Nord NC500
Hi everyone not sure if I should post this here but I have decided to sell my two Nord UP NC500 Black Monoblocks.
There is nothing wrong with them they are working perfectly and sounding great and they still look brand new without any marks or scratches.
But due to a change in circumstances (downsizing) I need to sell all my gear and get an all in one system which I am not entirely happy about.
They are exactly one year old and are fitted with the Rev. C input buffers and Sonic Imagery 994 op amps. I also have a pair of little used Sparkos SS3602 op amps to go with them and the original Hypex buffers.
They have not been used that much as I only play music for 5/6 hours each week.
If you are interested please send me a PM with an offer.
I still have all the original packing so no problem to despatch by courier.
Hi everyone the Nords are now sold, thanks for all the interest shown by everyone.
Hey Boggit, FWIW when you advertise your amps (e.g. on Audiogon) you should make sure to advertise their specs correctly. The Ncore 500 amp modules have a shocking 1% distortion 400W into 8R. The "typical" distortion figure of 0.001% (which is 'decent') is for when the amps are driven to just half their rated power into 4R.
We are using these Hypex NCore NC252MP in our new MP range of amps including a 8 Channel amp with 250W into 4Ohms and 200 8Ohms per channel.
Stereo MP 500W amp now shipping £849 with the £749 Stereo 250W shipping second week of January. Multi Channel amps to follow shortly after that. Based on these.
Happy New Year
Happy New Year
Yes, it is 'Mains Powered'Is that a module with integrated PS
No, it is the Hypex version of Hypex nCorei.e. the Hypex version of an Icepower ASX2 or Anaview AMS?
Please note these specs are peak power at 1% THD / 1kHz.
To compare with more conventional amplifiers (especially w.r.t. cooling), the continuous power rating for the NC252MP is a "mere" 50W, typically one 5th of peak power.
At what output do the modules produce at a more respectable (only just) 0.01% distortion?
NC252MP in 8 Ohm, 0,01% THD+N, both channels driven :
100Hz - 240W
1kHz - 260W
6kHz - 295W
They are kinda conservatively rated...
100Hz - 240W
1kHz - 260W
6kHz - 295W
Keep on dreaming
Here's the MP252. 65w continuous per channel
The current datasheet is a bit different, but that's about it.
By the way, in the download section of the Hypex website is a good paragraph on Thermal Design; worth a read.
THD graphs compare with NC400 for example, so you should be able to guess.
NC400 is rated for 200W peak power at 8 ohm, and when you check NC400 datasheet you should divide by a factor two to have a 100 W low distortion amp.
Much depends on cooling.
That mean that NC400 is almost equal to NC50X for low distortion into 8 ohms ?
Now about the number for NC500 ? 200W low distortion into 8 Ohms ?
- Vendor's Bazaar
- Hypex NCore NC500 build
