Excellent job, stormsonic. Congratulations! Do you find the Peak Atlas DCA Pro's max-current capability (15.5mA according to their web page) to be a problem?
After viewing the two plots in post #43, I am reminded of the wisdom of my very conservative first boss: Qualify Your Vendors! Then keep re-qualifying!
This was a guy who insisted on writing seven (7) copies of a mask database tape during IC tape-out. Then send three of them to the mask shop. Now those lazy oafs in the mask shop can't put your job aside and party all day, claiming "the tape won't read."
Two BC550C transistors from different manufacturers. First one with black faceplate and the second with silver colored faceplate.
BC550Cs = silver faceplate
Hi stormsonic and Mark,
Tks for the very useful info.
What about BC639/40? http://www.onsemi.com/pub_link/Collateral/BC635-D.PDF
Could be a good choice?
Thanks blmn, that one might be nice. Maybe I'll get a couple to play around with, next time I place an order with an ONsemi distributor.
Isn't BC639/BC640 not the same chip as BD139/BD140 in a different case?
Regrettably hobbyists don't have access to any simulators that offer the Mextram (or VBIC) models.
LTSPICE IV supports VBIC, there are a couple of threads here on incorporating quasi-saturation.
Parameters
Because the VBIC model is based on SGP model it is possible
to start with SGP parameters, carry out some
transformations. Following parameters are from VBIC
version 1.2, which is implemented in LTSpice in the
4-terminal version without excess phase network and
self-heating effect. To switch from SGP to VBIC you should
set the extra parameter level to 9.
In some sense, but the 639/640 from ONSemi seems to be different from the ones of other brands.
But, even considering the same brand, there are different parameters, maybe due to the metallic tab on BD´s.
Just wondering about 2SC3332 going at a reduced price at local supplier - quite cheap
http://docs-asia.electrocomponents.com/webdocs/127c/0900766b8127c810.pdf - may not be a best fit current wise - but any possible audio uses?
If those devices are genuine, non-counterfeit, and virgin brand new,
I think you will probably find a good use for them in audio circuits of some kind or another.
I buy from RS Components - a source for genuine parts - with branches here and other countries. They list these as made by On Semiconductor with the hFE classification of T =200 to 400 with IC of 100 mA. - 80 minimum at IC of 10 mA with the lowest hFE rank R type.
There is an element of Hmm about the parameters - I will put in on my short list of possibilities.
I tried using VBIC, but I couldn't get any better results than just using the standard model with it's quasi-saturation additions.
Found this "sleeper" in one of the tables in The Art Of Electronics, 3rd edition. It sure doesn't exhibit any quasi-saturation! Early Voltage "VA" is 590 volts. Nice.
_
Hi Mark,
This does indeed look like a nice device. I'll have to look up its datasheet and see if it has a complement and what the ft is.
BTW, I noticed that the Locky curve tracer was used for this plot. Did you do the test that produced these curves? I bought a Locky curve tracer over a year ago, but never had the time to set it up and use it. Was it easy to get it up (assuming this was from yours)?
Bob
Yes the LockyZ curve tracer is easy to set up, once somebody tells you the magical secret:
BD437's complement transistors seem to be BD438 and BD442, neither of which have a large Early voltage. Measured VA is 87 volts, pew.
When it comes time to install the USB driver software, right click on the installer and select "Run As Administrator". If you fail to do this, misery awaits you. The drivers will appear to install but they won't work properly and you will mutter many bad words from a sailor vocabulary.
Handle your curve tracer gently, LockyZ is not currently selling new ones or repairing old ones.BD437's complement transistors seem to be BD438 and BD442, neither of which have a large Early voltage. Measured VA is 87 volts, pew.
Yes the LockyZ curve tracer is easy to set up, once somebody tells you the magical secret:When it comes time to install the USB driver software, right click on the installer and select "Run As Administrator". If you fail to do this, misery awaits you. The drivers will appear to install but they won't work properly and you will mutter many bad words from a sailor vocabulary.Handle your curve tracer gently, LockyZ is not currently selling new ones or repairing old ones.
Thanks for the tip!
Bob
Stuartmp, your question is now here:
http://www.diyaudio.com/forums/solid-state/171159-bob-cordells-power-amplifier-book.html#post5105130
- Looking for a small signal NPN with no Quasi Saturation: MEASURED DATA
