AlephJ Mimi! (Mini)
Layout :D
:D if not in lazy mode, i can help making layout, just send schematic
Goodmorning all here!
I really appreciate the effort you do (and the rest here too :))
Well, didiet is it possible that you can make some more space for C6,C7.
If you look at the attached picture, (My diy AlephJ pcb) you can see my caramelized capacitor's :D, they are pretty big (Same size as C1)... So that would be cool. -Also for the possibility to make the pcb by hand, it would be nice if you could post the size of the pcb (When printing it's important ofcause)
Happy new year!
Jesper.
:) Didiet, you are very good at this layout... thanks.
But i got two things, that i would really like.
1. If not to much trouble for you, can you do a special non UMS layout where distance from center mosfet q5 to q7 is 170mm; this is because of dissipation/heattransfer in my chassis will be best this way!
2. Will you post the final schematic also?
Jesper.
Jesper.
170mm betwen mosfet. Or 340 betwen mosfet ?
  • Mini Aleph J std Comp.pdf
  • Mini Aleph J std bot.pdf
