmware upgrade
- Large dB volume display
- Ultralow Noise, Ultrahigh PSRR RF linear power supply regulator
- Separated LT3042 for any digital section
- Separated LT3042 for any analog channel
- Remote volume control
- Remote mute control
- Remote input control
- Digital filter control
- Stanby control
ES9038 DAC MODULE
The DAC module use a dedicated power supply with LT3042 separated for any section of the ES9038PRO:
Digiltal supply:
- 1.2V core: LT3042
- 3.3V oscillator: LT3042
- 3.3V digital: LT3042
- 3.3V Top-botton chip
- 3.3V USB: LT3042 (If you not like us 3.3v from Computer for USB)
Analog supply:
- 1.2V analog (left and right separated): LT3042
- 3.3V analog (left and right separated): LT3042
- 5V for LCD: LT1117
- 5V Analog supply: LT117
- 5V Digiltal supply Digiltal supply: LT1117
All the power supply use a LT3042 Ultralow Noise, Ultrahigh PSRR RF Linear.
This module the ES9038PRO when connected to the controller module can be configured to select 4 different inputs with button or remote:
- I2S/DSD to use with USB OEM Combo 384 (Amanero), There are pin for othe USB
- This DAC match with Amanero USB
- Coax Spdif RCA
- AES/EBU professional transport on XLR
- Optical Toslink.
This options are available and here the new cost:
1) DAC module assembled and tested with all components:
- ES9038PRO chip,
- CCHD-575 Ultra-Low Phase Noise Crystal Oscillator: http://www.electronics-eetimes.com/news/ultra-low-phase-noise-cmos-oscillator-provides-168-dbchz-noise-floor
- 7 x LT3042 linear power supply regulator 1uV noise
- 5 x LT1117 linear power supply regulator.
- All input connectors
- BUT NO OUTPUT STAGE
price 400$
2) DAC controller- Encorder + 4x20 LCD:
see video for LCD: https://www.youtube.com/watch?v=4owu...ature=youtu.be
- 20x4 LCD
- Infrared remote command
- Remote silver
- All connectors
price 150$
3) Amanero module
price 60$
4) Transformers, for the DAC: 6.5V x 2 / 15VA
price 30$ each
5) Chassie: include: weighs: 10 kg
- 1 x chassis, iron powder coated black, size: 420 x 380 x 86 mm,
- 1 x front surface silver anodized scratch: 430mm x 92mm x 10mm.
- 4 x rubber feet: 20mm high, 50mm wide
- 2 x aluminum knob 26mm x 38mm
- 1 x Plug + switch
- 20 x copper base 10 x 3 mm
- fasteners: catch the front, the back, motherboards, storage tank foam.
price 150$
Please write your nick to the list below with the choices you love:
1. bvtrinh : options : 1 to 3
2. chriselm: : options : 1 to 3
3. Zander Araujo : 1 to 3
4. lindamar : options : 1
5. akltam option 1,2,3,4,5
6. yos75: 1,2grec13;4925085]Count me in.
7.grec13 : 1 to 3
8.myint67 :1 to 3
9. bosmaworks : 1,2,3,4,5. I would also like to order the PCBs for a complete tube output stage.
10.
15
Thanks!
Update
1. bvtrinh : options : 1 to 3, HQ-IV tube output and HQ-HV power supply
7.grec13 : 1 to 3
8.myint67 :1 to 3
10.
15
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11.
15
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11. smanz: 1,2
12.
13.
14.
15.
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11. smanz: 1,2
12.j pduarte: 1, 2, 3
13.o
14.
15.
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11. smanz: 1,2
12. j pduarte: 1, 2, 3
13. AlphaC: 1,2,4,5. I would also like to order the PCBs for a complete tube output stage
14.
15.
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11. smanz: 1,2
14.faninos: 1 to 4. I would also like to order the pc a for a complete tube hq hv power supply
15.
7.grec13 : 1 to 3
8.myint67 :1 to 3
10. mjensen: 1,2,3
11. smanz: 1,2
14.faninos: 1 to 4. I would also like to order the pc a for a complete tube.
15.
7.grec13 : 1 to 3
8.myint67 :1 to 3 (complete test and run tube output stage with power supply)
10. mjensen: 1,2,3
11. smanz: 1,2
15.
